water pump leak from cover even after new gasket fitted - ZX6R Forum
post #1 of 4 Old 06-09-2011, 09:34 AM Thread Starter
hi there i got a 96 f model with a drip coming from waterpump cover. i replaced the cover gasket today only to find its still leaking. i put a smear of grease on the cover itself just to help the gasket stay in its groove . all surfaces were nice and clean with no pitting or scratching. now heres the problem. i just recently did an oil and filter service, new plugs etc etc and noticed a waterpump cover leak. so i ordered 2 waterpump gaskets and went to fit them today not knowing that the oil needs to be drained in order to remove the water pump to replace the inner gasket.i only found out today that the waterpump and oil pump are connected together and only thing seperating oil from water is a o-ring seal.is this correct ? and if so i cant understand why i have a leak coming from the cover but dont have oil and water mixing i.e no mayonnaise.is there perhaps a 3rd gasket seal on the pump itself now as i know my clutch is gonna need replacing soon, occasional slip between 10-14000rpm another oil change required.i would like to fix the 2 problems together i read on a zzr forum that the water pump should be replaced if water leaks from weaphole mines is leaking from the part on the cover that you use a screwdriver to prise the cover off and noticed there is a hole here. is this classed as the weep hole can anyone shed some light on this and hopefully save me from draining oil multiple times. i just want to get it all done at the same time.and is there any chance that the inner gasket will stop the leak.or is it like the zzr forum says new pump? really appreciate some help here.
craibzer is offline
post #2 of 4 Old 06-13-2011, 02:27 AM Thread Starter
Re
took out water/oil pump yesterday and removed shaft mechanical seal. looked fine, but theres a tiny o-ring at the impellar end of the shaft covered in shit. allso shaft itsellf was built up with crap, allso gave that a lite sand and clean, stuck it all back expecting it to leak. but its now allot better but im gonna wait and see how long it lasts. i think the shaft could cause a future leak as it was pitted so gonna wait and see.
craibzer is offline
post #3 of 4 Old 10-12-2014, 11:04 AM
does the coolant and/or oil run out when u remove the pump?
tevinrpj is offline
post #4 of 4 Old 10-12-2014, 11:08 AM
Crashz28's Avatar
Can you get a video of where the cover is leaking from.
Not sure if its on that bike or not but some had weap holes on the covers and if its coming from the weap hole the water pump wil need to be repllaced
Crashz28 is offline
99 kawasaki zx6r water pump
gpz 500s waterpump leaking after new mechanical seal
kawasaki waterleaks
kawasaki zx6r leaking water pump
zx6r oil pump leak
zx6r water pump cover o-ring grease
Valve Cover Gasket Recurring Fail '05 636 Gn6hami The ZX6R 12 06-15-2012 10:24 AM
Valve Cover Gasket Service Bulliten TheEvilTwin Mechanical and Technical 19 02-13-2012 11:30 AM
Chain cover leak? TheObsession Mechanical and Technical 29 05-03-2011 11:31 PM
Mystery coolant leak? Gary P The ZX6R 18 11-07-2009 12:16 PM
