Stator Replacement, Oil Change, More with pics - ZX6R Forum
 7Likes
post #1 of 16 Old 08-25-2013, 04:58 PM Thread Starter
devildogae's Avatar
I Ride: 2009 Black ZX6R
So my 2009 zx6r wouldn't charge, or start, and I knew it was the stator, again. So since I'm going to be doing a replacement, and some maintenance, I figured I would post of some pics to help anyone who wants to do it... Here goes:
First thing is to take off the fairings, now I'm sure there is a way to get to the stator without taking it all off, but I'm going to clean this sucker good, and it makes it easier to get to things like the coolant system and anything else I see I need to refresh or clean.
After you have the fairings off, you want to place an oil pan underneath your bike to catch the oil from the oil change and the stator cover being removed.
To drain the oil, you must loosen the bolt at the bottom of the oil pan, unscrew this with your fingers making sure to hold on to the bolt so you don't lose it as the oil gushes out.
Loosen the oil filter and place a paper-towel under to catch the oil that will leak.
Take it off and get the new filter from the box. Take some of the oil in the pan and lubricate the rubber seal on the new filter. I make sure I get it nice a tight so it doesn't vibrate loose.
Next you will want to remove the fill cap and replace with new oil. Everyone has their own preference, but for me I like synthetic Royal Purple 10W-40.
Ok, Next I am going to remove the stator. Now you want to loosen all the bolts to the stator cover. Once they are all out, grab a pair of needle nose pliers and prepare to jerk the cover from two opposing sides, for example, start on the right side and place the pliers inside a bolt hole, jerk hard to loosen the gasket and magnetic connection. Next do the same to the left side until the cover comes off.
The image above shows why I was having issues, the wire burnt up, so I cut the remaining wire loose. Also the next image is what it looks like with the cover off, except I cut my wire.
In order for you to get the stator out and the new one in, you just fetch the connecting wire that is ran to your regulator/rectifier, which you disconnected if you took the fairings off. They are located on the inside of the right upper fairing behind where the ninja logo would be.
The first step is to take off the gas tank. You must unscrew the olinns steering damper and set aside. Next there are two screws that hold the front of the tank to the body, take those out. Now you will be able to lift from the front, but only so far. So now you must remove the screw the bottom of the tank rotates on. When this screw is out, you will be able to lift the tank up some, but know you will need to disconnect some lines and plugs. Make sure you have a towel, or a couple to use under the tank as you tilt it to catch any leaking gas, and to separate the tank from the body, we don't want to scratch up our nice looking paint. Trace the electrical wire under the seat and disconnect. Then disconnect the black "S" shaped gas line, use a flat edge screwdriver to pop the red locking cap backwards and just pull. I usually don't disconnect the overflow lines, so bring them out with the tank.
When you place the tank down, make sure to place on a box or something in order that the weight is not on the little metal nozzle that you disconnected the "S" gas line from, this can break easily and then your buying a fuel pump.
Ok, so now your ready to get the air filter box up and out of the way.
There is one screw at the top-front and easily seen, remove this screw.
Next you will need to pop the little black plastic caps from the frame so you can get to the screws that are holding the attachment from the air box to the throttle bodies. Unscrew them just enough the loosen their grip on the connection. Once you have done this, pull up and backward and the airbox should come up. You will also need to unattach a hose at the bottom of the airbox. I don't take the airbox totally off, so just sit up upright until you are done.
Now is a good time to check out the status of your filter, from where the air comes in, this will give you a good idea of if you need to replace it without taking the top of the air box off, and as you can see, mine looks like it's time to replace. Would be a great time to clean out the airbox as well, so I will do that later.
Make sure to place a couple clothes, papertowels, or newspaper in the throttle body intakes to make sure you don't get debris or loose screws down in them.
Now it's time to get the wire out. So go over to the right side and locate the grey connector. This should be your stator connection, the other is black, so just ignore that one.
Trace the wire under the frame and locate under a group of other wires. Pull it out from under the frame and loosen anything keeping it down. Remove from any attachment so your ready to remove from the left side of the frame.
Now that you have removed the cable from the both sides of the frame, you can remove from behind any other hoses and free it from captivity.
The hardest part is getting the transformer circle off of the stator cover. I have had to use an impact drill. Make sure you put tons of pressure on the screws so they don't strip. To be Cont...
______________________________________
WERA # 333 Novice
devildogae is offline
post #2 of 16 Old 08-25-2013, 06:02 PM Thread Starter
devildogae's Avatar
Waiting on parts, will take more detailed pics...
WERA # 333 Novice
post #3 of 16 Old 08-25-2013, 07:50 PM
I Ride: 2009 CBR600RR
Looks good so far! I wish I had a garage!
Bootes is offline
post #4 of 16 Old 08-26-2013, 07:31 AM Thread Starter
devildogae's Avatar
Yea I have to rent one with my apartment. Can't wait to have a house with a garage
WERA # 333 Novice
post #5 of 16 Old 08-26-2013, 07:46 AM
ZXNasty's Avatar
I Ride: 2011 ZX6R
Just one note, if you do break off that silver nozzle, you won't need a new tank, just a new fuel pump
Originally Posted by rodas6r View Post
1nastyZ and zxnasty, forum a-holes, and heroes
Originally Posted by MonsterZX View Post
lol I am picturing nasty coming rolling off the bike and then just jumping up out of it and goin into a gas station buy a monster and start drinking it like nothing just happened
Originally Posted by iLean2much View Post
you're not the first who comes along wanting to look good. but i'd be the first to point at you and laugh while picking up your poor bike you just dropped in front of everyone.
Originally Posted by kninja View Post
beef curtins
AKA Princess
ZXNasty is offline
post #6 of 16 Old 08-26-2013, 08:17 AM Thread Starter
devildogae's Avatar
Indeed, will edit thanks!
WERA # 333 Novice
post #7 of 16 Old 08-26-2013, 08:55 AM
06olyzx6's Avatar
Great write up with pics, but I have to ask why or how did the wires go bad? Don't want to do this job and if I could avoid I would love to.
2006 ZX-6R
Muzzy, -1 front,Servo Elim installed
06olyzx6 is offline
post #8 of 16 Old 08-26-2013, 09:20 AM Thread Starter
devildogae's Avatar
I'm not totally sure, but I believe when I replaced the stator the first time, the wire got to close or in contact with the transformer. That's my best guess! I am going to try and use some heat resistant silicon to insulate the wire that's in close proximity to the coils.
WERA # 333 Novice
post #9 of 16 Old 08-31-2013, 04:31 AM
Looks like I will be going down this rabbit hole as well....
A few of questions:
1) Did you buy the same replacement stator the second time, as the first?
2) Did you see anything different, that would make you think the OEM stator would be more reliable?
3) What sort of shipping times have you been quoted for the replacement -- how long did the first one take to get to you?
4) Did you consider a used stator, rather than new?
5) Do you know when the reg/rec recall was done on your bike? How many miles/hours since new?
post #10 of 16 Old 08-31-2013, 08:56 PM Thread Starter
devildogae's Avatar
A few of questions:
I bought a ricks the first time and bought Kawi OEM this time.
The OEM looks to have a protective cover over the coil of wires, looks to be better quality. I also got a great deal from a guy who bought two by accident off eBay. $100 shipped
I don't remember, but they both came very fast.
I didn't consider a used one.
I did the recall about 6-7K I believe.
WERA # 333 Novice
post #11 of 16 Old 08-31-2013, 09:08 PM
Good stuff man. I cracked the cover on my stator and now I gotta replace it. But I was wondering....will a 03-04 stator cover fit a 05-06?
Scorpi0 is online now
post #12 of 16 Old 09-08-2013, 02:08 PM Thread Starter
devildogae's Avatar
I have no idea about that one, but my guess is no
WERA # 333 Novice
post #13 of 16 Old 09-08-2013, 07:03 PM
stevect's Avatar
Nice write up. I had to replace.cover but was too lazy to take tank and intake.off. If u peak under tank, you can reach in with a flathead and undo the brackets holding in the rectifier wire and pull out the wiring without removing anything.
stevect is offline
post #14 of 16 Old 09-09-2013, 01:39 AM
d1andonlyant's Avatar
I Ride: 04' ZX636
Nice write up apart from the holes you blocked aren't carb holes seeing as these bikes don't have carbs, they're the throttle bodies I believe
beantownmick likes this.
04' ZX636
Ram Air Mod - Kleen Air Mod
Short Stacks Mod - MWR Filter
SP Quickshifter - 2012 Shock
__________________
d1andonlyant is offline
post #15 of 16 Old 09-09-2013, 09:11 AM Thread Starter
devildogae's Avatar
Cool
Yes throttle bodies
WERA # 333 Novice
how to , oil change , stator
2005 zx6r engine starter case removal
2006 636 changing oil after taking off statot?
2009 ninja 1000e stator replacement
champion 46514 stator replacement
how to change the stator zx6r
how to replace the stator gasket kawaski 636 2005
kawasaki 636 stator cover change
replacing stator 2006 zx6r
stator connection on kawasaki zx6r j1
why does a cracked stator cover cause an oil leak on my2013 kawi ninja
zx6 stator connector location
zx6r stator replacement
oil change LoboZX The ZX6R 32 04-19-2016 11:52 AM
Rotella T6 5W-40 carotte Mechanical and Technical 57 07-31-2013 10:03 AM
Showa BPF oil change question PowerGroove Mechanical and Technical 7 08-28-2012 12:29 PM
ZX6-R Oil Change AxKaN Mechanical and Technical 15 03-26-2011 04:10 PM
Project Mongrel ZX6R Quarkz The ZX6R 116 09-29-2009 11:02 AM
HTML code is On
