How To: 2013+ ZX6R EVAP removal, Block off plates for CA models - Page 2 - ZX6R Forum
 6Likes
post #16 of 19 Old 04-01-2015, 08:43 AM Thread Starter
EDIT
halcyon026 is offline
post #17 of 19 Old 04-07-2015, 10:31 PM
I Ride: 2014 Kawasaki ZX-6R
Thanks a lot for this write up! I have been looking everywhere for this. Do you think it would be a viable option to just replace the cap with, for example, a vented Vortex or driven cap? Also, how are you getting around the error codes?
post #18 of 19 Old 04-08-2015, 04:55 AM
Schooley's Avatar
I connected the wires on the EVAP valve harness together and didn't get any codes.
Schooley is offline
post #19 of 19 Old 04-08-2015, 06:59 AM
Super Moderator
EvilTwin's Avatar
You can stick a 100ohm resistor where the old KLEEN Air valve went and it wont throw a code. or some people block the system but leave the valve connected to the harness.
I'll get this thread moved to the How Too section.
EvilTwin is offline
03 636 block off plates ca model
04 zx6r vacuum block off
2013 zx6r charcoal canister delete
2013 zx6r evaporative canister diagram
2013 zx6r smog removal
2014 zx6r block off plates
2014 zx6r evap cannister
evaporative canister 2013 zx6r
Exhaust Removal 2013 636 ZX6R IvyLeague Mechanical and Technical 8 09-16-2014 01:44 PM
Re: smog block off plates sparkybp Mechanical and Technical 27 05-08-2014 07:22 AM
Bazzaz zfi + quickshift for 2013 zx6r jigy The ZX6R 14 04-05-2014 05:29 AM
HTML code is On
