k&n air filter + two bros slip-on = ......power commander?
This is a discussion on k&n air filter + two bros slip-on = ......power commander? within the Mechanical and Technical forums, part of the ZX6R Forum category; hey all, new to the forum. i ride an 08 zx6r, and have a question for you guys. i installed a two bros slip on ...
Old 06-13-2011, 03:29 PM   #1
djnerek's Avatar
I Ride: 08 kawi green zx6r
hey all, new to the forum. i ride an 08 zx6r, and have a question for you guys. i installed a two bros slip on last year, with no problems. however, just today, i installed a k & n filter. i thought nothing of it, but two friends (who do not own zx6rs, btw) warned that i might need to purchase a power commander, because the bike might run too lean in high rpms. is anyone running these two upgrades without a power commander? any issues? do i need to get one? any info would be greatly appreciated, thanks
djnerek is offline
Old 06-13-2011, 03:46 PM   #2
OMalley912's Avatar
I Ride: 05 ZX6R 636, 06 KX250F, pocket bike 50
Welcome, been popular belief that you only need a PC for a full exhaust. If you are worried about it maybe a custom tune at a reputable bike shop. Up to you....someone will be along shorty with the same mods with the're .02
OMalley912 is offline
Old 06-13-2011, 04:14 PM   #3
zx racer's Avatar
I Ride: 04 ZX-636
you shouldnt need a pc with your mods.
zx racer is offline
Old 06-13-2011, 04:35 PM   #4
djnerek's Avatar
thanks for the info guys. i talked to another friend of mine, and he said id only need one if i deleted the cat(which may be a future mod). said something along the lines of being able to tell if the bike was running lean or rich if she starts backfiring or being able to smell gas from the exhaust.
djnerek is offline
Old 06-13-2011, 04:53 PM   #5
givuhcky22's Avatar
I Ride: 2009 GREEN ZX6R
yes get a fuel management system. its not required, but will help. a slipon changes the flow. grab a JuiceBox since you have the two bros slip on
givuhcky22 is offline
Old 06-13-2011, 04:57 PM   #6
OMalley912's Avatar
you could always grab a juice box from hicky
Old 06-13-2011, 06:04 PM   #7
givuhcky22's Avatar
pfffhahahah CLEVER
Old 06-13-2011, 06:30 PM   #8
05christj's Avatar
I Ride: 2007 ZX6R
I had the same mods without a power commander and never had any popping till I got the mjs performance race header installed. Then I finally installed a generic map
05christj is offline
Old 06-13-2011, 07:35 PM   #9
reaper636's Avatar
same mods as you and no PC am thinking about the juicebox pro tho down the road
reaper636 is offline
Old 06-13-2011, 08:03 PM   #10
willard's Avatar
I Ride: 07 zx6r
his juicebox brings all the boys to the yard.
willard is offline
Old 06-13-2011, 08:08 PM   #11
givuhcky22's Avatar
whats that willard? i couldn't hear you over your avatar.
Old 06-13-2011, 08:08 PM   #12
givuhcky22's Avatar
mmm
Old 06-13-2011, 08:43 PM   #13
djnerek's Avatar
juicebox vs the power commander? is there any advantage to getting one over the other? besides from the sounds of it the juicebox is designed for the two bros system....
djnerek is offline
Old 06-13-2011, 09:29 PM   #14
givuhcky22's Avatar
http://www.twobros.com/Perf_Products...nder_chart.pdf
Old 06-13-2011, 09:32 PM   #15
givuhcky22's Avatar
juice box pro is much better than juice box IF youre a racer.
if you're looking to beat other bikes on a twisty track, go with a juice box pro.
if youre looking for a little boost on the streets and clean up a lot of the popping, grab the standard juice box.
i have the standard juice box and i love it. i can adjust the settings on the fly. no maps needed.
power commander with slip on and kn air filter
zx6r air filter looks like an k&n filter
zx6r two brothers juice box pro vs power commander
Yoshi RS5 slip on Power Commander Map Cap Walker The ZX6R 28 04-18-2012 02:19 PM
05 zx6r With yoshi Slip on Power commander Map?? Onetap Mechanical and Technical 31 06-19-2011 07:13 PM
07 with Slip on Jardin RT-1 + K&N air filter power commander maps?? leftside 6 Mechanical and Technical 3 06-18-2011 05:02 PM
K&N air filter or BMC air filter pogiboy509 Mechanical and Technical 7 03-16-2011 03:44 PM
