Wire up heated grips via an automotive relay
This is a discussion on Wire up heated grips via an automotive relay within the Guides forums, part of the ZX6R Forum category; Hi all, It's been a while since I added anything useful to the forums, so here goes: I rode all last winter without hot grips ...
Old 12-12-2009, 09:38 AM   #1
Mentok's Avatar
Thumbs up Wire up heated grips via an automotive relay
Hi all,
I rode all last winter without hot grips and I'm f**cked if I'm doing that again this winter.
Grips can simply be wired directly to your battery, but if you forget to turn them off when you leave your bike you might end up needing a bump start.
I've also heard of wiring them directly off the bike's loom, but I don't like the idea od putting extra load on the loom with non standard parts. Grips can draw a fair bit of current and if it screws up the loom you're in for a world of pain.
I'm not going to bother with the actual grip install, this is pretty straight forward. I would recommend running all wiring on the opposite side to your throttle cables though and use plenty of zip ties and anchors to keep the wires out of harm's way. I didn't solder anything but used proper male/female connectors similar to the ones used by Kawasaki for the rest of the electrics.
The part that's tricky to find information about is the wiring of the relay. So, here's a nice simple diagram I made to explain the way I wired things up:
I used the +ve wire from one of my tail lights for the relay trigger - that way the grips will only work when my tail lights are on. One the bike is switched off the lights being off will cause the grips to also switch off automatically.
This means the grips wont work unless I ride with the lights on, but I usually have them on anyhow so it's no biggie.
It's a 2 pole relay - tab 87a on the relay is powered when the lights are off, so I can wire in a flashing LED to make it look like my alarm actually works if I wish.
Mentok is offline
« Fairing Repair | - »
09 zx6r heated grips
2006 zx636 heated grips
2009zx6r electrical diagram
automotive relay wiring
heated grips 2009 zx6r
heated grips automotive relay wiring
heated grips automotive relay wiring diagram
heated grips relay wiring
hot grips relay
hot grips wiring diagram
hot grips wiring relay
how to wire auto relay
how to wire automotive relay
how to wire heated grips relay
how to wire up a relay for heated grips
simple automotive wiring diagrams
wire automobile relay
wire in relay to operate heated grips
zx6r grips install
zx6r heated grips
07/08 LED Turns and Flasher Relay Install AtomicZX Mechanical and Technical 4 01-31-2012 05:11 PM
Non h4 relay kit wired to hi/lo switch?? How does hi/lo switch work? JonP925 Mechanical and Technical 1 01-24-2012 11:20 PM
Wasting money (on oil).... Chaos Mechanical and Technical 84 08-28-2011 11:00 AM
Wire up heated grips via an automotive relay Mentok The ZX6R 2 12-12-2009 06:13 PM
Heated Grips sc00bs The ZX6R 4 09-30-2009 04:59 PM
