This is kind of how my bike is right now.
Since it's winter time in Michigan it means to keep the bike on the stands and violate her :devious
Thing is, im the third owner and i dont know what's been done and hasnt been done! so all you vets, she has 18k miles. what should i have done over winter?
Plans:
K&N Air Filter - Done
Change Brake fluid - Done
Install speed bleeders- Done
Install Hel SS Lines- Done
Chinese Shorty Levers- Done
Kleen air mod
ZZR front stay bracket
Lube Cables
Flush current coolant
Check/Grease Bearings
Jet Kit
Fork seals/oil/springs
Valve adjustment
Sync Carbs
New Spark Plugs
Change shock
Install APE Cam tensioner
Paint Frame (black?)-
Modding my new fairings?-
What else should i add?
Plans:
Kleen air mod
Lube Cables
Jet Kit
Valve adjustment
Sync Carbs
New Spark Plugs
Change shock
