How To Pull FI Codes
148K views 33 replies 18 participants last post by  David Flower
#1 ·
This How To is performed on a 2003 Kawasaki ZX-6R and will be the same for any of Kawasaki's ZX models with fuel injection; other Kawasaki Fuel Injected bikes have similar or identical methods to pull the FI codes, so hopefully this will help.
There are two Self Diagnostic modes you can enter; Dealer Mode 1 and Dealer Mode 2. In dealer Mode 1 only current FI codes will be displayed, and in order from lowest FI code number to highest. In Dealer Mode 2 all past and present codes will be displayed, once again lowest to highest. I will explain how to enter both modes.
Kawasaki has designed the self diagnostic system so that you can preform it with out any extra wires or leads that are not already attached to the bike; however I have a set of leads that makes the process much easier which you will see later. However I do recommend you gather up a piece of paper and a pen so you can record the FI codes that are displayed, so you don't have to try and remember all of them.
Start by removing the front seat, this process is slightly different on each model so I won't go into it, next locate the self diagnosis lead. This lead is yellow and is protruding from the wiring harness near the Battery Negative (-) Terminal.
I have created a set of lead,s that attach to the self diagnosis wire, that have an alligator clip on the end. For anyone who does this on a regular basis and does not have three hands, a lead of this type is highly recommended. Other wise you will have to pull back the shroud on the end of the self diagnosis lead, or find some other piece of wire to connect to it.
Next turn the key switch into the "ON" position on wait for the bike to finish its starting sequence. To enter Dealer Mode 1 simply ground the self diagnosis lead continuously on the Battery Negative (-) Terminal. I do this by attatching my aligator clip to the terminal.
The red FI light on the dash will now start to "blink" out the codes. Long blinks are values of Ten (10), short blinks are values of one (1). So a sequence of bliiiiiiiiiink bliiiiiiiiiink blink blink blink would be code number 23.
The system will display all the current service codes for the fuel injection system, i.e. sensors that are currently not working properly. After all the codes have been displayed it will cycle back to the first code and continue displaying the codes in numerical order until you unground the self diagnosis lead. The reason I use the alligator clip is so that I can use both hands to record the codes as they are being displayed.
To enter Dealer Mode 2 you will tap the self diagnosis lead on the Battery Negative (-) Terminal more than five (5) times within two (2) seconds and then hold it on the terminal; so "tap, tap, tap, tap, tap, hold". After doing this keep the lead on the terminal just like what you did for Dealer Mode 1. Now in Dealer Mode 2 all current and past codes will be displayed, in numerical order not order of occurrence. So say you just dumped your bike coming up the driveway, this would have tripped the Vehicle Down Sensor, but as soon as you cycle the key switch that sensor is reset and the FI light goes off; but now you have the bike all opened up and you have the stick coild for cylinder one (1) unplugged. In Dealer Mode 2 codes 31 (Vehicle Down Sensor) and 51 (Stick Coil #1 malfunction) will be displayed numerically. Where as in Dealer Mode 1 only code 51 would have been displayed.
Another feature in Dealer Mode 2 is the option to erase all stored service code. To do this you must already be in Dealer Mode 2; then pull the clutch lever in for at least five (5) seconds and release it, now repeat the Dealer Mode 2 tapping sequence I explained earlier and remember to hold the lead on the terminal after the 5th tap. Now all the service codes have been erased and you have a clean slate to work with.
Here is a list of all the service codes (taken from a manual for an 05 ZX-6R, so it could possibly not have codes for other models).
I hope I have laid this all out clear enough for you to understand, if you have any questions please ask and if you need more help with you bike problems feel free to send me a PM and I'll send you the PDF version of the Service Manual for your bike and walk you through other diagnostic and repair procedures. :D
#2 ·
Nice wright up! You may want to make that picture smaller so that the whole thing fits on the screen; makes it a bit hard to read when you have to keep scrolling, but other than that; good work! :hail
#3 ·
I resized the pics last night on photobucket, but it took a little while before the update went through to this site; they're all better now.
#6 ·
Thanks for bumping the thread... but couldn't you jsut have posted that on Zoom's wall? :lol:
#8 ·
Yeah, should be the same, except you'll have an extra code for the power valve that the B models don't have.
#10 ·
Lolz, forgot I was smart enough to do that the first time :p
#13 ·
You are welcome Reaper. I know I've said this before but... Damn cuz, I like ur bike... I love that white with them rims. Just fit so nice.
#14 ·
this does not work with the 07 and up models. we have a dieagnostic plug. it has 4 wires. i know one is ground but the wires arent discussed in the manual. also, the maual says the old/historical service codes that occure are not able to be erased, once corrected the code will clear. it doesnt say if it will even be stored. just says they will clear. any thoughts? EVIL? my MMI buddy.
#17 ·
see all the more reason for me to go to the school! good thing i enrolled.
#21 ·
Wash your hands you filthy animal.
#22 · (Edited by Moderator)
My bike isn't exactly clean, it gets used... alot.
#27 ·
no prob
#29 ·
Okay Pulling them up is an easy thing, another thing does anybody know how to remove Error Codes 34 and 67 on an 09 6R? I know why there doing it as its the full system on it obviously, but what way can i get rid of these?
#30 ·
You'll need an electronic eliminator for each; a servo buddy for the exhaust servo and an O2 eliminator for the O2 sensor.
#33 ·
Historic Fault Codes are accessed using KDS (Kawasaki Diagnostic Software)
Due to the cost of the Kit you would be best to visit a Local Kwak Dealer with a Tech that knows how to use it.
There are other means like Texa but again cost prohibitive for the Man in the street :(
