Install Pazzo Levers
This is a discussion on Install Pazzo Levers within the Guides forums, part of the ZX6R Forum category; Tools needed -Flat head srew driver -3/8 socket and socket wrench -Size 5 Allen wrench Clutch side -Remove the nut on the bottom side of ...
Old 11-24-2006, 04:53 PM   #1
h20-50's Avatar
I Ride: 05 ZX6rr
Tools needed
Clutch side
-Remove the nut on the bottom side of the lever (3/8).
-The nut is easier to access if you remove the two bolts that hold the whole lever and actuator on the handle clip-om (both 5mm allen wrench)
-Once you have the nut off you need to loosen the clutch cable by turning the big silver adjuster that connects to the base of the lever.
-Once the cable is loose, pull the clutch out and remover the cable from the inside of the clutch.
-Next remove the spacer that is inside the clutch and put it in the new lever.
-Next place the cable back in its place on the inside of the lever
-Reposition lever back inside of actuator.
-But bolt thorugh hole and screw the nut back on the bottom (3/8 socket wrench)
-When the bolt is back in place and the lever is bolted back to the clip-on, tighten clutch cable to preference.
Brake Side
-Remove screw from the bottom of the brake (3/8 socket wrench)
-Then remove the flathead screw from the top off the brake lever.
-Then remove the brake lever.
-when replace the new brake lever in its place you will notice a "pin" sticking out make sure that "pin" is seated in the cut out on the brake lever for it otherwise you the new lever will not be able to slide into place.
-Once the "pin" is in it's place the new lever is is on screw the flathead screw back in.
-Then screw the bolt back on the bottom. (3/8 socket wrench)
Hope this helps!
h20-50 is offline
09 zx6r cable pics
2006 kawa zx6r levers
2006 zx6r clutch levers
2007 zx6r levers installation
2009 zx6r brake handle
2009 zx6r break and clutch levers
2009 zx6r levers
2009 zx6r levers install
brake lever pin removal
how to change zx6r levers
how to instal a zx6r aftermarket front brake lever
how to install lever on zx6r
pazzo levers 04 zx6r
pazzo levers zx6r
zx6r brake lever assembly
zx6r clutch lever bolt
zx6r crg levers
zx6r lever install
zx6r levers
zx6r pazzo levers install
pazzo levers? joeyhalifax Mechanical and Technical 16 03-29-2012 11:55 AM
FS: pazzo levers pmjones Classifieds 2 08-31-2011 06:14 AM
Installing Pazzo Levers Today / Cable Lube Question muffinman The ZX6R 2 07-18-2009 12:55 PM
pazzo or crg levers sick3sicks Want to Buy 1 06-24-2009 04:59 AM
Anyone have blue PAZZO levers? kellen The ZX6R 4 06-03-2009 03:06 PM
