How to: Homemade Power Commander III Quick Shifter - ZX6R Forum
 5Likes
  • 5 Post By Kevin2109
post #1 of 1 Old 08-22-2012, 05:47 PM Thread Starter
Kevin2109's Avatar
I Ride: 2006 ZX636r
Found a DIY for this on a zx10r forum, so I decided to make my own variation. Please ask any questions you may have
Disclaimer! If you blow your shit up, thats on you, not me. I personally havent had any problems with it
Parts:
Wire
Switch (picked mine up at radio shack)
bolts (I used 4-40 (I know its not metric ))
Some sort of female pin for the PC plug
Tools:
Wire cutters/strippers
Drill
allen for bolts
Thread tap (that matches your bolts)
Step 1: Figure out your mounting point. At first I was going to make a bracket but soon realized that the shift rod moves enough down that it has the potential to activate the switch. Notice, I'm running GP shift, so if you are not this placement wont work, but the concept is the same
Step 2: drill 2 holes for the bolts that hold the switch in place, and tap them
Step 3: Check your mounting points and make sure it all lines up
Step 4: solder wires onto the switch and run them to the tail
Step 5: Figure out how to get the wires to stay into the correct pins on the PC. You need to connect the 2 wires to the top far most right and top far most left pins. I had some female pins laying around that fit perfectly onto the PCIII's pins, then wrapped tape around it to hold them on (sorry I didnt take a before tape picture )
Step 6: Go to this link and download the QS add on, and activate it with your PCIII plugged in
http://www.powercommander.com/downlo...KillEnable.zip
Step 7: Open the PCIII software and change the delay to 85ms (seems to work well, but again, you will have to adjust it to what you like)
Step 8: You are going to have to adjust the metal lever that hits the switch, the goal is to get it to activate as you push the lever down, it will take some fine tuning to get it correct
Step 9: Go ride it!
September 2012 6OTM Winner!
Honda has 1 or 2 good points. Everything does. Including Herpes. Herpes has it's own herpes infected only dating site. Is this a reason to catch herpes? FUCK no.
<-----My Youtube----->
Kevin2109 is offline
2006 zx10r diy mods
diy power commander
diy quick shifter
homemade power commander
homemade power sifter
homemade quick shifter
homemade quickshifter
how to build a quick shifter
pc3 quick shifter homemade
power commander quick shifter software
quickshifter pcv zx10r 2006
zx6 quick shifter
How do you remove Power Commander III? GGEENN The ZX6R 17 08-22-2012 03:07 PM
Dynojet Power Commander III Emanuel2b The ZX6R 5 07-11-2012 08:23 AM
Quick power commander and m4gp question kawizx6r743 Mechanical and Technical 6 05-09-2012 09:54 AM
Power commander III stang07 Want to Buy 0 03-14-2012 12:03 PM
Power Commander III or Juice Box?? Iconmoto528 The ZX6R 4 08-14-2011 03:06 AM
HTML code is On
