Just bought a used gpr 1.0 stabilizerThis is a discussion on Just bought a used gpr 1.0 stabilizer within the Mechanical and Technical forums, part of the ZX6R Forum category; Hey whats up, I just bought a used gpr 1.0 stabilizer off ebay but I can't tell if this is in working condition... So when ...  |
02-16-2012, 08:05 PM
#1 | | Squid
Joined: Nov 2011 From: LI, ny Posts: 78 I Ride: 05 Kawasaki Ninja zx636 with passion | Just bought a used gpr 1.0 stabilizer
Hey whats up, I just bought a used gpr 1.0 stabilizer off ebay but I can't tell if this is in working condition... So when i set the dial to max which 8, the lever doesn't feel like much tension at all, because i was expecting it to be stiff to the point where it is tough to move the lever.... am I wrong?? how should it be??
02-16-2012, 08:07 PM
#2 | | Squid
Joined: Nov 2011 From: LI, ny Posts: 78 I Ride: 05 Kawasaki Ninja zx636 with passion | Quote:
Originally Posted by badnewsbrock Hey whats up, I just bought a used gpr 1.0 stabilizer off ebay but I can't tell if this is in working condition... So when i set the dial to max which 8, the lever doesn't feel like much tension at all, because i was expecting it to be stiff to the point where it is tough to move the lever.... am I wrong?? how should it be?? | and also i am able to turn the dial 360degrees an infinite number of times, if that is normal i dont know i am new with this
02-16-2012, 08:12 PM
#3 | | Team Green
Joined: Jan 2012 From: san clemente, CA Posts: 141 I Ride: 2005 zx6r |
hmm.. I had one and when set to 8, the lever or part that sticks out was almost impossible to move.. so if I understood correctly, your thing seems to be broken. GPR does repairs on their products though. Also, the dial is supposed to be able to be turned 360 infinite # of times.
02-17-2012, 09:48 AM
#4 | | Squid
Thanks, so I am gonna debate if I should get it serviced or return it and get my 225 back
02-17-2012, 10:21 AM
#5 | | World Superbike Racer
Joined: Oct 2011 From: Orange County Posts: 1,217 I Ride: 2006 ZX636r |
yeah, its broken for sure. Just picked up my used one, 8 is crazy, can barely move the bars
02-17-2012, 12:37 PM
#6 | | Track Star
Joined: Apr 2011 From: Erie, PA Posts: 384 I Ride: 2000 ZX6r |
Get your $$ back dude.
02-17-2012, 05:02 PM
#7 | | Squid
could it just had an oil leak and if i add oil and change the gasket wouldn't that fix the problem?? because i dont understand the mechanics of this device but i understand its purpose
02-19-2012, 05:18 PM
#8 | | Squid
ok so i just opened this stabilizer up and i am so happy i did, because now i understand the mechanics of this... So there was no oil inside!!! and it definately had to leak out of one of the damaged o ring seal from the body screw. So i am off to the hardware store to pick up the o-ring and should i pick up 10wt, 15wt, or 20wt fork oil??
02-19-2012, 09:02 PM
#9 | | Pro Racer
Joined: Sep 2010 From: Upstate, S.C. Posts: 638 I Ride: 2006 Ducati Sport Classic |
Take it to a dealer for service, i had one that came on my bike so i did not have a receipt for it but i went to my dealer and they sent it in for me and it was serviced for free.
02-19-2012, 09:08 PM
#10 | | Team Green
Joined: Nov 2011 From: wilmington nc Posts: 120 I Ride: 07 zx6r |
Correct me if I'm wrong but I think gpr will do a complete rebuild for $100 if the oil doesn't fix it
02-19-2012, 09:57 PM
#11 | | Team Green
Joined: Jan 2012 From: san clemente, CA Posts: 141 I Ride: 2005 zx6r | Quote:
Originally Posted by Kevin2109 yeah, its broken for sure. Just picked up my used one, 8 is crazy, can barely move the bars |
haha glad you like it! Just don't forget to turn it back to one when you're coming off freeways etc.. had that happen to me way too many times and it's scary as hell
02-19-2012, 09:58 PM
#12 | | Team Green
Originally Posted by badnewsbrock ok so i just opened this stabilizer up and i am so happy i did, because now i understand the mechanics of this... So there was no oil inside!!! and it definately had to leak out of one of the damaged o ring seal from the body screw. So i am off to the hardware store to pick up the o-ring and should i pick up 10wt, 15wt, or 20wt fork oil?? | first off, try returning it man. $225 is a lot for a used on, and then having to get it repaired will cost more. if you can't return it then I would send it into gpr just to be confident it's fixed.
02-19-2012, 10:25 PM
#13 | | Pro Racer
Originally Posted by sdawg first off, try returning it man. $225 is a lot for a used on, and then having to get it repaired will cost more. if you can't return it then I would send it into gpr just to be confident it's fixed. | +1 I'm sure it wasn't mentioned that it was non functioning. I'd get my money back and get a proper one, instead of paying more money to fix what shouldn't have been broken in the first place.
02-20-2012, 07:09 AM
#14 | | Team Green
Joined: Feb 2012 From: NM Posts: 106 I Ride: '09 ZX6R - Race Bike |
Return it... you can buy a new one for about $300-$320.
02-20-2012, 07:29 AM
#15 | | Pro Racer
You should also make sure you install it correctly. I took my bike to the shop once and when I got my bike back, The setting was at 5 and it felt like there was no stabilizer. So on my ride back home I was turnig and turning through the settings and nothing. As soon as I got home I noticed that the base was installed over my clutch cable. So I took it off fixed it and turned it back to my usuall street setting.
| | | Search tags for this page | | gpr stabilizer 1.0
