How To Pull FI CodesThis is a discussion on How To Pull FI Codes within the Mechanical and Technical forums, part of the ZX6R Forum category; Originally Posted by 09ZX-6R
this does not work with the 07 and up models. we have a dieagnostic plug. it has 4 wires. i know ...  |
09-29-2011, 04:04 PM
#16 | | MotoGP Champion
Joined: Oct 2008 From: Walnut, Ca Posts: 2,646 I Ride: 07 ZX-6R street, 03 636 track | Quote:
Originally Posted by 09ZX-6R this does not work with the 07 and up models. we have a dieagnostic plug. it has 4 wires. i know one is ground but the wires arent discussed in the manual. also, the maual says the old/historical service codes that occure are not able to be erased, once corrected the code will clear. it doesnt say if it will even be stored. just says they will clear. any thoughts? EVIL? my MMI buddy. | The diag wire that I ground to the negative battery comes out of a connector that plugs into the 4 pin diag connector. I was under the impression that all the bikes came with the that plug already installed. I'm at work right now so I'll check into this matter when I get home, I've got an 07 so should be easy to figure out.
As for the code storage that's where dealer 1 and dealer 2 modes come it. dealer 1 wont show past codes where dealer 2 will. I know this is the same all the way up through the 09 bikes we had when I was in school, and I don't see why they would change anytime soon.
09-29-2011, 07:17 PM
#17 | | Pro Racer
Joined: Oct 2009 From: Orlando Florida Posts: 779 I Ride: 2010 ZX-6R |
see all the more reason for me to go to the school! good thing i enrolled.
10-18-2011, 04:13 PM
#18 | | Squid
Joined: Oct 2011 From: atlanta Posts: 2 I Ride: 2004 ZX 636 |
I was wondering if you had a service manual for a 2004 zx 636 california exhast.
11-30-2011, 07:02 PM
#19 | | Squid
Joined: Nov 2011 From: Bayarea, CA Posts: 13 I Ride: 2005 ZX636 |
damn bro. thanks my stupid light went on today -_- argh
12-02-2011, 07:03 PM
#20 | | Team Green
Joined: Nov 2011 From: Tempe Arizona Posts: 138 I Ride: 04 ZX6RR |
Didn't even know it but it was your article from last year that tought me how to read the error codes thanks again.
12-04-2011, 06:22 PM
#21 | | MotoGP Champion
Joined: Nov 2008 From: Gilroy, CA, USA Posts: 2,583 I Ride: motorcycles |
Wash your hands you filthy animal.
12-04-2011, 07:12 PM
#22 | | MotoGP Champion
My bike isn't exactly clean, it gets used...alot.
12-04-2011, 11:48 PM
#23 | | World Superbike Champion
Joined: Mar 2011 From: Greenbelt, Maryland Posts: 2,380 I Ride: 09 ME ZX6R | Quote:
Originally Posted by ZoomSplat Wash your hands you filthy animal. | The movie "Home Alone"
02-19-2012, 10:03 AM
#24 | | Team Green
Joined: Sep 2011 From: Duanesburg, NY. Palm Bay, FL (Stationed in Germany) Posts: 217 I Ride: 2011 ZX-6R | Quote:
Originally Posted by 09ZX-6R this does not work with the 07 and up models. we have a dieagnostic plug. it has 4 wires. i know one is ground but the wires arent discussed in the manual. also, the maual says the old/historical service codes that occure are not able to be erased, once corrected the code will clear. it doesnt say if it will even be stored. just says they will clear. any thoughts? EVIL? my MMI buddy. | where can we get this code reader?
02-19-2012, 10:52 AM
#25 | | Pro Racer
Joined: Oct 2009 From: Orlando Florida Posts: 779 I Ride: 2010 ZX-6R | Quote:
Originally Posted by Dcook0 where can we get this code reader? | for your 2011, you dont need one. simply turn on the ignition switch to power up the guage cluster, set the mode to ODO, then hold the mode button for 5 seconds. the code will appear on the cluster.
same for 09 and up.
02-19-2012, 01:48 PM
#26 | | Team Green
Originally Posted by 09ZX-6R for your 2011, you dont need one. simply turn on the ignition switch to power up the guage cluster, set the mode to ODO, then hold the mode button for 5 seconds. the code will appear on the cluster.
same for 09 and up. | Thanks!!!
02-19-2012, 03:46 PM
#27 | | Pro Racer
no prob
| | | Search tags for this page | | 06 636 fi light code sequence, 08 zx6r easy pull clutch, 08 zx6r how to pull fi code, 2008 zx6r fi codes, 2011 zx6r trouble codes, 636 diagnosis codes, cant get self diagnosis mode on zx6r, code reading on kawasaki 636, codes on 04 zx6r 636, fi code on kawasaki 636, fi codes on kawasaki 636, how to pull fi codes zx6r forum, how to read fi codes on a zx6r, kawasaki 636 service code 11 and 14, kawasaki codes, kawasaki dealer mode, kawasaki fi code, kawasaki fi code 63, pull codes on a 650r, zx6r 07 code 23
