Lap button Garage door openerThis is a discussion on Lap button Garage door opener within the Mechanical and Technical forums, part of the ZX6R Forum category; Follow up of >>> http://zx6r.com/guides/4162-garage-d...ap-button.html <<<
Alright every since I saw this Ive been wanting to do it and think I am going to do ...  |
12-08-2011, 07:48 AM
#1 | | World Superbike Champion
Joined: Sep 2011 From: Wyoming, MI Posts: 1,922 I Ride: 09' Monster Edition ZX6r | Lap button Garage door opener
Follow up of >>> Garage Door Opener On Lap Button<<<
Alright every since I saw this Ive been wanting to do it and think I am going to do it this week. My buddy still wants to preserve his lap function so was thinking of adding a switch in a little housing that would allow to switch between using the lap button as a garage door opener and then still being able to switch back to the original use of the button
So my question is do any of you with electrical experience (more than me lol) think this switch will work. I have a selection to use from work. But this is one that i found, that I thought would work (this is a link to the part GRS-4012-0026 CW Industries Rocker Switches & Paddle Switches)
Would A go to say the opener and B to the Lap changer and then the middle be common/ground?? just curious thanks
Any help would be greatly appreciated
12-08-2011, 09:33 AM
#2 | | World Superbike Racer
Joined: Oct 2011 From: Orange County Posts: 1,217 I Ride: 2006 ZX636r |
You need a momentary switch, all your doing is activating the program written in the opener
This would be perfect http://www.radioshack.com/product/in...ductId=2062508 |
12-08-2011, 09:35 AM
#3 | | World Superbike Champion
Oh ok so I just need a push button switch? have loads of those too
I am new to the electrical world but wouldn't the rocker work the same way basically?
12-08-2011, 09:39 AM
#4 | | World Superbike Racer
Not really, unless its a momentary rocker. If not you have to switch it on then off, kinda a pain
12-08-2011, 09:49 AM
#5 | | World Superbike Champion
So this is actually the simplest push button we have here
Will this switch work do you think?
listed as MoM(N/O) cant find part number
12-08-2011, 10:08 AM
#6 | | World Superbike Champion
I guess my biggest thing is I am not sure as how to wire this up correctly depending on what I use. For now just may end up using a connector and when I want to switch it just swap which connector is plugged in.
12-08-2011, 10:18 AM
#7 | | World Superbike Champion
Well thanks for the info, ended up getting my answers I needed from an electrical engineer that I work with. So Hopefully if all works according today I may have this toggle switch installed. with functioning garage door opener but wont know if it works till spring since my bikes not stored near my garage lol
12-08-2011, 12:22 PM
#8 | | Team Green
Joined: Sep 2011 From: La Grange, NC Posts: 216 I Ride: 2007 Black ZX6R |
The lap button is a momentary switch. He wants to use the first switch to switch the lap button from it's stock function to garage door function. Yes it should work. If I wasn't in bed I would draw a diagram for you on how to it needs to be wired. Maybe later. Good idea though.
12-08-2011, 04:29 PM
#9 | | Team Green
Joined: Sep 2011 From: Hawthorne,NJ Posts: 203 I Ride: 2011 ZX6R |
sounds like the toggle switch should work. maybe you could make a video of its operation when you get it going
12-08-2011, 04:31 PM
#10 | | World Superbike Racer
Joined: Sep 2011 From: Grand Rapids, MI Posts: 1,745 I Ride: 2009 Green ZX6R |
Failed project hahahahaha 15 minutes in
12-08-2011, 04:33 PM
#11 | | Pro Racer
Joined: Jun 2011 From: Midwest Indiana Posts: 809 I Ride: 2009 black zx6r |
If you have to add a switch to make the lap button perform a different function, why not just make the added switch a momentary switch for the door opener only? Seems like you're making it more confusing than it needs to be.
12-08-2011, 04:40 PM
#12 | | World Superbike Racer
Joined: Sep 2011 From: Grand Rapids, MI Posts: 1,745 I Ride: 2009 Green ZX6R | Quote:
Originally Posted by Farmboyzx6r If you have to add a switch to make the lap button perform a different function, why not just make the added switch a momentary switch for the door opener only? Seems like you're making it more confusing than it needs to be. | Hes an electrical engineer, he gets paid to think to hard about stuff.
12-08-2011, 04:47 PM
#13 | | Pro Racer
Joined: Jun 2011 From: Midwest Indiana Posts: 809 I Ride: 2009 black zx6r | Quote:
Originally Posted by sXzx6rXa Hes an electrical engineer, he gets paid to think to hard about stuff. | LMAO, I've never seen anything designed by an engineer that couldn't be improved by a farmer!
12-08-2011, 04:50 PM
#14 | | World Superbike Racer
Originally Posted by Farmboyzx6r LMAO, I've never seen anything designed by an engineer that couldn't be improved by a farmer! | Hahaha must be an Indiana thing. The farmers around here are a bunch of idiots |
12-08-2011, 04:52 PM
#15 | | Pro Racer
Originally Posted by sXzx6rXa Hahaha must be an Indiana thing. The farmers around here are a bunch of idiots  | HaHa, it's the cold MI winters... Stunts brain function!
| | | Search tags for this page | | 2011 zx6r gargage door opener lap button
