throttle position sensor?
This is a discussion on throttle position sensor? within the Mechanical and Technical forums, part of the ZX6R Forum category; i have an issue with my 2005 636. i have pc3 and slipon akra. only sometimes i'll get a massive loss of response at like ...
Old 08-07-2011, 04:25 PM   #1
TexMex's Avatar
i have an issue with my 2005 636. i have pc3 and slipon akra. only sometimes i'll get a massive loss of response at like 8000rpm. it acts like i close the throttle, when i don't, and the bike lunges me onto the tank and it's really gay :-p but yesterday i took it out and rode at 8k rpm for like 20 min. and nothing happened. so is it my sensor acting funny? could it be anything else? it normally happens in 1st, 2nd, 3rd, or 4th gear. probably because by 5th or 6th i'm not hitting 8k rpm anymore? any advice is appreciated!
TexMex is offline
Old 08-07-2011, 05:24 PM   #2
zx racer's Avatar
I Ride: 04 ZX-636
is the bike throwing any FI codes on the instrument dash ?
zx racer is offline
Old 08-07-2011, 06:04 PM   #3
KYD
KYD's Avatar
I Ride: 00 ZX6R, 05 636, 08 WR250X
pretty much if any sensor is going bad or is malfunctioning your bike will flash a FI light. If it doesnt then its most likely something mechanical. have you replaced or adjusted anything with the clutch lately? cable, lever, perch, etc?
KYD is offline
kawasaki throttle position sensors
rpm sensor 636 2005
07 zx6r Fuel ECU Sub-Throttle ?? fitter07ZX6R Mechanical and Technical 21 03-29-2012 07:16 PM
TPS Throttle Position Sesor Karl T Classifieds 0 01-25-2012 06:27 PM
Throttle Position Sensor N3WMAN Mechanical and Technical 7 12-15-2011 10:42 PM
TPS - 2007 - Throttle Position Sensor Karl T Classifieds 0 10-20-2011 06:00 PM
