How To: change a j rear to a b rear - Page 5 - ZX6R Forum
 5Likes
post #61 of 65 Old 02-13-2012, 06:58 PM
NuggetNik's Avatar
I Ride: 2001 Blue J2 ZX6R
Originally Posted by mark72 View Post
what im doing now is collecting B plastics .....and J frames
so im going to convert a couple .....if any one is interested when they are done ...
it should be a straight bolt on conversion with the modified frame and plastics
the plastics will be primed all for you colour to go on
the frame will be painted satin black
all you will need to do is cut down your battery tray/undershield ....to fit it all in
and buy a new light unit
You haven't said how much you are thinking of charging for your services lol
Originally Posted by TXZX6R View Post
WTF Nugget... I thought they were suppose to fix your brain?? You seem A LOT more fucked up now... YOU FUCKEN WEIRDO! bahahahahahaha
Big Up The "Fizzy Gravy" Club
NuggetNik is offline
post #62 of 65 Old 02-14-2012, 02:47 AM Thread Starter
scoobs's Avatar
I Ride: something naughty
i know ....it all depends on how much i get the bits for .....being realistic i would do the rear for £50 plus parts ....
but the seat is down to you ......
scoobs is offline
post #63 of 65 Old 02-14-2012, 01:21 PM
NuggetNik's Avatar
Dam, That isn't bad at all really bud... if someone dosen't have the knowledge to do it themselves and needs a hand to do it for a price!
I wont be looking to do it any time soon, maby next year or somthing like that lol
But I will keep it in mind :-)
post #64 of 65 Old 03-09-2012, 04:29 PM
0104zx6r's Avatar
dude thats SICK but one hell of alot of work and finding parts and tinkering
0104zx6r is offline
post #65 of 65 Old 03-09-2012, 04:38 PM Thread Starter
scoobs's Avatar
no not really alot of work .....its pretty easy to do ......follow the step by step advice and you should have the plastics and frame mounted in mock up stage within about 2 hours easily
as for finding parts ....all parts came off my smashed up B series so i had all parts to hand
scoobs is offline
00 zx6r subframe swap
2001 zx6r cdi
2001 zx6r subframe removal
changing 01 zx6r tail section
changing seat unit on zx6r
how to change a j rear to a b rear
how to change the rear subfram on zx6
how to cut rear seat of a zx6
j1 zx6r seat change
modify rear end 02 zx6r
putting a b1h subrame on an f1
zx6j rear shock
2008 Zx6r rear brake pad change..Not sure where shim or sensor goes? Jtuned8 Mechanical and Technical 3 09-13-2011 02:29 PM
Rear tire change from a 180 t0 a 190 THUG The ZX6R 50 05-23-2011 09:42 AM
07 rear shock change geordieninja The ZX6R 2 01-24-2010 06:12 PM
HTML code is On
