Problem finding gears?
This is a discussion on Problem finding gears? within the Mechanical and Technical forums, part of the ZX6R Forum category; I just recently got a 2000 zx6r with 30k miles. I went out for a ride and a couple times when shifting into 4th gear ...
Old 04-19-2011, 11:02 AM   #1
Nelmsy's Avatar
I Ride: 2000 zx6r
I just recently got a 2000 zx6r with 30k miles. I went out for a ride and a couple times when shifting into 4th gear it seemed to go neutral. Like the rpms just shot done, let out clutch and bike was not in gear. So I clicked up again and it went into 4th. It happend to me a couple times so i was just wondering if it was possible that I am not shifting hard enough or if something is wrong with my bike?!
Nelmsy is offline
Old 04-19-2011, 11:08 AM   #2
oldninjadude's Avatar
I Ride: 2007 ZZR/ZX6R
Could be a shift fork in the transmission,
You could try adjusting the lever, to get better leverage with your toe.
Try adjusting it down just a bit.
oldninjadude is offline
Old 04-19-2011, 11:19 AM   #3
Nelmsy's Avatar
I Ride: 2000 zx6r
thanks for the quick reply ond, I will definitely try adjusting the lever this weekend. Or whenever it decides to stop raining
Nelmsy is offline
Old 04-19-2011, 01:05 PM   #4
rattyzx6's Avatar
I Ride: zx6 09, B1h, tdr250
check your chain tension as well.
rattyzx6 is online now
Old 04-19-2011, 01:36 PM   #5
Nelmsy's Avatar
I Ride: 2000 zx6r
chain tension seems to be fine. It has between 1 and 1.5 inch slack.
Nelmsy is offline
Old 04-19-2011, 02:14 PM   #6
rattyzx6's Avatar
how slack is it when you are sat on the bike. Don't take this the wrong way but with 1"-1.5" of slack that may not be enough if you are a heavyweight.
i generally set my chain slack so that it is nearly touching the guard under the swing arm. then when i sit on it i know it won't be too tight.
Old 04-19-2011, 02:19 PM   #7
Nelmsy's Avatar
I Ride: 2000 zx6r
haha I only weigh 155 lbs. so i dont think it should make much difference
Nelmsy is offline
Old 04-19-2011, 03:33 PM   #8
wiffy's Avatar
I Ride: b2h 636
undo bolt and take gear linkage off spline then move linkage as u would with ur foot see if its stiff if so lube it up that could be prob sorted.
wiffy is offline
Old 04-19-2011, 05:45 PM   #9
Atuz636's Avatar
I Ride: 2003 zx6r 636
if tightening the chain doesn't seem to fix it, you could have a false neutral.
Atuz636 is offline
Old 04-19-2011, 09:34 PM   #10
^ lol that's exactly what it is. But whats causing it is the ??.
Bad shift fork, linkage or a too tight chain.??
Find the tightest spot on the chain check it just behind the side stand,
Lift up on it, does it touch the swingarm?
If not, Adjust it so it does.
Old 04-20-2011, 01:31 AM   #11
kone35's Avatar
I Ride: 2001 j2
Good info given to ya already.
May wanna check your oil too.
kone35 is offline
What is the problem? (or where?) PowerG Mechanical and Technical 0 07-31-2011 07:04 AM
Gas Ventilation Problem!! Help jdthieme The ZX6R 2 06-29-2009 08:51 PM
Gas Venting problem....kream coating? Brichard The ZX6R 13 05-28-2009 09:22 PM
2000 J1 6r running problem.... alburger The ZX6R 8 03-10-2009 03:35 PM
hard shifting to gears whats the problem? jcrouc03 The ZX6R 41 03-02-2009 01:26 PM
