Front brake problem
This is a discussion on Front brake problem within the Mechanical and Technical forums, part of the ZX6R Forum category; I am having some problems with my front brakes. When the bike is sitting and "cold" the brakes feel and work fine. After the bike ...
Old 02-20-2012, 09:11 AM   #1
Front brake problem
I am having some problems with my front brakes. When the bike is sitting and "cold" the brakes feel and work fine. After the bike is started and warmed up the front brakes FAIL. By fail I mean they have to be pumped a few times before they start to engage. I have bled both sides of the front and there was very very little to no air (now no air after being rebled) and still nothing. Rear works just fine.
Before I order a new front brake master cylinder (only thing I can think of) I wanted to see if y'all know what else it could be? I don't wanna order the part and then find out it could be 100 different things and I bought the wrong thing.
I was told it could be warped rotors too?
Any help is appreciated.
ZX6R Noobie is offline
Old 02-20-2012, 09:20 AM   #2
MonsterZX's Avatar
I Ride: 09' Monster Edition ZX6r
Ok working of slight knowledge (recently learned) Pick up a vacuum bleeder will save you that headache if there is ANY air in the line or caliber. Also Id assume if it was a warped rotor it would not need pumping. The break would just kind of "pulse" pick up a $30ish vacuum bleeder or borrow one. just my 2 cents
MonsterZX is offline
Old 02-20-2012, 09:23 AM   #3
The guy at Autozone also recommended a vacuum bleeder is the pump bleeder didn't work.
Would even the slightest bit of air cause this problem? Sorry if that sounds really dumb >.>
Old 02-20-2012, 09:24 AM   #4
Alex Gold's Avatar
Yes, especially if you have braided lines
Alex Gold is offline
Old 02-20-2012, 09:29 AM   #5
They are not braided they are just the stock lines.
Ok, a vacuum bleeder it is! I didn't know if even the slightest bit of air would cause this, I guess I had it in my head "no way just a lil air could do this, has to be something more!" lol
Old 02-20-2012, 09:30 AM   #6
MonsterZX's Avatar
there could be more air than you think stuck in the brake caliper its self
Old 02-20-2012, 09:33 AM   #7
Y'all strike again on this forum! Super fast help and so much knowledge.
Y'all are simply amazing! <3<3<3
Old 02-20-2012, 09:35 AM   #8
MonsterZX's Avatar
Let us know if that solved it. I know we had an issue with my buddies brake and that was the fix. We fucked with that bike for a while till another friend brought his bleeder. So happy to pass it along. nothing more frustrating then a bike not working properly.
Old 02-20-2012, 09:37 AM   #9
It is very frustrating lol. I bought just a lil bottle one man bleeder from autozone and it had a lil air in the lines but it seemed to have got it all. When the bike was sitting brakes worked fine, fired it up let it warm up to ride and they needed pumped to engage :/
I figured it was a much bigger problem lol.
Gonna head out in a few and pick the vacuum bleeder up, maybe endure the cold and try and fix it today.
I'll let ya know!
Old 02-20-2012, 09:42 AM   #10
MonsterZX's Avatar
alright man good luck hope it was that simple
Old 02-20-2012, 10:23 AM   #11
NatBrown's Avatar
It could very well be warped rotors too. Although, you will feel pulsation in the brake lever and in the way the bike stops. As the warp rotors move past the pads, the rotor will push the brake pad away and the piston back into the caliper. When you try to brake, you have to pump in order to move the pad/piston back out.
NatBrown is offline
Old 02-20-2012, 10:59 AM   #12
rattyzx6's Avatar
I Ride: zx6 09, B1h, tdr250
What bike is it. if you have stock lines and you ride a 10 year old bike your hoses will be expanding when hot. Feel the hoses when you put the brake on.
It could be an air lock as has been said above.
rattyzx6 is online now
Old 02-20-2012, 11:17 AM   #13
o sorry, the bike is a 2000
Old 02-20-2012, 04:37 PM   #14
oldninjadude's Avatar
I Ride: 2007 ZZR/ZX6R
First off, Have you had the the bike on stands, & spun the front wheel?
Is it dragging?
You should check this, If there's no drag, Then its a pressure problem.
Could be the master, could be in the lines or fittings.
You should look closely at every inch of the system for tiny fluid leeks.
& of course you want to bleed the system, If your not getting air bubbles?
The master is proly bad.
But you first need to do as I said & check for to much drag, To much will overheat the rotors & cause fade, & lead to warped rotors
oldninjadude is offline
Old 02-20-2012, 04:42 PM   #15
trackdayhero's Avatar
Is it dragging?
But you first need to do as I said & check for to much drag, To much will overheat the rotors & course fade, & lead to warped rotors
To add to that, and I am not sure if this is an issue on the Ninja but I do know this happens on dirt bikes all the time, is that if you have any water at all in your system (via condensation or otherwise) and you are using your brakes heavily the temps can get hot enough to boil the water which of course creates air bubbles and the brakes will not work. When the brakes cool the vapor turns back into water and the brakes will then work again. If you haven't changed out your fluid you might want to do that in addition to a good bleeding with the vacuum bleeder system to make sure there is no contamination.
trackdayhero is offline
zx6r brakes problem
Bohemian Racing Adjustable Rearsets ZX6R Kevin2109 The ZX6R 101 05-18-2012 01:46 PM
09+ Torque Specifications sXzx6rXa Mechanical and Technical 1 02-12-2012 08:57 PM
Controlling Your Controls: Braking EvilTwin Motorcycle Talk 13 10-12-2011 12:16 AM
Need help with Front Brake problems on a 2004 Ninja zx6r Aadaamm Mechanical and Technical 7 07-27-2011 07:17 AM
