Infamous Kawi Tick
This is a discussion on Infamous Kawi Tick within the Mechanical and Technical forums, part of the ZX6R Forum category; so far anyways.......... it would be cool if akra came out with a shorty or smaller gp...
Old 02-18-2012, 02:03 PM   #31
THUG's Avatar
From: OMAHA NEBRASKA / TULSA OKLAHOMA / OCEAN CITY MARYLAND
I Ride: 2009 ZX6R DIABLO BLACK (TOTALED) COMING SOON: 2009 ZX10R DIABLO BLACK
THUG is offline
Old 02-18-2012, 09:08 PM   #32
Alright guys. Tightened the auto cct. Sound a ton better. But I think.I still.have a slight ticking. Is this the valve noise everyone is talking about? I would assume so. You guys help so much! Thanks! I'll upload a video soon!
russellzx6r is offline
Old 02-18-2012, 09:12 PM   #33
trackdayhero's Avatar
Well, I think if you don't hear any ticking at all your motor probably isn't running.
trackdayhero is offline
Old 02-18-2012, 10:46 PM   #34
Normal then I'm assuming real faint tick but I've still watched videos where I don't hear it at all.
Old 02-19-2012, 07:32 AM   #35
It's really nearly impossible to diagnose subtle engine noise from a video considering all cameras would pick up sound a little differently depending on the capabilities of the mic and and processing that gets done to the video. Your engine noise was more than subtle and was fairly obvious. Although even still there was a chance that it was more than a tensioner issue. Another possibility is that it is still a tensioner issue. That is, you made it go another notch on the tensioner but maybe it really needed a notch and a half to be properly tensioned. Of course the automatic tensioner doesn't have "half" notches. A manual tensioner is infinitely adjustable so if you are still hearing a little noise from the cam chain being a little too loose the manual tensioner would get that out. But I wouldn't worry about it if it is minor. It's better to be slightly loose than too tight.
Old 02-19-2012, 10:36 AM   #36
Thanks buddy. Its not coming from the same area now which I'm assuming was the cct. It sounds more towards the headers now. Which could be the tippets I believe is what they are called. I'm in no way capable of really diagnosing this and I just hit 10k so I was thinking of taking it to the stealership for the 10k service. Does anyone know what this actually consists of?
Old 03-06-2012, 08:29 PM   #37
DirtyMartini's Avatar
I Ride: 2007 ZX6R
Thumbs up
Originally Posted by ZX6RRECTION View Post
Adjusting auto cam tensioner
1 . Loosen the two small side bolts.. Top and bottom... Loosen do not remove
2. Loosen the big middle bolt.... Slightly back it out 1click.... Tighten everything
3. Start bike
4. Repeat as needed until she runs quiet
Just did it today ...1 click and it purrs like pussy cat ...Thanks guys!
DirtyMartini is offline
Old 05-09-2012, 07:18 PM   #38
ely
ely's Avatar
I Ride: 09 ZX6R
does anyone know if this adjustment of stock cct is the same for 09 zx6r thank you all in advance
ely is offline
Old 05-09-2012, 07:53 PM   #39
kawi636rt's Avatar
I Ride: 04 636
I found a video on youtube how to do it on my 04 but all he did was loosen then top bolt pretty much all the way, then the bottem bolt till it clicked once and tightened both back up. Didn't touch the center bolt...and it fixed the noise
kawi636rt is offline
kawi tick
Talked to kawi today (07-08 riders) chaz Motorcycle Talk 1 09-06-2011 01:41 PM
Tick tick tick 1NastyZ Mechanical and Technical 15 08-10-2011 01:38 PM
cheapest place to buy kawi oil Chaos Mechanical and Technical 13 07-02-2011 10:26 PM
Yes ia m still having problems starting my kawi, but now it is a new problem lol kimasaki636 Racing 2 04-17-2011 12:32 AM
Kawi oem part problem Brichard The ZX6R 10 04-04-2009 08:50 PM
