Parts compatibility list ! - Page 4 - ZX6R Forum
 26Likes
post #46 of 152 Old 12-09-2013, 10:58 PM
4htrs's Avatar
The front and rear seat on a 2004 zx6r, will anything else fit it?
4htrs is offline
post #47 of 152 Old 12-09-2013, 11:10 PM
NEPAzx6r's Avatar
I Ride: 2005 ZX6R
Seats are pretty specific. Probably just stick between 03-04
4htrs likes this.
Originally Posted by zninja View Post
All I wanted to do was get away and Mariah Carey made me beat up a child.
Originally Posted by Street Hawk View Post
I think my girlfriend is a squid because she rides me real hard with no gear on.
Originally Posted by beckzach05 View Post
Spark plugs don't lie, they don't hide shit from you, they lay it all out there like a geisha girl with sushi on her bits.
NEPAzx6r is offline
post #48 of 152 Old 12-09-2013, 11:47 PM
4htrs's Avatar
Will do. Thanks!
4htrs is offline
post #49 of 152 Old 12-11-2013, 04:32 AM
4htrs's Avatar
Will any other exhaust (headers or slip ons) fit a 2004 zx6r or are they pretty specific too?
4htrs is offline
post #50 of 152 Old 12-11-2013, 10:40 AM
NEPAzx6r's Avatar
I Ride: 2005 ZX6R
With the right set of skills and a welder and a good fuel controller and tune afterwards you can make just about anything work really. Without any work? Pretty sure they're limited. I know people put 03-04 headers on J's but I don't think you'd want older stuff on your bike
NEPAzx6r is offline
post #51 of 152 Old 12-27-2013, 08:32 PM
mfromphilly1's Avatar
I Ride: 99 ZX6R
From what I'm seeing in the swap list a ZX12 front for assembly will bolt on to a J model with no mods, am I right? Will it need the 12 wheel or can the J wheel be used with it's spacers? Thanks
99 ZX6R Gianelli pipe, Penske shock, Hyperpro springs, Ivan's jet kit, Ontario ignition advancer, GPR damper, Vortex rearsets, TRS projector light, Hel brake lines
mfromphilly1 is offline
post #52 of 152 Old 01-02-2014, 10:38 PM
I am planning to do this swap on a Versys so the triple trees are not an issue. Either bore the lower if using ZX10 or leave as is with the ZX6R
I will lower the rear to compensate for the shorter fork, and my short legs, yielding ER6 geometry
Understood about the 04-05 ZX10 forks c/w axle and the direct fit with the wheel and rotors. I also understand if using the 05 - 08 ZX6R fork c/w axle one needs to machine the wheel to fit the 25mm axle
How to handle the lack of ABS on all these forks
Aside from the ABS problem it is easy so far
Now lets throw the ZX6R big piston +09 forks into the mix. 51mm top and 53mm bottom means boring my existing Versys trees 1mm and 3mm respectively. Do I have the fork size correct?
Is this still a 25mm axle - I am fine with machining the wheel as required
I do not see provision for the ABS sensor on the ZX6R until 2013
the 2013 also has 310mm rotors - will these fit my Versys/ER6 wheels
Are all the BP - ABS forks the same 51 x 53mm yokes
I think that the zx10 is 43mm tubes and the zx6R is 41mm
The ZX10 has had BP ABS forks since 2011 but the same 310mm brake issues
Hoghead is offline
post #53 of 152 Old 01-12-2014, 04:54 PM
GinjaZX600R's Avatar
I Ride: '00 ZX600j, '07 S3, '97 El Tigre
Great thread! Bookmarked for future reference!
Urmum
GinjaZX600R is offline
post #54 of 152 Old 01-20-2014, 09:49 PM
DoeMai619's Avatar
I Ride: Magma Red 2005 ZX6R 636
Anyone know if an 08 zx6r mid pipe will fit an 05 zx6r?
DoeMai619 is offline
post #55 of 152 Old 01-20-2014, 10:23 PM
Kozaru's Avatar
I Ride: 2009 ZX6R
2008 is part number 49062-0033
...and 2005 is part number 49062-0027.
I can't tell from the diagrams above what the differences are. They look similar, but who's to say without a scale drawing or placing them side by side.
Kozaru is offline
post #56 of 152 Old 01-21-2014, 08:39 AM
NEPAzx6r's Avatar
I Ride: 2005 ZX6R
I Imagine if the same website lists them as different parts, then they aren't compatible without any custom work
NEPAzx6r is offline
post #57 of 152 Old 01-21-2014, 10:00 AM
Z1000 Top tree compatibility
In their quest for dirt bars, has anyone tried the Z1000 top tree onto 05-06 ZX6R forks and wheel assembly?
On a few forums they say they will work, on others they say no. Does anyone here have experience with that?
I am running a stock 06 ZX6R front end. If i can source a 03-07 Z1000 top tree, can they be bolted onto a ZX6R front end?
thirstforspd is offline
post #58 of 152 Old 01-21-2014, 10:12 AM
NEPAzx6r's Avatar
I Ride: 2005 ZX6R
Why not just get risers for your zx6r top triple? I have risers drilled into my top triple on my 01 and plenty of stunters have them on their 636's
NEPAzx6r is offline
post #59 of 152 Old 01-21-2014, 10:21 AM
I am going to build another bike like this, but with dirt bars.
Instagram
I want an OEM look to the bars and such. if I cant do that, i will just machine a top triple myself that can accomodate risers. I'm not a huge fan of adapting risers to the ZX6R trees.
I will investigate a small production run of billet top trees as well if I cannot find a suitable alternative, but i want to rule out the Z1000 top tree route first.
post #60 of 152 Old 01-27-2014, 08:09 PM
I Ride: 09 ZX6R
Has anyone ever done or heard of someone putting a 03-04 swingarm on an 09 zx6r? I hate the 09 swingarm and don't care for the thick curved swingarms. I prefer the straight swingarm looks. any help would be appreciated!
Blugoose00 is offline
00 zx6r swingarm compatibility
2012 compatible parts list
bridge years for 99 kawasaki zx6e
can you use other bike model parts on a zzr600?
does a kawasaki ninja zx6r and azx6e interchange fairing parts
what model zx6r is compatible with a zx9r e1
will a zx6r 2003 tank fit a 2001
zx6e shock sagawap
zx6r parts compatabilty list
zx6r parts compatibility
zx9r compatible parts
zx9r rearset compatibility
  LinkBacks (?)
LinkBack to this Thread: http://zx6r.com/mechanical-technical/15021-parts-compatibility-list.html
Posted By For Type Date
ZX6R models - parts compatibility - Bike Chat Forums This thread Refback 06-20-2014 10:45 PM
WTB parts list CSUFSAE Classifieds 0 03-15-2012 01:48 PM
parts list zx6chris The ZX6R 4 11-06-2011 03:42 PM
List of aftermarket parts for 2011 ZX6R xironworker Mechanical and Technical 6 06-03-2011 10:23 PM
07 Parts Compatibility.... CamZx The ZX6R 4 12-28-2009 04:08 PM
G & J Model Parts Compatibility Question Buster The ZX6R 3 03-01-2009 02:48 AM
