Everything you need to know about HID / Xenon - Page 2 - ZX6R Forum
 24Likes
post #16 of 61 Old 05-03-2012, 07:24 AM
twatsonhd's Avatar
I Ride: 2007 ZX6R
Steve, have you any information on how to upgrade to the headlights and also have them both work as High and Low beams??
How many motorcycles in the garage are enough?? 1 MORE!!!![/
twatsonhd is offline
post #17 of 61 Old 06-14-2012, 03:25 PM
balla_08's Avatar
I Ride: 09 ZX6R
Ive been thinking about blacking out my headlights..should i counteract it and get a stronger bulb? what do you think a good setup would be?
09 ZX6R
Vortex sprocket, smoked Hotbodies undertail, smoked turn signal, Moto GP slip on
balla_08 is offline
post #18 of 61 Old 06-14-2012, 03:44 PM
silversurfer's Avatar
that is just a bad idea, your headlights are what lets cagers know your on the road
silversurfer is offline
post #19 of 61 Old 06-14-2012, 04:21 PM
balla_08's Avatar
I Ride: 09 ZX6R
but if i get 35 8k to counteract it i dont think it would be bad at all..?
09 ZX6R
balla_08 is offline
post #20 of 61 Old 06-14-2012, 05:40 PM
FolowdaChamp's Avatar
I Ride: 2011 zx6r
I'm suprised that this thread only has 18(19) posts, considering all the daily hid questions
FolowdaChamp is offline
post #21 of 61 Old 06-15-2012, 08:33 PM
Nickoli's Avatar
I Ride: 08 ZX6R
This is a great thread, helped me out since I didn't and still don't know much about HIDs. I also like his other post about installing them, I just need to figure out if it is the similar for an 08 because I am looking into buying new projectors and everything. When I bought my bike at the end of April this year it already had the Ebay HID kit installed on it and I ride a couple times a week at night on my way home from work and tonight is the first night I was not flashed by another vehicle.
I have adjusted my stock projectors down to what I believe might "help" the issue until I can purchase and install the new system but im not sure where to start with it or what to buy.
Nickoli is offline
post #22 of 61 Old 06-21-2012, 02:51 AM Thread Starter
Steve's Avatar
I Ride: 2017 636 KRT Performance Edition
I made a thread a while back about this
http://zx6r.com/zx6r/22089-dual-hid-info-thread.html
Dont black out your headlights, this will work against you in a very dangerous way, if your going for a dark look then if you have projectors then you can paint everything inside the headlight black.
Dont touch the lens or the headlight lens.
Plus 35W ballasts wont due much unless your installing wide angled projectors.
8000K is just too blue and wont get the best light output, brightest you'll get is 4300K
Your best bet is to go with something like a mini projector if your going for bi-xenon.
bi-xenon projectors tend to be a little bigger due to have the solenoid to move the shutter but if your going for a one projector high and projector low then the vast majority will fit in the headlights.
Just email the supplier for sizes and then you should be able to make a judge whether it will fit or not.
HTH
Steve
Steve is offline
post #23 of 61 Old 06-21-2012, 05:38 AM
om6r's Avatar
I Ride: 04 ZX6R
Thanks for the info.
om6r is offline
post #24 of 61 Old 06-21-2012, 07:51 AM
balla_08's Avatar
I Ride: 09 ZX6R
09 ZX6R
balla_08 is offline
post #25 of 61 Old 06-21-2012, 09:42 AM
zx6ixxer's Avatar
Great post!
Looking at this post reinforces my great decision I made when I ordered my DDM tuning HID kit, I got the 35w 4500k, looks awesome!
zx6ixxer is offline
post #26 of 61 Old 08-04-2012, 03:11 PM
How do HID's work in the stock projectors? Im debating either 4300 or 6000 in mine
01jackedZ is offline
post #27 of 61 Old 10-03-2012, 10:46 AM
FieldDay's Avatar
I Ride: 2011 ZX-6r CPB
So I guess the real question is, what would be the best for our zx6's?The most popular choice, I'm assuming, is the ddm kit.
Will those be good for our bikes?
35w or 55w?
Do our bikes have xenon or halogen projectors, and how big of an issue is it really?
I know the 09-12 have projectors, but what about the other years?(this is mainly for the community to answer, not Steve)
Side note: I had the DDM 55w 8000k on my Buell, it seemed like a pretty solid kit. Had them for about a month before the bike was rear ended and subsequently totaled. But they were way brighter than stock and hooked up rather easily.
FieldDay is offline
post #28 of 61 Old 10-03-2012, 11:34 AM Thread Starter
Steve's Avatar
35w or 55w?
The best for bikes is 35W.
there is not much of a difference in brightness on the 35W to 55W ballasts only real difference is lifetime of the bulbs, they last longer on the 35w as they are not getting worked as hard on the 55w kits.
The bulbs in ALL the ninjas are halogens no bike as of yet has come with an optional extra of xenons.
The only real big issue with using xenon bulbs in your halogen projectors is it doesnt make good use of the light output and directs the light more like a torch to a point. whereas if you use a xenon projector your get a nice wide spread of light onto the road. Refer to pic below:
all xenon kits whether they be 35 or 55 watt kits will be substantially better than the halogen OEM parts they only way to make sure you have the best light output and light on the road is to used as close to white light (4300K) and xenon projectors to get the best results.
HTH
Steve
Steve is offline
post #29 of 61 Old 10-03-2012, 11:54 AM
martydmb's Avatar
I have no problem with my $50 hid kit. No hot spots or glare.
[[11' zx6r green & black]]
martydmb is offline
post #30 of 61 Old 10-03-2012, 12:11 PM
Blake2185's Avatar
I Ride: 2006 Ninja ZX-6R (636)
I recently installed the same 35w dual conversion kit for my high and low as a friend .
It worked fine on his bike ,but when my lights warm up they start to flicker .
What would cause this ?
Blake2185 is offline
can flash hid headlights
everything about hids
everything you need to know about hids
h7 bulb comparison
hid 2011 zx6r
hids know it
high intensity motorcycle headlights zx6r
luz xenon en su base
what is hid lighting or so called xenon?
xenon headlights turn orange
zx6r hids 2012
zx6r xenon lights 2012
Dual HID Info thread Steve Mechanical and Technical 30 06-03-2014 12:41 PM
How-to: HID Install on '05 ZX6R EvoMR Mechanical and Technical 11 11-11-2013 05:05 AM
HID, very disappointed DirtyZX6R Mechanical and Technical 22 02-26-2012 06:53 AM
HID wont turn on Slo6R Mechanical and Technical 13 02-08-2012 01:13 AM
HID frenzy devildog4045 The ZX6R 56 10-28-2010 09:04 PM
