01 zx6r bogs at high speeds and higher rpms? - ZX6R Forum
post #1 of 12 Old 07-30-2011, 06:17 PM Thread Starter
I Ride: 2001 zx6r
I got a zx6r a few months ago. It was dropped so I made it a naked bike while I was finding parts and getting the fairings painted. It was sitting for like a year before I got it. The bike ran ok and started running better and better after riding it some more. After about 100 miles it was running normally. I just figured it was build up from sitting and stuff.
Anyways, it ran perfect. Pulled good to redline and all. I rode the bike without fairings and all the ram air stuff for a few hundred miles.
The problems started when I put it back together. To me it sounds like a mixture problem. But it only happens at higher speeds so I'm starting to think it has something to do with the ram air system.
Here are the symptoms:
- runs fine in all gears to about 45 or 50 mph.
- 1st gear can go to about 10k or maybe even redline before starting to bog
- revs are really responsive and good when the bike isn't moving or at low speeds.
- above about 40-50 mph, if I hold in the clutch and do a few quick twists on the throttle, it bogs on the 1st or second twist and then revs after that.
- at speeds above about 40mph, if i give it gas smoothly, it goes good until about 50 or 60. But if I yank it and try to accelerate very fast, it bogs and actually slows down instantly and then accelerates slowly
- it's a lot worse up hills but i guess that would be normal with a poor running engine.
- despite all the other symptoms, it revs perfectly fine when its not moving, to redline and all. doesn't bog or hesitate at all.
Nothing except the oil and filter was touched on the engine. It ran perfectly fine before I took the tank off and dropped everything off to get painted. I've checked the tank and intake system for anything that can clog it up but its all clear. I also raised the rear 2 inches back to stock(it was lowered before) but I doubt that changes things.
I think i'm gonna have to play with the mixture but I just wanted to see if what you guys thought.
Thanks for your help.
Oh and the bike has a D&D exhaust and that's it. But it was like that when I got it. Everything else is stock
dlstech is offline
post #2 of 12 Old 07-30-2011, 06:22 PM
arron's Avatar
I Ride: 1998 zx6r, 1999 sv650
If it does the same when standing I would look At the carbs.. Could be a sync prob or a mixture setting prob as well.. Have you looked at the plugs
still lovin forever!
arron is offline
post #3 of 12 Old 07-30-2011, 06:30 PM Thread Starter
I Ride: 2001 zx6r
No that's the thing, when it's standing, it revs fine and doesn't bog. just at higher speeds. and I haven't looked at the plugs yet, I can't get the outer ones out without a swivle adapter and I can't find mine right now..
dlstech is offline
post #4 of 12 Old 07-30-2011, 06:36 PM
arron's Avatar
Look at the hoses going to the carbs. The ram air tubes to pressurize the float bowls.. Could be a vacume leak as well?
arron is offline
post #5 of 12 Old 07-30-2011, 06:44 PM Thread Starter
I Ride: 2001 zx6r
Yeah that's definitely a possibility. I'm gonna start taking it apart and I'll keep updating. Thanks for your help.
dlstech is offline
post #6 of 12 Old 07-30-2011, 07:24 PM
arron's Avatar
No orob.. Let me know how it goes
arron is offline
post #7 of 12 Old 07-30-2011, 11:29 PM
kd283's Avatar
I Ride: zx6r j2, 79 rd250, 86 yz490, 89 gs 500, 94 rs125rr
my old bike reved fine on a stand still but when under load it spluttered, bogged and backfired. it was the carbs out of sync and lots of shit inside the float bowl.
Lets go slay some litre's
lets try not to crash a!
kd283 is offline
post #8 of 12 Old 07-31-2011, 10:46 AM
kone35's Avatar
I Ride: 2001 j2
You aren't using your mind properly. LOL...you CAN get the outer plugs out without a swivel adapter. Takes a little thought, but it is very much possible.
kone35 is offline
post #9 of 12 Old 07-31-2011, 10:51 AM
TXZX6R's Avatar
I Ride: 02 ZX6R
90% sure its a loose vacum hose
Originally Posted by LenaLilLower View Post
Hahahaha....there's never a wrong time to suck a cock!! +1000000
THE ONLY THING BETTER THAN MY ZX6 IS HUGE BOOBS AND TATTOOS!
Vortex front & rear sprockets -1/+5 with 520 conv.-- EK Gold Chain-- Myrtle West lowering links (2.5in drop)-- Myrtle West 6in swingarm ext.-- matte black paint-- custom blinkers-- sportech wscreen-- D&D exhaust-- nut sack hanging from under tail (for humor)
TXZX6R is offline
post #10 of 12 Old 07-31-2011, 10:55 AM
TXZX6R's Avatar
I Ride: 02 ZX6R
had the same problem with my 02... i let my bro in law put on my side blinkers.... bike startes bogging out pretty hard... when i looked over my hoses, the hose that is under the headlights was not connected to the airbox.. plugged it in and viola problem solved
TXZX6R is offline
post #11 of 12 Old 08-01-2011, 08:03 PM
nate1235's Avatar
I Ride: '99 zx6r
__________________
Yeah, try seeing if the 2 small hoses are connected to the airboxes underneath the headlights.
I think you should smurf the bullshit. 1 shot of Jim Beam, beer chaser, small line of cocaine. Repeat until you run out, die, or find the true meaning of life.
nate1235 is offline
post #12 of 12 Old 08-01-2011, 08:29 PM
arron's Avatar
have you fixed it yet?
arron is offline
