Throttle Position Sensor
This is a discussion on Throttle Position Sensor within the Mechanical and Technical forums, part of the ZX6R Forum category; Bike is an 06 636. My TPS sensor on the right hand end of the throttle body (or is it Sub Throttle position sensor?) is ...
Old 12-13-2011, 09:20 PM   #1
N3WMAN's Avatar
Bike is an 06 636.
My TPS sensor on the right hand end of the throttle body (or is it Sub Throttle position sensor?) is literally broken into two pieces.
Is there any oem sensors that will work or am I stuck buying one from the stealership/getting a used throttle body?
I know some Honda motorcycle's use the same TPS as the Honda civic.
N3WMAN is offline
Old 12-14-2011, 07:14 AM   #2
zx racer's Avatar
I Ride: 04 ZX-636
if you need that part i got the whole throttle body and sensor for you
zx racer is offline
Old 12-14-2011, 12:37 PM   #3
ZoomSplat's Avatar
I Ride: motorcycles
why not just change the sensor? First, you need to figure out which one you need. Is it the one on the upper butterfly plates (the sub throttle sensor) or the one on the lower plates, closer to the engine (The main tps sensor). Both are available from bike bandit, at are right around $140. I know, that's a shit load of money for a tiny little sensor, but a throttle body assembly is almost $1200 new. If you buy a used sensor, you don't know what you're getting or what sort of condition its in. Never buy electronic parts used if you want them to last.
ZoomSplat is offline
Old 12-14-2011, 08:24 PM   #4
N3WMAN's Avatar
It is the one on the end of the throttle bodies, on the right hand side when sitting on the bike.
Edit: looked it up in the manual. It is the subthrottle sensor.
The reason I don't want to buy it from bikebandit is I hate spending $140 on a $5 part. Plus I dont have a huge budget to rebuild the bike with.
N3WMAN is offline
Old 12-14-2011, 08:59 PM   #5
ZoomSplat's Avatar
I Ride: motorcycles
Theres a set of throttle bodies for an 03/04 on ebay for 100 bucks.
Old 12-15-2011, 06:56 AM   #6
zx racer's Avatar
I Ride: 04 ZX-636
i have a set of 05-06 636 throttle bodies complete for 50 + shipping if intereste pm me.
zx racer is offline
Old 12-15-2011, 12:41 PM   #7
ZoomSplat's Avatar
I Ride: motorcycles
do it!
Old 12-15-2011, 10:42 PM   #8
N3WMAN's Avatar
I know you do. If I can't get it locally I will PM you.
N3WMAN is offline
07 zx6r Fuel ECU Sub-Throttle ?? fitter07ZX6R Mechanical and Technical 21 03-29-2012 07:16 PM
TPS Throttle Position Sesor Karl T Classifieds 0 01-25-2012 06:27 PM
TPS - 2007 - Throttle Position Sensor Karl T Classifieds 0 10-20-2011 06:00 PM
throttle position sensor? TexMex Mechanical and Technical 4 08-07-2011 08:55 PM
