How To: DIY Track Fairings from OEM Plastic - ZX6R Forum
post #1 of 17 Old 10-09-2013, 03:50 PM Thread Starter
mr5drums's Avatar
I Ride: 2004 ZX6R Pearl Blazing Orange
So, being that I have more time than money, I decided to buy a set of OEM nose and side plastics for my 04. After my rainy wreck at Road Atlanta I did not want to have to repair my stock orange fairings a third time due to a track day low side .
I have been saving up this thread for a while so everything is in it. If you have any questions hit me up. I know it would be SUPER easy to buy track plastics and just paint them...but hey...when you've got time, why spend the money??
The nose AND side plastics cost me 150 shipped from Sean on here. i spent about $40 total on JB weld and bondo and body filler, and $25 for my belly pan decals (they'll be in early next week and will update with pics.)
Enjoy
Nose from SSGSXRZX6R (Sean)
Piece was broken (I knew prior). Fixed.
Primed
Fairings came in from Sean. USPS broke this piece. I filed a claim and got my money back a week later for the price I paid Sean for.
Fixed said fairing. Heat molded some plastic and JB welded it. I'm going to add the triangle piece later
After primed white. Used Plastidip blaze orange. About 3 coats total.
Applied one coat of clear gloss. Makes Plastidip easier to clean and handle
Filling in the light openings for track nose.
Using some plastic from X-Ray film cartons. (My dad works in that field, has
plenty. It's really good to work with. Soft enough to easily mold with heat
gun)
Cut out the stencil. Notched spots for tabs (for securing to backside)
Use heat gun, mold the curvature.
Tabs secured with JB weld. Will probably do a ring of plastic weld just to
be super secure
Filling in the front side with a layer of bondo body filler. Slathered on
like cake batter.
Let cure for 12 hours. Used electric sander to smooth out and level the
filler with the nose plastic
Yeah I ruined the Plastidip. But hey, it peels off and I can just redo it no
problem later.
Need to bondo fill the remaining smaller cavities
Now to fix the broken chunk I couldn't find after reattaching the bigger
broken part
Using a skinnier long piece as a backbrace on the inside
Now to make this more "track compliant" by cutting the bottoms in half where
I will then attach tabs to the tops and then drill holes and rivet DZUS
fasteners.
“That which can be asserted without evidence can be dismissed without evidence”
Originally Posted by pucksdown View Post
Drums had absolute control at full lean!
Fairing Repair--Condensed version
04 to 05 Swingarm Swap
For Motorcycle and Trackday videos, check out my youtube Channel
^^^ Look....Links ^^^
mr5drums is offline
post #2 of 17 Old 10-09-2013, 03:50 PM Thread Starter
mr5drums's Avatar
Now tracing the bottom holes to cover up to catch fluids in case of a spill
As before, apply heat to form to the curves
Lay down adhesive. (JB weld)
Apply weight/pressure let cure
Fill in bottom cavities to make smooth
Do this a few times with sanding and reapplying to make sure you get all the
air pockets. This is Bondo Body filler with Red hardener, just like with the
nose plastic
Starting to wonder if JB weld will sponsor my track bike...
Mending the rest of the bottom together
Dzus fasteners came in
Creating the tabs for the Dzus fasteners. I scored the epoxy side with a
razor and drilled holes in it for extra grip on the epoxy.
Cut out a "V" to complete the last part that would catch fluids
Bottom fairing turned out real smooth. Filling in the center line with
filler then it should be good.
Since it is now October. . .
mr5drums is offline
post #3 of 17 Old 10-09-2013, 03:50 PM Thread Starter
mr5drums's Avatar
Cav likes this.
mr5drums is offline
post #4 of 17 Old 10-09-2013, 04:03 PM
Hitman123's Avatar
Looks good. I did the same thing but I just used fiberglasse to cover front cowl holes.
It's pretty easy to change for the track on my 05, basically remove the mirrors then remove the 4 screws where the lights attach to the front of the bike and the whole front cowl with the head light housing comes off.
What mine looks like.
Hitman123 is offline
post #5 of 17 Old 10-09-2013, 05:09 PM Thread Starter
mr5drums's Avatar
Thanks!
mr5drums is offline
post #6 of 17 Old 10-09-2013, 07:10 PM
Rickthefix's Avatar
I Ride: 79 XS650-SF, 96 EN500, 91 RT180
AHHH, yes, wee-hoppa, you have come very far!
I was at your house couple days ago playing with the bb, the track plastics really look good!
Did you find the orange quick-ties I left for you?
BTW, you stole my line: "I have more time than money"
Rickthefix is offline
post #7 of 17 Old 10-10-2013, 02:58 AM
jchilly92's Avatar
I Ride: 2002 ZX6R
good fucking job holy shit
Survived The Mayan Apocalypse
2002 ZX6R Emily
My Build: http://zx6r.com/build-thread/37297-j...r-project.html
-Black Hel SS Lines
-Speed Bleeders
-Chinese Double Bubble
-K&N Air/Oil Filter
-Chinese Shorty Levers
-NGK Iridium Spark Plugs
-Leo Vinici SS Slip-on
jchilly92 is offline
post #8 of 17 Old 10-10-2013, 03:14 AM
SkyChimp's Avatar
I Ride: 2011 ZX6R Ninja
I'm impressed for an Allatoona man ;-) Good job!
If you suck at riding, you're gonna die! If you're really good at riding, you're gonna see friends die!
You don't need a parachute to skydive; You need a parachute to skydive TWICE!
SkyChimp is offline
post #9 of 17 Old 10-10-2013, 04:34 AM
Ebster1085's Avatar
Nice work dude! You really got this fairing stuff down to a science. I think we should all start referring to you as the locak OEM fairing guru.
Track Bike: 2006 ZX6R
Daily: 2007 Speed Triple
A link to my build thread!
Ebster1085 is offline
post #10 of 17 Old 10-10-2013, 05:16 AM
Rickthefix's Avatar
he had a good mentor
Ebster1085 likes this.
post #11 of 17 Old 10-10-2013, 05:36 AM Thread Starter
mr5drums's Avatar
Some better pics in outside light
mr5drums is offline
post #12 of 17 Old 10-10-2013, 07:55 AM
oKayH's Avatar
Holy shit that is a lot of work. I'd be interested to see how this compares to fiberglass race bodywork in a crash.
If you want to really get all race bike on us, drill out two holes in the belly pan and put a rubber stop in. It'll make draining a lot easier after rain or blowing up a motor.
Rickthefix likes this.
CCS EX
More gas, less brake
oKayH is offline
post #13 of 17 Old 10-10-2013, 08:55 AM Thread Starter
mr5drums's Avatar
I've low sided the right side of my regular orange plastics twice theyre fine. but yes, OEM is harder so it handles sliding better. BUT, it is not as "squishy" or "flexy" like fiberglass is so it smashed and cracks a little easier. Time will tell. hopefully not on this bike. She is pulling double duty for now until i save up for a track only B model in the early spring
noted...will add these before Barber next weekend. good thinking
mr5drums is offline
post #14 of 17 Old 10-10-2013, 09:52 AM
Rickthefix's Avatar
he has a great sensei ....
post #15 of 17 Old 10-10-2013, 10:11 AM
Slice3054's Avatar
I Ride: 2006 ZX-6R
I hope you know this is really helpful man! Thanks. :
Slice3054 is offline
diy bicycle fairing
diy fairing zxrr motogp
diy r6 race fairing
homemade racing fairing
how to build track fairings
making a 3 quart belly pan motorcycle zx6r
making a belly pan for street plastics track bike
making a fiberglass race cowl for a motor bike
orange gloss plastidip
plastidip fairings
track bike fairings
used track plastics zx6r
FS: 05/06 636 zx6r OEM Fairings and Windscreen preludezx6r Classifieds 4 02-16-2013 04:00 PM
FS: 07-08 ZX-6R OEM Fairings MrGoo Classifieds 11 02-08-2013 12:43 AM
Where to get track fairings in the uk? sharkyad The ZX6R 4 06-14-2012 04:36 PM
09 zx6r OEM blue fairings for sale glclark Classifieds 0 05-21-2012 12:15 PM
Track Fairings kwakinut Classifieds 2 06-30-2009 02:38 AM
