Bi-Xenon Projector Install / How To - ZX6R Forum
post #1 of 31 Old 01-29-2012, 06:33 AM Thread Starter
Steve's Avatar
I Ride: 2017 636 KRT Performance Edition
Hey guys,
I decided to finally stick my projectors in the bike.
I'll try and post as many pics/videos as possible so you can see exactly what I done.
This is on going so check back to see up to date progress.
First things first, get the headlight removed
Then remove all the bulbs and rubber seals:
Now you want to preheat the FAN assisted over to 150C (300F)
Now having a look at the headlight, the only parts which now hold the lens onto the headlight is these clips: (4 in total)
Now you need to find yourself a nice bit of think wood, or dense wood like birch or mahogany and stick the headlight on it to save from deforming other parts of the headlight from the heat:
Now set your timer for 3 mins:
Then Stick her in:
Now wait.. for roughly 3mins (funnily enough), then grab your mits:
Now take the lights out and place on a suitable work surface.
NOW LISTEN TO THIS PART.
Using flat wide objects like a wide screw driver etc pry the sides up ensuring that the clips are not holding onto the lens.
Now you must work SWIFT not quickly as you want to take your time with this but not so long that the glue gets cold.
A little bit of force is required but work your way round and round the lens till it starts to fall free.
Now be careful and make sure you do not get any of the adhesive on the lens projector etc etc, if you have to, when its stretches (like cheese on a pizza) just pull it off with your fingers, roll into a ball and discard.
Now hopefully you should have the first side off (for the people with separate lenses):
So now onto the other side, since you have take your time doing it, its time to stick it back in the oven again for another minute (only 1 min, as anymore is just over kill)
bring it out and same again with the other side, pry open the lens.
and thats how easy it is getting the lens off,
now you have full access to the projector and the surround to do as you please.
I will also mention now you have the lens off, cover them in cling film or as such to prevent scratches if your working on them:
So far I have done this and I've started modifying my projector to fit into the housing but this will come late, keep an eye out for updates.
Steve
Steve is offline
post #2 of 31 Old 01-29-2012, 06:33 AM Thread Starter
Steve's Avatar
Here is a video of what is next in the process
Modifying the projector to fit the standard housing.
http://www.youtube.com/watch?v=hn65xFq_9jo&list
the video was cut abruptly at the end due to memory space running out, but I got what I needed in.
I'm going to post up more pics later in the follow up to this video.
Steve
Steve is offline
post #3 of 31 Old 01-29-2012, 06:33 AM Thread Starter
Steve's Avatar
Ok so now you have the projectors out and your sticking in your new Bi-Xenon ones.
Mines, which are the FX-R projectors, are a little big.
At first I thought I would have to cut up the headlight a little bit to make room but after having a play with the projector in the headlight I've managed to get it in a position where is sits snug.
Now I wanted to keep the adjustment screws in use (the ones you use to change the direction of the beam from left/right or up/down).
This consisted of 3 screws to which bolt onto the standard projectors.
Since mines do not line up I decided to make a bracket to which the projector will be bolted to:
My original template was a bit thin in places, making the metal bracket a little weak but where I could I increased the size to make it more sturdy.
Now here is a look at the projectors with the brackets attached:
Make sure you have the tilt on the projectors set correctly before bolting anything down, last thing you want in one cut off line sloping left and the other sloping right.
What I did was bolt it on with 1 bolt then rotated the projector clockwise or anti-clockwise to get the cut off line flat (and I mean flat… I had a spirit level out… haha)
Once your cut off line is flat then the minor adjustments like up/down and left/right can be done with the standard screws already on the headlight.
Now this is the new projector in the headlight compared to the standard projector:
a trial fit with the lens:
Looking good so far… now the second one:
Coming together just nicely.
Now here is a quick explanation of what I've just done in a video:
http://www.youtube.com/watch?v=rLjR-3kl604
Now next I will be going into the smaller details like, covering up escaping light and painting the projector etc etc… keep posted.
Steve
Steve is offline
post #4 of 31 Old 01-29-2012, 06:34 AM Thread Starter
Steve's Avatar
Ok first things first.
I'm going to answer a common question, Why Dont You Use The Standard Projector?
Simple... Its not good for light output.
With HID you can get a lot more light out than a standard halogen bulb so therefore the projector is made different, It spreads the light.
Unlike a halogen projector which is more concentrated due to the lower light output from a halogen bulb.
Anyways, Moving on...
I got these:
High Temperature Black Paint and Aluminium Tape
The high temp pant is for spraying the projector as there was a little too much silver showing when I trial fitted the projector so wanted it to look more subtle.
Finished:
Now the Aluminium tape is to cover up any gaps the projector lets light out of so that the only light coming out is from the front:
Now she is beginning to look the part
Just a little pic to see how she sits in the plastics:
Now I want to make sure she seals up perfectly. At the back of the projector there is a rubber seal, and it does not fit the new projector.
So I cut a strip of metal out and JB welded it to the projector to make a nice tight fit so it will be sealed off:
And here is it with the rubber on it so you can see what will be visible behind the headlight:
So now I'm just waiting for the JB weld to completely cure and be solid so I can get the projectors in for one last time and get the lens back on them for the final adjustments.
In the next thread I'll be covering the final adjustments and the resealing of the headlight and maybe if I'm luck a little video of the final shot at night
Keep tuned
Steve
Steve is offline
post #5 of 31 Old 01-29-2012, 06:34 AM Thread Starter
Steve's Avatar
One last slot of easy viewing
*insert content here*
Steve
Steve is offline
post #6 of 31 Old 01-29-2012, 12:58 PM
imadude1134's Avatar
I Ride: 05 zx6r mostly stock
Subscribed... Looking good so far... Lots of pics are a plus for noobs like me
05 ZX6R - Plasma Blue
-TBR Dual Slip-on, Double-Bubble Smoke Windscreen, Sequential Integrated tail light, Vortex Rear Sets, Blue Shorty Levers, Grey ZX Gel Grips
Originally Posted by mark72 View Post
never ....you can ride my bike .....you can even shag my wife but you will never race my car.......lol
imadude1134 is offline
post #7 of 31 Old 01-29-2012, 08:38 PM
MDeezy's Avatar
Yes Steve!!
Looking great so far!
What projectors did you go with?
HIDs and what temp rating?
Subscribed for future comments and random statements!
05 ZX6R - Samantha...PUIg Black Double bubble|| Random frame sliders| Morimoto Dual Bi-Xeon Retrofit with 35w 6k HIDs| more to come...
MDeezy is offline
post #8 of 31 Old 01-30-2012, 10:47 PM Thread Starter
Steve's Avatar
My set-up is as follows:
FX-R Bi-Xenon Projectors
D2S 4300K Bulbs
35W Slim Ballast
Steve
Steve is offline
post #9 of 31 Old 01-31-2012, 12:00 AM
MDeezy's Avatar
Excellent.
Do the FX-R projectors bolt right up? or do you need to do some modifications to make it fit?
just to help this be a more educated thread. What is the difference between a d2s bulb and a regular say H1 or H7 HID bulb? I know the D2S bulb is a superior bulb just not sure in what way
ib4linktoalluneedtoknowabouthids
MDeezy is offline
post #10 of 31 Old 01-31-2012, 06:13 AM Thread Starter
Steve's Avatar
FX-R projectors don't fit perfectly but I'm going to do a bit of modifying to make it fit, keep an eye on the thread and you'll see the progress.
If you want to know about the bulbs see my other thread giving all the information you need.
http://zx6r.com/zx6r/22111-everythin...hid-xenon.html
Steve
Steve is offline
post #11 of 31 Old 01-31-2012, 07:55 AM
MDeezy's Avatar
Good job! I'll be keeping an eye on the progress!
MDeezy is offline
post #12 of 31 Old 02-08-2012, 10:46 AM Thread Starter
Steve's Avatar
going to get a video on the go soon to give you an update on the progress.
but in the mean time here is a couple of teaser pics:
Steve
Steve is offline
post #13 of 31 Old 02-08-2012, 10:57 AM
Mercedes's Avatar
I Ride: 2007 Cbr1000 Repsol
what's wrong with the stock projectors? just curious
and I can't wait to see it with 4300k I don't like the gay blue hid's people put on
Mercedes is offline
post #14 of 31 Old 02-08-2012, 11:09 AM
Stock projectors are not HID projectors. I'm sure you and others have noticed how if you put an HID kit in stock headlights, the light output near the bike isn't as smooth. It looks like a ring of light on the ground in front of the bike. This is because the stock projectors are made for halogen bulbs and directs the beam differently than a true HID projector would.
The OP is also using bi-xenon projectors which, I'm assuming, means that both projectors would be on for low beam and also high beam. Bi-xenon projectors have an internal solenoid that activates a mechanism when high beams are triggered. This causes the cutoff of the light to be raised which mimics high beams.
hzhong456 is offline
post #15 of 31 Old 02-08-2012, 11:11 AM Thread Starter
Steve's Avatar
The standard projectors in the headlights are for Halogens only not HIDs.
so i'm changing mines to Xenon projectors, not only that they are bi-xenon so both will be on and both can do high beam.
My pictures only show 1 as i've only got one temporary fitted in.
Also those are 4300K I have in that projector.
Steve
Steve is offline
06 zx10 installing bi-xenon projector
07 zx6r bixenon
2000 zx6r projectors
2006 zx6r bixenon hid install
bixenon projectors 06 zx6r
how do i install xenon hid lights on a 07 zx6r
how to change direction of my hid headlights zx6r
how to install bi xenon projector headlights
how to install bi-xenon projector headlight
morimoto hid kit zx6r
zx6 projector
zx6r install single hid projector
Everything you need to know about HID / Xenon Steve Mechanical and Technical 60 10-27-2015 09:52 PM
HTML code is On
