How to: Install Stainless Steel Brake Lines - ZX6R Forum
post #1 of 19 Old 03-31-2012, 11:12 AM Thread Starter
Chaos's Avatar
I Ride: 2011 ZX-6r
Disclaimer: Myself nor anyone on zx6r.com is responsible for anything you may break while following this how-to. This how-to is purely informational and can be taken however you like. If this is out of your mechanical ability, please, for the love of your bike, don't do it.
With the legal jargon out of the way, lets get started, shall we?
So I was getting annoyed with the squishy feeling of my stock brake lines and decided it was time to upgrade to SS braided lines. I went ahead and purchased HEL's kit and I must say I'm very impressed. I was also shocked at the ease of the installation (minus a few wtf brain fart moments lol). So here we go:
Step 1:
First things first, get ur bike up on a stand - i just used my rear swingarm stand...i don't recommend using a fork stand because your gonna want to be able to move the front wheel for maximum accessibility.
Now we need to tackle the brake reservoir. Unscrew the "lock" from the reservoir, and take the lid off. After you take the lid off you'll notice a rubber diaphragm looking thing (used to prevent water vapor from getting to the fluid) - carefully pull it out to expose the fluid.
Step 2:
Next you need to get the fluid out of the reservoir. Theres a couple of methods to do this: you can just traditionally bleed the brakes, use a suction pump, or my personal favorite, use a turkey baster it'll get like 90% of the fluid out in one shot. Then you'll have to bleed the brakes to get the fluid out of the lines. Granted you won't get it all out so keep that in mind when removing the lines.
Step 2a:
If you don't know how to bleed your brakes this will be a quick touch on how to do it. If you are still confused, Google it.
Basic procedure - pull the cover off the bleed nipples on the master cylinder and the 2 calipers. Get a tube that can fit over the nipples with a bottle to catch fluid and a 10mm wrench for the calipers. Do one at a time. Start with the right caliper. Open the nipple (turn the wrench) press and hold the brake, close the nipple. repeat this until you are pulling air. Then to the left caliper. Next do the master cylinder (you'll need an 8mm wrench for this nipple) for good measure, there probably won't be any fluid in there, but it doesn't hurt to do it.
Step 3:
Time to loosen up the master cylinder for better access to the under side. Using an allen wrench loosen, but don't remove, the bolts holding the master cylinder to the clip-ons.
Step 4:
Now we begin the fun part. Get a rag or a crap ton of paper towels and start covering everything under the master cylinder. Using a 12mm socket undo the banjo bolt at the under side of the master cylinder. Remove it and set it aside.
A little further down, above the radiator, you'll see the little junction box with 3 lines going to it. Unbolt it and set the bolt aside (no fluid will come out here).
Now we move down to the calipers following the same procedure of removing the bolt from master cylinder. Again, don't forget to protect your rubbers and paint/powdercoat from the brake fluid.
After you got the banjo bolts out of both calipers, you'll need to remove the line guide that is in the fender. Its a little tricky to remove em, you kinda have to pinch them and pull them out. Might need to pinch from the inside of the fender. Don't get frustrated, it'll give out eventually.
Once you get both of those guides out the lines are free to be removed. Grab em from the master cylinder line and carefully pull em out the top. Be careful of spillage.
Congrats you're done. Now go test ride the bike and report back....
Step 5:
If you survived the previous step, congrats you're not a moron. I felt i needed to do my part to further help Darwins theory of natural selection. Anyways...
Get your new brake lines out. There should be 3 to a full kit. The rear lines usually have the companies logo on both ends (for mine it did at least). Looking at the 2 front lines, the shorter of the 2 is going to go to the right caliper and the longer to the left. Right side is the side that the brake lever is on.
Now it's time to begin the physical installation. Both brake lines will be going directly to the master cylinder. Grab the long bolt that has 2 holes in it along with 3 crush washers.
Hold the bolt so the head is pointed down. Slide a washer on, right brake line with the banjo angled down, followed by another washer, then the left line with banjo down, followed by the last washer. You don't have to worry about the holes lining up.
Screw this into the master cylinder, but don't tighten it yet. Now bolt the bajos up to the calipers. You should be doing washer, banjo, washer. The banjos bend goes forward to back (refer to photo below). Dont try to force them, if they aren't lining up you did something wrong.
After everything is all bolted up and tightened, you'll need to fill the reservoir with fluid and begin the bleeding procedure again. This time start with the master cylinder nipple. Loosen, squeeze, tighten. loosen, squeeze, tighten. do this until there is no air bubbles and make sure to not let the fluid drop below the lower line, or you'll start drawing air and have to start all over. Use this method for the right then the left caliper. For good measure do it twice or until all air is out of the system and your brakes work properly.
Step 6:
Now onto the rear brakes!
Remove the housing for the reservoir (08 and older bikes are mounted in a different location)
Drain the fluid like you did for the front reservoir and bleed the brakes. Remember, once you're pushing air you're done.
Side note: I found it very strange that my bike only has 28XX miles on it and i had black some black fluid...something to keep in mine for the future...
Time to unscrew the banjo bolts (again, cover all areas with a rag or towel)
Before you can remove the brake line, you'll have to take the line guide that runs along the swing arm and holds the hugger in place off.
Pull the line out and you're ready to install the new one.
Make sure to take note of which way the banjo's lined up and install the new lines the same way. Again, fill the reservoir with fresh fluid and bleed the brakes. You only have to worry about 1 nipple on the caliper.
That's it, you're done! Changing the brake lines is actually quite easy if you access to the tools and the mechanical knowledge. If you have any questions feel free to ask em and i'll try to help. Enjoy the better non-squishy braking power!
Allelockon and DblD like this.
2011 ZX-6r
chaosfromabove.com
Chaos is offline
post #2 of 19 Old 03-31-2012, 02:15 PM Thread Starter
Chaos's Avatar
I Ride: 2011 ZX-6r
just a little update...finally got around to taking it out for a test drive....talk about better braking lol...the response is alot better and feels a bit smoother...no more squishy squishy....oh...and you can do a burnout with east
2011 ZX-6r
chaosfromabove.com
Chaos is offline
post #3 of 19 Old 03-31-2012, 02:27 PM
TwoBit's Avatar
I was just about to do this too! Perfect timing that you have done this write up. Good job and thanks Chaos!
TwoBit is offline
post #4 of 19 Old 03-31-2012, 02:28 PM
Steve's Avatar
I Ride: 2017 636 KRT Performance Edition
Thats an awesome write up there my friend
What brake fluid did you use to refill?
Steve
Steve is offline
post #5 of 19 Old 03-31-2012, 03:07 PM
Kevin2109's Avatar
I Ride: 2006 ZX636r
Those brakes are soooooo good Best upgrade on the older model ZX's
September 2012 6OTM Winner!
Honda has 1 or 2 good points. Everything does. Including Herpes. Herpes has it's own herpes infected only dating site. Is this a reason to catch herpes? FUCK no.
<-----My Youtube----->
Kevin2109 is offline
post #6 of 19 Old 03-31-2012, 03:26 PM
oKayH's Avatar
I just installed mine last night and tested them hard today
SS lines are the best upgrade upgrade you can do on any bike. I highly recommend anyone use this guide Chaos has provided and throw some lines on ASAP!
CCS EX
More gas, less brake
oKayH is offline
post #7 of 19 Old 03-31-2012, 03:57 PM
6OTM Master of Ceremonies
Youssef636's Avatar
Been there done that
Winner - 6OTM March 2012
FAQ for new riders
Youssef636 is offline
post #8 of 19 Old 03-31-2012, 03:59 PM
DaddysNinja's Avatar
Great write up man. I did my when i rebuilt my bike and i will never go back.
Need to make this a sticky.
Nil conscire sibi
SOLD 2007 ZX6R 03/29/2013
Only once.
Originally Posted by SkyChimp
DaddysNinja is offline
post #9 of 19 Old 03-31-2012, 04:37 PM
Connorvore's Avatar
I Ride: 2005 zx6r
Only thing that sucks about the 05/06 brake lines I got (Galfer colored steel brake lines) is I had to cut a notch off the master cylinder to get it to fit. Other than that super easy install
Connorvore is offline
post #10 of 19 Old 03-31-2012, 06:58 PM Thread Starter
Chaos's Avatar
I Ride: 2011 ZX-6r
Haha awesome. Glad this was able to help everyone...unfortunately i know this will be buried within a week...no one can sticky it
Steve
I can't remember off the top of my head, but I'm pretty sure it was Prestone DOT4 synthetic
2011 ZX-6r
chaosfromabove.com
Chaos is offline
post #11 of 19 Old 03-31-2012, 09:30 PM
oKayH's Avatar
I will add to this...
If for any reason you bleed brakes or install these lines somewhat regularly (more then 1 a month) then a vacuum bleeder is worth the $40.
CCS EX
oKayH is offline
post #12 of 19 Old 04-01-2012, 12:40 AM
Fletch's Avatar
I Ride: 2003 ZX6R
Good write up mate, im considering SS lines at some point lol
Black double bubble screen, Pro Grips black and green, Shorty levers, Moto gp carbon stubby can "Loud As Hell" Aluminium pegs with ZXR engraved in them, R&G Tail tidy, Green wheel rim tape, Bright white LED side lights, Decals removed, Rear seat cowel, Carbon petrol cap cover, Front and rear tinted lights, ZX6R Monster tank pad, Zip tie mod, Clean air mod
Fletch is offline
post #13 of 19 Old 04-01-2012, 01:38 AM
bod
bod's Avatar
I Ride: kawasaki zx636r c6f
Did mine on my 06 636 a while ago,easy todo loads better brakeing feel,....connorvore why did u have to cut a notch outa master cylinder to get them to fit, is it just with the galfer lines i installed HEL and was a straight forward fit matey... just curious..
KAWI ZX6R 06 636
CARBON FIBRE AIRBOX TANK COVER,CARBON FIBRE SWINGARM COVERS,CARBON FIBRE HUGGER,CARBON FIBRE MUDGUARD,CARBON FIBRE CHAIN GUARD,CARBON FIBRE ENGINE COVERS,CARBON FIBRE DASH PANELS,CARBON FIBRE FRAME PROTECTORS,CARBON FIBRE DECALS,BREMBO MASTER,ZZR1400 FRONT CALIPERS,ZX6R 2014 310MM DISCS,HEL BRAKE LINES,EBC SINTERED PADS,PAZZO SHORTY LEVERS,GALFER WAVY REAR DISC,POWERCOMMANDER3 WITH CUSTOM MAP,K&N AIR FILTER,IRIDIUM PLUGS,DE-CAT,ARATA RACE CAN,RAM AIR MOD,08 REAR SHOCK,2012 MIRRORS,SMOKED INDICATORS,HOT BODIES SMOKED SCREEN,GILLES REARSETS,POWERBRONZE GREEN CRASH BUNGS, BIKE REPAINTED KAWI GREEN WITH CARBON FIBRE DECALS AIRBRUSHED..
bod is offline
post #14 of 19 Old 04-01-2012, 05:38 AM
Torino's Avatar
I Ride: 07 zx6r
luv the write up. I swapped to ss lines last month.
Totally cracked me up with the last comment for step #4.
Torino is offline
post #15 of 19 Old 04-01-2012, 07:58 AM Thread Starter
Chaos's Avatar
I Ride: 2011 ZX-6r
+1 or even if u frequently do it by yourself, pressing the rear brake while holding a wrench, tube, and bottle in the other hand gets old quick.
2011 ZX-6r
chaosfromabove.com
Chaos is offline
07 zx6r brake line replacement
07 zx6r brake line size
2005 zx6r steel braided brake lines
how to change brake line 2005 kawsaki ninja zx6r
how to change brake lines on 2005 zx6r
manual brake hoses kit zx6 b1h
stainless steel brake line installation
what is the switch on a brake on a stock 2012 zx6r
zx6r brake lines
zx6r steel brake lines
zx6r.com steel brake line
zzr600 how to install ss brake lines
Stainless Steel Brake Lines? fulopchoy99 Mechanical and Technical 18 10-20-2014 07:42 AM
Stainless Steel Brake lines jmorgan3 The ZX6R 20 04-15-2013 01:13 PM
front brake lines hitting fork tubes. need help please. Chuck Mechanical and Technical 8 06-03-2011 11:56 PM
05-06 Galfer Stainless Steel rear brake line DellsNinja Classifieds 4 01-23-2010 05:18 PM
HTML code is On
