How to: DIY Servo Remover - Page 4 - ZX6R Forum
 4Likes
post #46 of 228 Old 07-11-2011, 09:06 PM Thread Starter
Chaos's Avatar
I Ride: 2011 ZX-6r
for some reason it isn't working perfectly, and i can't figure out why. I have my guesses, but not 100% sure.
in theory an axial resister shouldn't make a difference, but i will be pissed as hell if i find out that's what the problem is.
I've been talking to a guy that sells these and he might be able to work out a deal for me to test a servo buddy, and ultimately dissect it. I'm gonna get it when i come back from vacation, which will be next weekend (the 23rd)
2011 ZX-6r
chaosfromabove.com
Chaos is offline
post #47 of 228 Old 08-01-2011, 11:04 AM Thread Starter
Chaos's Avatar
I Ride: 2011 ZX-6r
Ok just a little update, decided to take the plunge and drop $60 to put an order in for a ServoBuddy, so when it gets here I'll test ride it for a little, then dissect it and post my findings...
2011 ZX-6r
chaosfromabove.com
Chaos is offline
post #48 of 228 Old 08-01-2011, 04:30 PM
josh42575's Avatar
I Ride: '06 ZX10R 05 ZX6R
you ARE the man!
GOOD JUDGEMENT COMES FROM EXPERIENCE......EXPERIENCE COMES FROM BAD JUDGEMENT
josh42575 is offline
post #49 of 228 Old 08-04-2011, 12:15 PM Thread Starter
Chaos's Avatar
I Ride: 2011 ZX-6r
well...i got the servo buddy in the mail today...cut off the heat shrink to reveal a nice thin coating of some sort of black epoxy that is just thick enough to block part numbers, values, and the paths for the parts on the top side of the circuit. Apparently it's using some sort of voltage regulator tho. IDK if I'm going to be able to do anything with this...but i'll see what happens.
Here's what I'm dealing with:
2011 ZX-6r
chaosfromabove.com
Chaos is offline
post #50 of 228 Old 08-04-2011, 12:31 PM Thread Starter
Chaos's Avatar
I Ride: 2011 ZX-6r
well i just tried removing a little of it and unfortunately there's no way to preserve any of the values on the surface mounted reistors. I can't ohm them out either...unfortunately I'm gonna have to call it a loss before I damage this thing beyond belief. Wish there was an easier way, sorry guys, I have failed you. So until someone can get a hold of a schematic or or a servobuddy without epoxy on it, I can't do anything.
2011 ZX-6r
chaosfromabove.com
Chaos is offline
post #51 of 228 Old 08-04-2011, 01:10 PM
usdsk8er540's Avatar
I Ride: 05 ZX6R 636
damn. oh well. it was worth a shot. does it still work so you can put it on your bike?
usdsk8er540 is offline
post #52 of 228 Old 08-04-2011, 07:45 PM
09ZX-6R's Avatar
I Ride: 2010 ZX-6R
a heat gun will melt the epoxy off it. just be carefull not to over heat the circuit. iv done it before with a heat gun on a high setting. makes for high heat and fast action.
09ZX-6R is offline
post #53 of 228 Old 08-05-2011, 11:06 AM Thread Starter
Chaos's Avatar
I Ride: 2011 ZX-6r
Tried that too...it pulled off the coating that was on the surface mounted resistors :\ I know there's a schematic out there for Ivans servo eliminator, I'm gonna try to use that and see what i can do with it
2011 ZX-6r
chaosfromabove.com
Chaos is offline
post #54 of 228 Old 08-05-2011, 11:22 AM
oKayH's Avatar
I'm wondering if that 14 pin IC is just digital logic, purpose built, or a MCU. Anyway of poking around at it with an external power supply and some type of meter?
oKayH is offline
post #55 of 228 Old 08-07-2011, 09:39 AM Thread Starter
Chaos's Avatar
I Ride: 2011 ZX-6r
I have a strong feeling the servo buddy is using the LM3900N amplifier. I really hope this will work. However I'm tight on cash right now, so if someone else wants to try this out first, by all means go for it and let us know how you made out!
Here's the next schematic I'm going to start working with:
Name:	Servo Eliminator Detail.jpg
2011 ZX-6r
chaosfromabove.com
Chaos is offline
post #56 of 228 Old 08-21-2011, 08:57 PM
09ZX-6R's Avatar
I Ride: 2010 ZX-6R
ok so i figured out why its not working for us!!! the setup is right!!
symptoms:
1st startup, no FI light.
shutdown
2nd starup, FI light on.
shutdown
3rd startuo, FI light on. repeat.
unplug unit, wait 1 minute and reconnect. no FI light.
restart, FI light on.
bla bla bla
this seems to be the consistant issue. same goes for the guys on the ZX10 site that i post on with ZX6's
heres the trick, DISCHARGE the cap between starts. works everytime. momentary switch can be put from pos to neg on the cap. pushing the button will drain the cap so u can start the bike with NO FI LIGHT!!
at high revs everything works too.
now the trick to make a perm. fix....i leave it up to you guys.
chaos...the new schematic looks good. have you tried it yet?
09ZX-6R is offline
post #57 of 228 Old 08-22-2011, 07:20 AM Thread Starter
Chaos's Avatar
I Ride: 2011 ZX-6r
symptoms:
shutdown
shutdown
bla bla bla
Interesting...i had a feeling it had something to do with the cap needing to discharge...makes sense y there's a voltage regulator in there now...
I haven't had the time to check that new schematic yet. But i think im going to research how to make the cap discharge itself when there's no current running through it...I'd rather stick to that schematic as it's a lot easier to use with a lot less parts lol. I'll keep you guys informed
Quick update: after only a few minutes of searching I've come up with a couple of ideas of how to discharge the capacitor when the bike is off. Use some kind of light (LED) or a high valued resistor across the capacitor. I'll give it a shot sometime this week and let you guys know how it works out. If anyone else wants to give it a shot, by all means go for it! Just be sure to post your findings.
2011 ZX-6r
chaosfromabove.com
Chaos is offline
post #58 of 228 Old 08-22-2011, 07:45 AM
Banned
I have a 09 zx6r with a slip on exhaust and no FI light issues
green600 is offline
post #59 of 228 Old 08-22-2011, 08:01 AM Thread Starter
Chaos's Avatar
I Ride: 2011 ZX-6r
Obviously you didn't read the OP...or remove the servo motor...
2011 ZX-6r
chaosfromabove.com
Chaos is offline
post #60 of 228 Old 08-22-2011, 08:44 AM
Banned
Whats the benefit of removing the servo motor?
green600 is offline
06 zx6r exhaust servo eliminator
06 zx6r servo buddy
08 zx6 bypass servo
2006 zx6r exhaust servo bypass
by pass servo zx6r
diy 2005 kawasaki zx6r servo eliminator
servo diy
servo eliminator zx6r
servo motor bypass zx6r
zx6r servo buddy
zx6r servo eliminator diy
FS: Servo Eliminator Chaos Classifieds 121 01-13-2013 05:57 PM
05 636 Servo faceplant Mechanical and Technical 10 01-17-2012 04:45 PM
Servo Removal Tutorial lil636 Mechanical and Technical 5 09-22-2011 09:17 PM
Servo Motor..... cam012 Mechanical and Technical 22 04-11-2011 12:20 AM
****Motor Electric aka Servo Motor**** ZX6R_C1H The ZX6R 0 06-10-2009 06:19 AM
HTML code is On
