Read your FI light codes on the fly
This is a discussion on Read your FI light codes on the fly within the Guides forums, part of the ZX6R Forum category; Now this one is super simple. All you will need is a male bullet connector, about 3 inches of wire, and a 1/4 inch eyelet ...
Old 10-28-2007, 09:33 PM   #1
Wesley Randles's Avatar
I Ride: 08 ZX6R Track, 05 ZX10R Street
Now this one is super simple. All you will need is a male bullet connector, about 3 inches of wire, and a 1/4 inch eyelet connector.
1. Just crimp the bullet connector on one end of the wire and the eyelet on the other side.
2. Remove the seat, and the bolt that holds the tank on at the back, and slip the bolt through the eyelet, and reinstall it.
3. As you can see from the picture, that orange wire on the left is the signal wire for the FI light codes on the gauge pod, and the one on the right is the connector I made to read the codes. Whenever you get a FI light trip, you just connect those two wires together and that will flash the code in the Gauge pod, the just look in the manual and see what the code is.
Wesley Randles is offline
07 zx6r fi light
2006 zx6r how to check fi light
checking code 636 fi
fi light on 636
how to check 2006 zx6r fi light
how to check codes on kawasaki 2008 zx6r fix
how to check codes on zx6r
how to check codes zx636
how to check codes zx6r
how to check f1 codes for 08 09 zx10
how to read fi light kawasaki
how to read fi light zx10
kawasaki 2008 f1 code
kawasaki 636 fi code
kawasaki zx6r forum fi
what is the fi light on zx6r?
zx6r code
zx6r code check
zx6r fi light
zx6r service code
Everything you need to know about HID / Xenon Steve The ZX6R 15 05-03-2012 07:24 AM
How To Pull FI Codes EvilTwin Mechanical and Technical 26 02-19-2012 03:46 PM
Tail Light electrical problems 2201436 Mechanical and Technical 11 12-17-2011 06:53 PM
Tail light doesnt work Erik Mechanical and Technical 10 10-30-2011 01:44 PM
