The "Zip-Tie Mod"
This is a discussion on The "Zip-Tie Mod" within the Guides forums, part of the ZX6R Forum category; I seen this once before and thought I’d try it…. and got immediate results. Have you ever wanted “full throttle” with less twist? I know ...
Old 04-21-2007, 06:33 PM   #1
raized1199's Avatar
The "Zip-Tie Mod"
I know there is stuff out there, but, I’m cheap!
Here we go.
THE “ZIP-TIE MOD”
What you need:
Cut a thick zip-tie about 3 inches long.
I smoothed down both ends on the “ribbed” side.
Take apart your throttle housing and unhook your cables.
Super glue an end of the zip-tie to your throttle tube where the cables ride.
Then do the same for the other end.
(I scuffed up the smooth side a bit for better adhesion)
Replace your throttle cable ends back into their places.
Close up the throttle housing making sure there is no binding of anything.
Enjoy!
(While you are there, go ahead and lube your cables)
When I took my bike out to test this…WOW!
Like I said, the response is immediate!
Have Fun.
raized1199 is offline
2001 zx6r throttle
2010 zx6r throttle zip tie
2011 zx6r zip tie mod
99 ninja zx6r throttle cables help
ezip twist throttle mod
throattle mod zx6r
throttle cable zip tie guides
throttle zip-tie mod
what is the zip tie mod
what is the zip tie mod zx6r
zip tie mod
zip tie mod motorcycle throttle
zip tie mod zx6r
zip tie motorcycle throttle
zip tie throttle mod
ziptie mod zx6r
zx6 zip tie mod
zx6r throttle zip
zx6r zip tie mod
zx6r zip tir mod
zip tie mod pooley The ZX6R 22 04-23-2012 10:56 PM
zip tie mod arron Mechanical and Technical 11 08-07-2011 07:03 AM
how do you tie up your helmet? mcastro831 The ZX6R 67 07-22-2011 09:35 AM
