How-To: LED DRL in Headlights - ZX6R Forum
  • 1 Post By yabbaz
post #1 of 7 Old 08-20-2012, 08:49 PM Thread Starter
yabbaz's Avatar
I Ride: 07 ZX6R
Well, today, instead of trying to put halos in my headlights, i got the idea of putting some white LEDs there. Looks pretty good IMO.
TOOLS NEEDED:
Flat head screw driver
Philips head screw driver
Drill
Dremel (optional)
Automotive wire (optional, only use if not splicing into the running light or low beam)
Solder (optional)
Soldering iron (optional)
Heat shrink (optional)
Toggle switch with terminals
Inline fuse (optional)
PROCEDURE:
1. Remove the upper fairing. If you do not know how to do this, do NOT bother attempting this mod.
2) Remove headlight assembly from upper front fairing as directed in your service manual. Keep bolt locations straight and set dash cover brackets aside.
3) Separate the headlight cover from headlight assembly, i followed this process:
- Preheat oven to 250 degrees
- Place headlight assembly in oven for ~5 min. (Recommended you place assembly on tray/foil to avoid melting/burning from direct heat)
- Remove assembly with oven mitts
- Pry back clips enough to clear, plastic should be soft enough not to crack
- Use flat head screwdriver or other tool to slowly pry apart the clear headlight cover from the mounting assembly. Take your time, it is hard to get started, but gets easier as they come apart. Be careful not to let the melted adhesive get on the clear healight covers. Depending on how long it takes, you may have to put it back into the oven for a minute to soften the second one.
4) Remove the inner headlight trim, via the 3 Philips head screws (shown in the picture.)
5) Place the LED strip inside the headlight housing (shown in picture) and replace the inner headlight trim (removed in step 4.)
6) Drill a small hole wherever you see fit, and feed the LED wires through. I drilled a hole near the front on the inside.
7) Place the headlight lens back onto the assembly, and place back in the over to loosen the glue. I placed it inside the oven for about 3 mins. Then push the lens back on so the clips connect again.
8) Reassemble the upper fairing.
9) Disconnect the negative battery cable. Grab your automotive wire if you're wiring to a switch and connect some wire to the positive terminal of the battery. Run that wire to the in-line fuse (use solder and heat shrink to join, or just use wire nuts), and then continue to the power terminal of the switch (sorry for no pictures of this, will update next time I take the bike apart)
10) Next, connect the positive wires of the LED strips to the "LOAD" terminal of the switch. Usually in the middle of the switch.
11) Grab some more wire, and run the negative wires of the LED strips to a ground, or the negative battery terminal.
12) Remove the terminals from the switch. Grab your dremel and cut a spot for the switch to be placed into the inner fairing. Place the switch into the hole you made and reconnect the power wires.
13) Power on your lights and enjoy!
sparkplug896 likes this.
07 ZX6R "Aleiah"
My Bike Build: http://zx6r.com/pictures/31398-yabba...-red-bike.html
YouTube: https://www.youtube.com/user/yabbazHD
Originally Posted by zxrider432 View Post
wow Tyga is pretty nasty on a dirtbike.
Rack city bitch rack rack cittyy 10 10 11 12 13 14 15 15 20s and 30
Originally Posted by tbird412 View Post
I just don't know how to break the ice with "Hey, would you mind sticking this 36" dildo up your ass completely using milk as lube and then taking a purple plastic poop while I film it?"
yabbaz is offline
post #2 of 7 Old 08-20-2012, 08:52 PM
sampson03's Avatar
I Ride: 03 Zx6r
thought you were selling this pig?? lol looks great!!
PC3'd/M4 high mount/BMC race filter/free mods!/07 swingarm/05+ wheels/R1 front calipers/05+ front rotors/-1 +3/venhill braided lines/bixenon projectors with 35w HIDs/Dunlop Q3s
sampson03 is online now
post #3 of 7 Old 08-20-2012, 08:52 PM
09ZX-6R's Avatar
I Ride: 2010 ZX-6R
nicely done...
09ZX-6R is offline
post #4 of 7 Old 08-20-2012, 08:54 PM Thread Starter
yabbaz's Avatar
I Ride: 07 ZX6R
psh.. fuck that. selling the car instead haha
nicely done...
thank ya sir.
07 ZX6R "Aleiah"
yabbaz is offline
post #5 of 7 Old 08-20-2012, 08:54 PM
givuhcky22's Avatar
I Ride: 2015 636 Carbon Grey
pretty sick dude. good thing you skipped out on our ride so you could put lights on your bike
i hate you
givuhcky22 is offline
post #6 of 7 Old 08-20-2012, 08:55 PM
givuhcky22's Avatar
but still, very well done.
post #7 of 7 Old 08-20-2012, 08:55 PM Thread Starter
yabbaz's Avatar
I Ride: 07 ZX6R
i hate you
woulda come, but i dropped my phone 20 mins from you guys, and lost the address
07 ZX6R "Aleiah"
yabbaz is offline
07 zx6r headlight screws wont
2012 zx6r drl
best spot for led on zx6r
can you use a led running lights on 2009 zxr6
how to install led headlights on ninja 1000
how to put leds in headlight
how to wire hradlight led lights on a 06 zx6r
install led running lights inside headlight
led drl inside headlight heat
running lights inside headlights
zx6r drl lights
zx6r led headlights
Wide Angle 10mm LED HeadLight install Doms 636 Pictures 8 09-02-2012 02:21 PM
TST Bracket and LED Light w/custom switch MasterTurkey Pictures 3 08-16-2012 01:30 PM
LED headlights for 08 ZX6R Rudebwoy Mechanical and Technical 12 04-03-2012 01:42 AM
LED headlights jumbalaya09 Mechanical and Technical 9 10-15-2011 11:03 PM
wiring led strip lights Nassty Mechanical and Technical 4 06-26-2011 07:53 AM
HTML code is On
