cylinder head questions - ZX6R Forum
post #1 of 8 Old 09-27-2011, 11:31 AM Thread Starter
DrewC's Avatar
I just pick up a cylinder head for a kawi zx6r. How do i tell if the head is for a 03/04 or a 05/06. And would a 03/04 cylinder head work on a 05/06 bottom end.
DrewC is offline
post #2 of 8 Old 09-27-2011, 12:46 PM
greenmeeny's Avatar
The 05 06 head has better cams, better combustion chamber, bigger valves. To find out what year it is look up the part numbers on the head or cams. Sorry don't know staight off.
greenmeeny is offline
post #3 of 8 Old 09-27-2011, 02:05 PM Thread Starter
DrewC's Avatar
I cant find a number on the head and it cam with no cams in it. the only numbers i see on the head is a K2 doses that mean anything.
DrewC is offline
post #4 of 8 Old 09-27-2011, 03:04 PM
greenmeeny's Avatar
Yeah, they don't always have numbers on them. I guess you could measure the size of the valves and work out what year from that, 05-06 were bigger. Look up the sizes in the on line manuals.
post #5 of 8 Old 09-27-2011, 05:44 PM Thread Starter
DrewC's Avatar
Thats what i am going to do. Thanks
DrewC is offline
post #6 of 8 Old 09-27-2011, 07:39 PM
Super Moderator
EvilTwin's Avatar
They are interchangeable, so it won't hurt anything, you may just not get as much power. 05-06 cams have adjustable cam sprockets, 03-04s do not, so there's another clue.
EvilTwin is offline
post #7 of 8 Old 09-28-2011, 06:32 AM Thread Starter
DrewC's Avatar
the head i got has no cam. I am going to try and messure the valves to help me tell what it is. I was looking for a spare head for my 05 I would have like to sent it out to make some more power out of it. I didnt no there was so much diffrent betwwen 03 and 05. Doses anyone got any input on what I can do to my 05 for it to start making more power. I alreday took the secondary throttle flaps out. And did the euro trip "wire jump".
DrewC is offline
post #8 of 8 Old 09-28-2011, 07:30 AM
greenmeeny's Avatar
I got an 05-06 rr head for my 03 636, it has K2 stamped on it. My 03 636 head had adjustable cam sprockets. I think you're better off comparing valves so you know for sure. You could go for an 05-06 rr head with cams if you can find one, it has race cams and ports reshaped, stiffer valve springs for higher rev limit and bigger valves again. Or tune the ignition and injection, degree cams, porting, balance, blueprint etc. What you do depends on budget. Most do full exhaust system, race filter, PC 3 custom map to start with. Maybe lighten the bike to get more out of what's there, often cheaper than engine work.
head and port and polish Bensbaby Mechanical and Technical 15 01-06-2012 09:27 AM
Questions about Head Milling. Jsim4 Mechanical and Technical 4 11-08-2011 04:57 PM
head cam N2O ninja z28 The ZX6R 19 06-01-2011 09:32 PM
Questions about 05' head lights (darn previous owner!) ZX6RJosh636 The ZX6R 0 03-15-2011 04:08 PM
FS: 2003 zx6r 636 Retrofit head lights nolazx6r The ZX6R 1 07-02-2009 09:43 AM
