Need Help, 03 ZX6rr rev limiter
This is a discussion on Need Help, 03 ZX6rr rev limiter within the Mechanical and Technical forums, part of the ZX6R Forum category; I am trying to figure out what controls the rev limit on a 2003 Zx6rr? Its kind of a long story but here is my ...
Old 03-18-2011, 09:31 PM   #1
Its kind of a long story but here is my problem as short as I can put it:
I have a 03 Zx6rr (600). I have had it for about 3 years now, got it from a friend used, it is my first bike. A while back I noticed it was hitting the rev limiter at 14,500, never really paid it much attention at first. So I started researching and found out that the 636 redlines at about 14,500 but the 600 is suppose to be higher. So I talked to the guy I got it from to start and found out that it is a 600 motor but it may have some 636 parts on it also. So I started going through the whole bike. Changed the computer, injectors, and bought a power commander. Now when im riding it still redlines at 14,500 except every once in a while it will go to 16,000 and feel stronger than ever for a minute or so. So now I am really just trying to figure out what else could be causing this and what other parts are different between a 636 and 600?
Thanks for any help!!
REDBULLZX6RR is offline
Old 03-19-2011, 12:05 AM   #2
bradlee08's Avatar
I Ride: 2004 kawasaki zx-6r
Um, did the guy put a limit on it? Cuz my 636 revs up at 16 so idk what he told you?
bradlee08 is offline
Old 03-19-2011, 10:14 AM   #3
The newer 636's do rev higher. The 2003 models only rev to 14,500.
Old 03-19-2011, 11:20 AM   #4
BlueBike's Avatar
03/04 Are the same. ZX6RR has the 600 engine and ZX6R has the 636 engine
BlueBike is offline
Old 03-20-2011, 02:15 PM   #5
Traines898's Avatar
I Ride: 95 zx6e, 04 zx6r 636 :D
Actually its 15,500
Traines898 is offline
Old 03-20-2011, 02:39 PM   #6
Steve636's Avatar
I Ride: ZX6R B1H, 02 R6 Trackbike, 09 Superstock R6
yeah i have a 2003 636 and mine redlines at 15,500 , the rev limiter is controlled by the ecu and if you have changed it i don't know what else would cause it as it is an electronic limiter and if anything else was at fault it would flash up an FI code and probably wouldn't rev as high. I don't want to insult your intelligence but is it physically on the counter not hitting 15500 or is it when orange light starts flashing ?
Steve636 is offline
Old 03-20-2011, 05:11 PM   #7
Traines898's Avatar
Ive already blown one motor, You wont catch me near the redline lol.
04 zx6rr front calipers and 05 zx6rr front brake lines Steel Classifieds 0 02-13-2012 10:59 AM
ZX636R B1 won't rev over 9000rpm gazza4545 The ZX6R 13 12-20-2011 03:47 AM
zx6r or zx6rr Kazoo6942 The ZX6R 14 12-03-2011 07:51 PM
Rev limiter?? corey2pac6 Mechanical and Technical 28 04-23-2011 08:21 PM
pre mature rev limiter? bartc150 The ZX6R 13 10-28-2009 12:18 AM
