MFChop CCS #396 ZX6-R - Race Bike Build - Page 2 - ZX6R Forum
 37Likes
post #16 of 56 Old 09-19-2016, 08:42 AM
"I wrapped the box in DEI Gold Heat Delfect because if you cant go fast "
Thanks for the reminder. I have to do this on my track build. .
Sabotage is offline
post #17 of 56 Old 09-21-2016, 01:53 PM
PinoyRider88's Avatar
I Ride: '13 ZX-6R
Dude this looks amazing. Forgive my newbness but what is the purpose of the block off plates?
2013 ZX-6R
PinoyRider88 is offline
post #18 of 56 Old 09-21-2016, 04:38 PM Thread Starter
MFChop's Avatar
I Ride: 2015 ZX6-R & 2012 GSX1300R
It removes the Pair System. The pair system is used to remove oil fumes / blow by from the engine and clean up emissions. Removing it prevents oil fumes from being burned and hindering performance. It also causes issues with the air / fuel ratio as well
MFChop is offline
post #19 of 56 Old 09-24-2016, 12:44 PM Thread Starter
MFChop's Avatar
Today I got back into my garage and had a full Hindle exhaust system waiting for me courtesy of Woodcraft Technologies
The quality is great even includes a pre-welled bung if you need to run an O2. I opted for the ceramic black but you can go with one of 4 different cans
Just on the weight savings alone, I saved almost 10lbs! Im sure with the carbon fiber or titanium can you will save even more
OE System
Hindle
Installation was pretty straight forward..
You can get your own at Hindle Exhaust
Next up will be installing a Bazzaz and having it tuned by Dyno Solutions
blitzkraig and Ur2Fat2Wear like this.
MFChop is offline
post #20 of 56 Old 09-25-2016, 02:55 PM Thread Starter
MFChop's Avatar
Had to swing by the track today and do a bunch of tire / wheel swapping.... So while I was there and the wheels were off I picked up Fast Frank captive spacers from a local vendor..
What makes them so much better than other copy cats out there is that if you notice they are beveled which allows them to be guided in
blitzkraig likes this.
MFChop is offline
post #21 of 56 Old 09-29-2016, 05:33 PM
wheresMyLid's Avatar
I Ride: 2010 ZX-6R Race bike - 2011 Husqvarna TE630
Those chamfered edges make all the difference. Have had a set of locally made captive spacers for a while now. Night and day difference when changing wheels!
Great build thread! Keen to see how you progress it further.
wheresMyLid is offline
post #22 of 56 Old 10-09-2016, 01:20 PM
whatisabutt4's Avatar
I Ride: 2011 ZX6R - (Track ) 2016 ZX6R (Street)
Looks sic. Did you have to get longer brake lines then stock length to work with brembo RCS master?
whatisabutt4 is online now
post #23 of 56 Old 10-10-2016, 02:17 PM Thread Starter
MFChop's Avatar
Thank you
I cant exactly say, Spiegler makes the rennsport longer i.e. looser to not restrict travel of the suspension. The Brembo will match up perfectly fine to the OEM lines though however the pitch of the lever range may be restricted
MFChop is offline
post #24 of 56 Old 12-13-2016, 01:58 PM Thread Starter
MFChop's Avatar
Well theres been zero changes until today.... This came in the mail for me to install this weekend!
PainfullySlo likes this.
MFChop is offline
post #25 of 56 Old 12-13-2016, 02:11 PM
Looking good bud! Just a quick note: I just noticed the header install. Consider this a friendly reminder that we are required to safety wire the outside header nuts.
ZedExMuse likes this.
PainfullySlo is offline
post #26 of 56 Old 12-13-2016, 02:15 PM Thread Starter
MFChop's Avatar
Shhhh tech never notices jk
Yeah I have the nuts from my 05 just haven't swapped them yet
MFChop is offline
post #27 of 56 Old 12-19-2016, 07:31 AM Thread Starter
MFChop's Avatar
So I got around to installing the Bazzaz yesterday....
First I installed a servo buddy to eliminate the FI light and exhaust servo motor supplied by Woodcraft Link
The Bazzaz install is pretty straight forward however there are two aspects to this install I was not particularly a fan of.
1. Bazzaz instructs the power supply be tapped using a Scotchlok, these are the devil! So a good old fashion solder guarantees Ill never have a power disruption to the unit
2. Bazzaz is designed to be installed at the rear of the tail in the trunk. Im not a fan of this because in my opinion it puts it in a vulnerable location to damage in the event of a high side. So thanks to the room freed up using the Servo buddy its now nestled lower down under the seat.
I have the newest version of the Bazzaz system that includes a strain gauge with the USS system. My bodywork is not in yet so I havent been able to decide the optimal location for the USS module
Special thanks to my mechanic for giving me a hand too
(FYI his middle name is Agostini lol)
Still have a long but simple list of things to do but I have till end of April to get it all buttoned up
Felixthecat likes this.
MFChop is offline
post #28 of 56 Old 12-19-2016, 11:30 AM
ninjaman89's Avatar
Bike is looking awesome!
ninjaman89 is offline
post #29 of 56 Old 01-01-2017, 01:23 PM Thread Starter
MFChop's Avatar
Small victory today.... GPR installed
MFChop is offline
post #30 of 56 Old 01-01-2017, 02:25 PM
I Ride: 2014 Kawasaki ZX-6R
Here's how I routed the QS gauge
Martillo y Mantequilla #99
Some Thoughts and Tips On Bike Theft Prevention groomlake Motorcycle Talk 50 11-02-2016 03:20 AM
AM #396 MFChop LRRS /CCS Round 4 Race Report - You cant stop me from racing! MFChop Racing 8 08-18-2015 03:11 PM
2013 Kawi ZX6R 636 Race Bike WCCoffey Classifieds 15 12-08-2014 01:43 PM
