Replacing my Rear Shock - 02 zx6r 636 A1P.- Any advice and guides? - ZX6R Forum
post #1 of 19 Old 01-12-2012, 01:56 PM Thread Starter
I Ride: 00 zx6r ninja J1
Hi there,
i picked up a revalved, rebuilt, upgraded rear shock off ebay as my existing shock is far gone; sloppy, to soft - terrible.
Im fitting the new rear shock this weekend, any1 got any tips or guides. ive got a haynes manual just want to know if any1 had any other guides or tips.
Thanks
thegreensnot is offline
post #2 of 19 Old 01-12-2012, 05:03 PM
oldninjadude's Avatar
I Ride: 2007 ZZR/ZX6R
Did the shock come from a 2003/4 ZX6R? if so it should bolt right up.
I would recommend a new linkage as-well, at least remove yours, clean & check the bearings repack em too.
read only one page"
oldninjadude is offline
post #3 of 19 Old 01-13-2012, 03:04 AM Thread Starter
shocks of a 2x6r j1 & zx9r. should fit straight on my a1p. im going to fit it see if its anygood then im going to clean bearings etc.
post #4 of 19 Old 01-13-2012, 05:34 AM
NuggetNik's Avatar
I Ride: 2001 Blue J2 ZX6R
You my man might just be a life saver for me, could you sent me the eBay "shop" that you brought the shock rebuilt kit from as I have to buy one for my J2 at some point before the new season, also would you post up anything you had trouble with as I have no idea what I am going to have to do, I have brought the Haynes but any extra info would be really handy thank you mate :-)
Originally Posted by TXZX6R View Post
WTF Nugget... I thought they were suppose to fix your brain?? You seem A LOT more fucked up now... YOU FUCKEN WEIRDO! bahahahahahaha
Big Up The "Fizzy Gravy" Club
NuggetNik is offline
post #5 of 19 Old 01-13-2012, 03:03 PM Thread Starter
Nugget nik. It took me a while to find one. I found a revalved and refreshed to match my wieght, was lucky I found it really, we will see what its like, it cant be any worse than what it is now lol. I kept searching zx6r j1 shocks on eBay until a revalued 1 turned up. Or you could remove your rear shock and send it to (k-tech) or (reactive suspension). I'm doing it Sunday so al keep you posted
post #6 of 19 Old 01-13-2012, 03:06 PM
scoobs's Avatar
I Ride: something naughty
shame you can buy my rear shock its only 2 years old and plenty of life init
scoobs is offline
post #7 of 19 Old 01-13-2012, 03:09 PM Thread Starter
We will see what this one is like mate, is it an aftermarket 1?
post #8 of 19 Old 01-13-2012, 03:13 PM
scoobs's Avatar
noooooooooo....its the real mckoy .....
the only reason im not using it as ive fitted a 2007 rear srm on my bike and i had to fit a 2007 rear shock .....if i didnt have to i would still be using it
scoobs is offline
post #9 of 19 Old 01-13-2012, 03:18 PM Thread Starter
Aw sound how much would you be wanting?
post #10 of 19 Old 01-13-2012, 03:20 PM
scoobs's Avatar
1 million pound ...
2 chicken and salad cream sandwiches
1 bottle of orange juice
and a packet of dry roasted peanuts
or just thow me £30 posted and its yours ....its no good to me now
comes with spring ....all ready to go just bolt it on
scoobs is offline
post #11 of 19 Old 01-13-2012, 04:09 PM
NuggetNik's Avatar
DIBS
As long as it is a straight replacement for a J2 shock...
I will have it!
post #12 of 19 Old 01-15-2012, 12:25 PM Thread Starter
Well i successfully fitted my rear shock and regreased my suspension linkage using the nipples to. its alot better and stiffer very pleased with it. pritty simple process as peeps have mentioned, i used front paddock stand and supported the bike by a jack under the sump. i also used my grab rails to tie rope to the garage rafters to provide support. i also supported the reear wheel with a wood latt allowing it not to drop when the shock was removed. i used a rear paddack stand to postion the bike until the sump was jacked and the rear of the bike was supported then removed it. i would say the hardest part was to take 1 bolts out of the suspension linkage so i could easily remove the shock as the nut was between a size 16 & size 17 socket, had to use a spanner in the end to ensure i didnt round it off.
i worked to the haynes manual which was pritty simple to use. ive added a few pictures,they dont real show much but i thought i would attach them anyway.
thanks for the help guys.....next the front shocks
ID:	7821   Click image for larger version
ID:	7822   Click image for larger version
ID:	7823   Click image for larger version
ID:	7824   Click image for larger version
post #13 of 19 Old 01-15-2012, 01:09 PM
NuggetNik's Avatar
Thank you mate for that.... I'm planning on doing mine 28th/29th of this month.... blitz-ing a load of stuff on the bike over a weekend.... how long did it take you do you think?
post #14 of 19 Old 01-15-2012, 01:24 PM Thread Starter
no problem took me about 1.5 - 2 hours as i had a bit clean around when the shock was out and i had abit of bother with try to get that daft suspension brace bolt out but to be honest it takes longer to prep and get the bike support than to actually remove the shock. the haynes manual is abit missleading when it says to remove the brace bolt as you actually cant as the exhaust is in the way (this will make sense when you do it) i removed the bolt above on the on the suspension linkage instead so i could move the brace to one side.
i would grease all the nipples while you have access there but make sure you have a grease gun with a flexible hose as it is quite tight to get to the nipples on the suspension linkage.
post #15 of 19 Old 01-15-2012, 02:53 PM
NuggetNik's Avatar
Sweet, there will be two of us when I do mine so it might make it slightly easier I reckon, I will let you know how I get on. I will make sure I get a grease gun... thanks for the tip mate! just what I need :-D
