Parts compatibility list ! - Page 2 - ZX6R Forum
 26Likes
post #16 of 157 Old 09-30-2012, 10:41 PM
Andrew727's Avatar
I Ride: 2004 zx6r
Anyone know if an ignition switch from an 05 636 will fit onto my 04 636? I am about to buy one from a guy for $65 (with key). He says all you have to do is pull and switch the pins. And that hes done it from an 07 to an 02. I don't know if he is just selling me but I'm kind of in an urgent situation.
Thanks for any advice.
Andrew727 is offline
post #17 of 157 Old 09-30-2012, 10:56 PM
rickjames692's Avatar
I Ride: 07 zx6r
Nice list. This will help a lot.
rickjames692 is offline
post #18 of 157 Old 09-30-2012, 10:56 PM
Andrew727's Avatar
I Ride: 2004 zx6r
I just checked on that link provided by Stiggy. Also looked at the other oem parts sites. The part number is the same for the ignition switch. #27005. This is making me thing it should be as simple as plug in and bolt up. Ill post pics and let you guys know how it goes I am gonna pick up the ignition and key for 65$ tomorrow.
Thanks.
post #19 of 157 Old 11-07-2012, 11:41 PM
Apollo 39's Avatar
I Ride: 2003 ZX6R /// 2009 HD Iron bobber
This is why I love this site... period
Apollo 39 is offline
post #20 of 157 Old 11-08-2012, 04:44 AM
LarryJ's Avatar
I Ride: '06 ZZR fighter, '05 VTX 1300
Probably too late but the 05 636 ignition won't simply plug in and bolt up on an 04. The ignition where it goes through the hole on the triple tree is bigger on the 05 than it is on the 04 and older. The orientation of the switch itself and the handlebar lock will also be different. I put an 05/06 636 ignition on my ZZR600 when I did my fork swap and it took a few hours of grinding and filing to get the ignition plunger to engage the frame on my bike. Definitely not a direct swap.
Also people need to realize that the part numbers you see are general numbers. For example 1234 could mean "swing arm", and 1234 will be listed for other models as well to represent a swing arm, but it doesn't mean they are the same part. I hope this helps someone from ordering the wrong part by mistake.
LarryJ is offline
post #21 of 157 Old 11-10-2012, 10:29 AM
I Ride: 08 zx6r
So let me get this straight! Does an r6 tail swap right into my 08 zx6r? If so what year of r6 and from 1 to 10 how hard is it or did i just read wrong?
ThX
2008 green zx6r
Whooping 23xxx miles and still running strong
Paco is offline
post #22 of 157 Old 11-10-2012, 09:37 PM
LarryJ's Avatar
ThX
No, not even close. Besides, your tail is nicer than the R6 tails anyways. The R6 subframes bolt down similarly to the J and G model subframes, you just need to make a small bracket on each side to reach the bottom mount to the frame.
I think it would be more trouble than it's worth.
LarryJ is offline
post #23 of 157 Old 11-11-2012, 12:37 AM
Apollo 39's Avatar
Ok so question I have an 04 636B can I use the top triple tree clamp from an 05, I already have an ignition I just want to bolt the old ignition from the 04 into the 05 clamp... possible??
post #24 of 157 Old 11-11-2012, 01:20 AM
arron's Avatar
I Ride: 1998 zx6r, 1999 sv650
The 08 swing arm will work with the stock 98 chain and also you can use the stock wheels with the right spacers machined up or cut down..
still lovin forever!
arron is offline
post #25 of 157 Old 11-12-2012, 09:45 PM
LarryJ's Avatar
Yes the 05-08 top tree will bolt up. Your ignition bolt holes line up with the newer tree, but your steering lock likely won't work without some extra work.
Just for additional information, the ignition mount on the 07/08 tree is longer than the 05/06, which means you'll need to remove some material to get the ignition to sit the same in the 07/08 tree. Also the 03-05 top tree ignitions are mounted offset where as the 07/08 are mounted in the center, so swapping from one to the other likely will make so you can't use your steering lock without drilling a new hole in the frame for the pin to insert. I'd just drill a new hole in the thick area where you'll find the original hole. It's a pain in the ass, but it's up to you i you care about a steerin lock. My fighter has been without one for a few years.
LarryJ is offline
post #26 of 157 Old 11-16-2012, 09:30 PM
Apollo 39's Avatar
Thanks for the feed back, I was having a hard time finding one for my bike my search was getting desperate... One turned up on Ebay I snatched it up same day ha
post #27 of 157 Old 02-07-2013, 08:02 AM
I Ride: 05 636
awesome. Thanks!
zx636in805 is offline
post #28 of 157 Old 04-23-2013, 07:52 AM
woz
I Ride: zx6r c1h & street triple
Just to expand on these, as Im investigating a swap at the moment.
zx6r:
03-12 front rotors are the same, and are a direct swap.
- 03/04 gold centres, not wavy/petal type, but direct swap - mistaken - see below
- 05/06 ones are gold centers, 5.5mm thick
- 07-12 ones are black centers, 6mm thick. Also used on the 07/08 z1000
- 13-?? ones are 310mm diameter, so no longer a direct swap
zx10r:
still investigating these, but the 08 onwards discs are 310mm, so are not a direct swap..? bolt holes are the same however
woz is offline
post #29 of 157 Old 04-23-2013, 10:57 AM
Kevin2109's Avatar
I Ride: 2006 ZX636r
Originally Posted by woz View Post
zx6r:
zx6r:
NO, do not put 03-04 rotors on your 05+, they are smaller in diamater (290mm vs. 300mm if im not mistaken)
zx6r:
zx10r:
You can install larger rotors you will need spacers for your caliper, as long as the bolt pattern line up
beckzach05 likes this.
September 2012 6OTM Winner!
Honda has 1 or 2 good points. Everything does. Including Herpes. Herpes has it's own herpes infected only dating site. Is this a reason to catch herpes? FUCK no.
<-----My Youtube----->
Kevin2109 is offline
post #30 of 157 Old 04-25-2013, 02:01 PM
I Ride: Black '07 ZX-6R
Would the 600p8f engine swap into an older 600p7f frame without any trouble? I know they should but am trying to be 100% sure since I've had my engine ruined and found an 08 replacement...
Thanks
markgrech79 is offline
  LinkBacks (?)
LinkBack to this Thread: http://zx6r.com/mechanical-technical/15021-parts-compatibility-list.html
Posted By For Type Date
ZX6R models - parts compatibility - Bike Chat Forums This thread Refback 06-20-2014 09:45 PM
WTB parts list CSUFSAE Classifieds 0 03-15-2012 12:48 PM
parts list zx6chris The ZX6R 4 11-06-2011 02:42 PM
List of aftermarket parts for 2011 ZX6R xironworker Mechanical and Technical 6 06-03-2011 09:23 PM
07 Parts Compatibility.... CamZx The ZX6R 4 12-28-2009 03:08 PM
G & J Model Parts Compatibility Question Buster The ZX6R 3 03-01-2009 01:48 AM
