PVC throttle mod "zip tie"
This is a discussion on PVC throttle mod "zip tie" within the Mechanical and Technical forums, part of the ZX6R Forum category; I am looking for some help. Would anyone be willing to send a piece of PVC to my APO box? I do not have easy ...
Old 02-20-2012, 05:07 AM   #1
Dcook0's Avatar
From: Duanesburg, NY. Palm Bay, FL (Stationed in Germany)
I Ride: 2011 ZX-6R
I do not have easy access to pipe ( no homo) , or a band saw.
Of course the pipe would have to be cut to size already.
I ride a 09-11.
In return I will send a money order to cover the shipping and such.
Anyone interested?
Dcook0 is offline
Old 02-20-2012, 05:33 AM   #2
dash8's Avatar
I Ride: 09 ME ZX6R
Hey man, I could probably send you my pipe
seriously, let me know what size and length (grrrrr baby), and email me your addy there, i'll see if home depot has it
dash8 is online now
Old 02-20-2012, 09:28 AM   #3
Dcook0's Avatar
I Ride: 2011 ZX-6R
I need 1/2" X 2" (i think)
if you take apart your throttle, you'll see where the throttle cables connect to the barrel. I need a small piece of PVC that will fit around the barrel.
Alternative to the zip tie mod
Thats what I'm trying to do^
Dcook0 is offline
Old 02-20-2012, 11:01 AM   #4
rattyzx6's Avatar
I Ride: zx6 09, B1h, tdr250
Why don't you want to use a zip tie though. it works!
rattyzx6 is online now
Old 02-20-2012, 11:06 AM   #5
Farmboyzx6r's Avatar
I Ride: 2009 black zx6r
If I remember correctly 1 1/4" is what I used. It measured roughly 1 1/2, but after you cut out the section for the cable hookups it snaps over the tube perfect.
If dash can't get it I'll try to find the left over piece from mine. PM me if you need it.
Farmboyzx6r is offline
Old 02-20-2012, 12:46 PM   #6
Dcook0's Avatar
I Ride: 2011 ZX-6R
Thanks man.
Ill keep in touch.
Dcook0 is offline
Old 02-20-2012, 01:37 PM   #7
dash8's Avatar
I Ride: 09 ME ZX6R
ok, let me know when you have a size, and I'll shoot over and get it... plus everything is closed here for the holiday...
dash8 is online now
Old 02-20-2012, 02:43 PM   #8
Dcook0's Avatar
I Ride: 2011 ZX-6R
I will measure it and get back to you.
Farmboy said it should be an 1 1/4" pipe
I just need a sliver off the end. 1/4"
Dcook0 is offline
Old 02-20-2012, 03:54 PM   #9
trackdayhero's Avatar
I tried this last night and ended up reverting back to stock. Before I changed anything I measured the stock throttle rotation with a protractor and I got 70 degrees of turn. With one strip of ziptie it only dropped it to 65 degrees and with two strips doubled up it only brought it down to 60 degrees. Not nearly as significant of a reduction as I had hoped. Also with two strips I had to loosen the cable adjustment completely to full loose as the added thickness of the zipties took up all the slack. I guess that's why the Motion Pro kit also comes with new cables. I assume with much greater adjustment. So, I just decided to take the zipties back off and go with the stock setup.
trackdayhero is offline
Old 02-20-2012, 04:21 PM   #10
Haven't measured mine with a protractor, but it made a noticeable difference in the throttle throw to me. I'll check it when I get home.
2009 zx6r kleen air mod how to : THUG Mechanical and Technical 49 04-19-2012 02:55 PM
Quick Turn Throttle Mod jenfield Mechanical and Technical 0 06-21-2011 09:29 AM
jumper mod yes or no? bmarcinczyk1 Mechanical and Technical 17 04-18-2011 03:29 PM
Top butterfly mod. kawasakifreak77 Guides 11 05-19-2009 07:16 PM
