manual cam chain tensioner - Page 3 - ZX6R Forum
post #31 of 98 Old 03-23-2011, 12:55 PM
I Ride: 03 636
sportryder: how long did it take you to install? i finally got mine today!! LOL
pogiboy509 is offline
post #32 of 98 Old 03-23-2011, 02:00 PM
zx racer's Avatar
I Ride: 04 ZX-636
i installed one on my 04 636 and it only took me like a hr to install and adjust. just make sure you use your factory oring off your old cct and use it on the new ape manual adjuster.
zx racer is offline
post #33 of 98 Old 03-23-2011, 02:10 PM
I Ride: 03 636
sounds good!! tnx
post #34 of 98 Old 03-23-2011, 02:14 PM
zx racer's Avatar
I Ride: 04 ZX-636
sounds good!! tnx
no problem
zx racer is offline
post #35 of 98 Old 03-23-2011, 03:25 PM
09ZX-6R's Avatar
I Ride: 2010 ZX-6R
Originally Posted by ZoomSplat View Post
So you CAN adjust it without pulling the air box and throttle bodies, correct?
And yes 'twin, they come in fancy colors. I'm thinking "horespower pink" for mine
its not pink! its lightish red!
09ZX-6R is offline
post #36 of 98 Old 03-23-2011, 06:00 PM
arron's Avatar
I Ride: 1998 zx6r, 1999 sv650
Waiting on mine to turn up and does the bike have to be warmed up then the new ape cct changed or is it better to do it when the bike is cold?
still lovin forever!
arron is offline
post #37 of 98 Old 03-24-2011, 08:41 PM
arron's Avatar
My ape cct turned up today and just a quick question.......
Does the bike need to be warmed up or cold?
arron is offline
post #38 of 98 Old 03-25-2011, 01:22 PM
KYD
KYD's Avatar
I Ride: 00 ZX6R, 05 636, 08 WR250X, 06 GSXR600 (current)
I got one on my 636, sorta of a bitch to change, but not to bad. tooke me about 30-45 mins to do.
Id do it when my bike is cold. dont think itd be such a good idea to be reaching into the engine area after running it. temps might be a lil hot n you could burn yur fingers/knuckles fumbling around in there.
KYD is offline
post #39 of 98 Old 03-26-2011, 03:52 PM
I Ride: 03 636
to brantc: since u have an 03, how did you install urs? when u took off ur gas tank, does that mean u unplugged all the fuel lines? my fckin hand s wont even ft in there to get to the damn tensioner!!! need help!LOL
post #40 of 98 Old 04-01-2011, 03:34 PM
pegleg's Avatar
I Ride: ZX6R and a few more
Definately do this with the engine cold.
pegleg is offline
post #41 of 98 Old 04-06-2011, 02:53 PM
oldninjadude's Avatar
I Ride: 2007 ZZR/ZX6R
arron, How did your install go? I'm about to order an APE for my bike.
Did you have to remove the carbs? In sure Ill need to remove the tank & air box.
Just not sure about the carbs.??
Also has anyone else done this on a J model?
read only one page"
oldninjadude is offline
post #42 of 98 Old 04-06-2011, 06:15 PM
arron's Avatar
No I didn't have to take the carbs off.. I used a socket with a uni/bendy bit andnall was good.. Sounds heaps better.. I got a black ape cct cos I didn't mind what color cos you can see it. Yer just tank and airbox is all I took off..
arron is offline
post #43 of 98 Old 04-06-2011, 08:40 PM
Great, thanks. Iv got one ordered. Should be here next week.
read only one page"
post #44 of 98 Old 04-06-2011, 09:04 PM
arron's Avatar
Sweet, let me know how you go with it and what color?
arron is offline
post #45 of 98 Old 04-06-2011, 09:20 PM
I'm getting it from APE, the one they show for my bike is black.
I saw lots of blue ones for other models.
read only one page"
how to install a Manual Cam Chain Tensioner zx6r 07 jstunna The ZX6R 13 03-29-2016 09:23 AM
cam chain tensioner for a 04 kawi 636 zx racer The ZX6R 24 05-10-2013 12:46 PM
Can a 95 zx6r cam chain tensioner be used for 98-02 zx6r? idriftnaked Mechanical and Technical 0 05-20-2011 01:44 AM
03-636 cam chain tensioner, can i manually adjust gaillarry The ZX6R 1 07-29-2009 08:20 PM
