MrZ and his Franken-Julia - Page 3 - ZX6R Forum
 22Likes
post #31 of 40 Old 03-18-2017, 03:00 PM Thread Starter
MrZ
MrZ's Avatar
I Ride: my sexy Julia
First ever throttle body sync, at 23.000km (manual says every 10.000 duh!)
How i started
How i left it at
Bike got way too hot (and fan wouldn't kick in...wonder why)
So i had to shut it off and couldn't leave it in parts. It's way better than before anyway.
Planning on a coolant change, maybe tomorrow.
MrZ is offline
post #32 of 40 Old 03-18-2017, 03:19 PM
Looks great,, fan would have to be well the fan is bad or the sender.
Assuming there is power going to it.
MrZ likes this.
post #33 of 40 Old 03-19-2017, 10:34 AM Thread Starter
MrZ
MrZ's Avatar
Coolant change today
Old coolant vs fresh
I'm going to check the fan within the following week.(I have to take the airbox out...again!!!^@^%$@*) I already checked the fan fuse and it was fine.
According to the service manual, there is a relay for the fan, but it is hidden in a relay box(?) and i'm not sure if i can check this.
And the temp sensor goes straight to the ECU.So i assume there is one sensor for gauge reading and fan.Since my reading is fine, i assume the sensor is too.
We'll see...
MrZ is offline
post #34 of 40 Old 03-19-2017, 12:26 PM
And the temp sensor goes straight to the ECU. So i assume there is one sensor for gauge reading and fan.Since my reading is fine, i assume the sensor is too.
We'll see...
Glad you swapped the coolant... that looks like it was well past it's prime.
I would try and power the fan directly, to make sure you chase the right issue..... many fans fail when they get jammed; a very few have a fuse that recovers. Most don't, and rely on the fuse in the box to protect the wiring.
MrZ likes this.
post #35 of 40 Old 03-20-2017, 11:40 AM Thread Starter
MrZ
MrZ's Avatar
Tested the fan...working.
Fuse ok.
Now what?
MrZ is offline
post #36 of 40 Old 03-21-2017, 04:43 AM
Fuse ok.
Now what?
There should only be a few other components.... the temp sensor which indicates the temp to the ECU, then the ECU, which commands the relay that provides power to the fan. The loop has to be complete for both the control line, and for the power. That means the wiring all has to be intact, and making good electrical contact where it is meant to.
If the fan will run directly, that's obviously not the fault.
If you have a temp reading on your instrument display, the temp sensor should be okay.
That leaves the ECU, the relay, or the wiring.
If you have a meter, you can check to see the ECU is sending the right signal to the relay.... since that's the most expensive part that seems like something we should eliminate as soon as possible.
If the voltage on the pin on the ECU that is meant to activate the relay changes as it should when the motor gets up to temp, the relay is likely not using that signal as it is meant to. you need to make sure that the voltage gets all the way to the coil of the relay and that the other side of the relay's coil is getting back to the battery.
A relay is a very simple electric motor -- when you apply power across the coil, the armature moves from the Normally Closed pin, to the Normally Open. Power from the battery is supposed to be constantly present on the Common pin, and goes whichever way the armature sends it.
You can also check the relay's action, by applying 12VDC to the coil pin and checking to hear the 'click'.
You can also use your meter to Ohm between the 'C' and 'NO' pins -- that should be wide open (infinite) with no power applied. The opposite should be true if you measure between the 'C' and the 'NC'..... that should be a dead short, and go open when you apply power.
It is not all that uncommon for relays to eventually wear out and fail.... but I would just as readily expect that there is a corroded contact which is preventing everything from working.
Last edited by RJ2112; 03-21-2017 at 07:49 AM. Reason: changed thermostat to temp sensor --doh!
post #37 of 40 Old 03-22-2017, 04:28 AM
hows the fairing?
good fit? and this set is made by our real injection mold,
auctmarts is offline
post #38 of 40 Old 03-23-2017, 11:01 AM Thread Starter
MrZ
MrZ's Avatar
I have temp reading so i suppose that the sensor is ok.
I tested the relay and it is working.
But i got confused when i turned the key of the ignition...
I measured the pins of the relay connector that activate the relay(18,19) and i had a reading!!! I thought that there shouldn't be a reading until the ECU sends a signal.
Bike was cold, so i was expecting not to have a reading until it got hot.
On the other hand, 17,20 had nothing.
I thought it would be easy and i also thought that i understood how the circuit worked.
Now i am lost...
MrZ is offline
post #39 of 40 Old 03-24-2017, 05:20 AM
You have to have a difference of potential to get the current to flow. If both sides are at 12V, no current. When one is 12 and the other zero, current flow.
Pin 18 may be pulled 'low' by the ECU.... the active signal from the ECU may be grounding that pin.
Pin 17 -20 (Normally Open) on the relay side should read infinite Ohms, with no power applied, and should then read nearly zero Ohms when that difference of potential is applied between pins 18 and 19.
Strider and Indy like this.
post #40 of 40 Old 03-24-2017, 05:45 AM
You have a reading on the cluster?
Some older models have two, one for the cluster, don't know if yours does or not.
The second is a switch that closes once a set temperature is met.
You have a reading, what is it.
Put one lead on the battery negative the other on 18, then 19. What do you get.
IF nothing. Put one lead (of the meter) on the positive post of the battery. Repeat readings on 18 and 19. What do you get.
Repeat voltage check from above on both sides 17 and 20. What do you get.
I don't have your schematics of your model. Print them out to a PDF and attach them to a post.
Want to trace the circuit from the fan back.
