Compatibility
This is a discussion on Compatibility within the Mechanical and Technical forums, part of the ZX6R Forum category; Anybody know if the 2008 ZX6R left rear set (shiftpedal & peg) is compatible with the 2009 ZX6R? Thanks. Ride safe, Augie....
Old 01-02-2012, 09:27 AM   #1
Augie's Avatar
I Ride: 2011 Ninja ZX6R / 2008 Hyosung GT25R
Compatibility
Ride safe,
Augie.
Augie is offline
Old 01-02-2012, 09:42 AM   #2
Sandoval's Avatar
I Ride: 03 636 (Under Construction)
There different part numbers so it could be different
Sandoval is offline
Old 01-03-2012, 07:32 AM   #3
Augie's Avatar
ok thanks.
Augie is offline
Old 01-03-2012, 08:29 AM   #4
killzrain's Avatar
there different part numbers but still compatible im sure,, hell i had to run an o5 636 reaset for a couple weeks and it matched right up
killzrain is offline
Old 01-04-2012, 12:33 PM   #5
Augie's Avatar
hmmm.. I'd like to try it.
Augie is offline
Old 01-05-2012, 08:12 AM   #6
yes they will work, the angle might be slightly different or something. I used a 08 set on a 05 zx636. the linkage might be a little different too
JMNRACING is offline
Old 02-21-2012, 09:50 AM   #7
Augie's Avatar
Update:
An 07/08 ZX6R left rear set (shift pedal & peg) WILL fit a 2009-2012 ZX6r.
A buddy of mine had an 08 ZX6R and had the left rear set laying around, he gave it to me and it was a perfect fit, everything was in alignment. I just had to paint it black since it was gray.
**NOTE**
This is for the left rear set, I can't speak for the right side.
Ride safe.
Augie is offline
Old 02-21-2012, 10:52 AM   #8
EvilTwin's Avatar
I Ride: 07 ZX-6R street, 03 636 track
Rearset spacing has been the same since 05-present, 85mm to be exact. Before that they were 80mm.
EvilTwin is offline
Old 02-21-2012, 12:23 PM   #9
Vampyre's Avatar
I Ride: 2005 ZX-6R, 2011 250R
On the right side 05-08 are the same, but in 09 they changed the angle of the rear brake master cylinder. Before it was pretty straight up and down, after it is at almost a 45 degree angle forward.
Vampyre is online now
Old 02-22-2012, 09:14 AM   #10
EvilTwin's Avatar
Does that affect the line that runs up to the reservoir?
EvilTwin is offline
Old 02-22-2012, 09:18 AM   #11
oKayH's Avatar
I Ride: a Schwinn
Bohemian Racing Adjustable Rearsets ZX6R
I'm inferring from that thread that going from 05-08 sets to 09+ will require a longer line and 09+ down to 05-08 will be fine with a stock or shorter line
oKayH is online now
07 Parts Compatibility.... CamZx The ZX6R 4 12-28-2009 03:08 PM
03 636 shock compatibility question Drunken_Clam The ZX6R 4 12-10-2009 12:54 PM
03/04 zx6r compatibility Shadona The ZX6R 3 07-01-2009 04:23 PM
compatibility selfinfliction The ZX6R 12 03-28-2009 07:57 PM
G & J Model Parts Compatibility Question Buster The ZX6R 3 03-01-2009 01:48 AM
