Hi All,
Took the fairings off my bike today, pretty much all of them have some damage or imperfection. I'm trying to fix these up myself, so I'm hoping I can get some guidance. I plan to use
Bondo Fiberglass Repair kit to fix the cracks. Has anyone used this product or have suggestions on what I should get instead. After I fix the damages I will prime and paint the parts myself(rattle) and have the clear done with a gun.
DAMAGES
Front Wheel Fender
cracked on both side
Paint is chipped on the front
Left Fairing
Craacked, tried to repair this before with some plastic bond
One of the top pieces broke off. Whats the best way to put this back on?
Tab for blinker is broken off
Rear Cowl
Mainly skratches, but there is a crack too
Plan of action:
Work on one piece at a time. Clean part with soapy water, then clean water, and wipe the whole thing with a towel. Tape the exterior of the part along the crack. Drill along the crack on the interior to take away the paint and make a groove. Mix/apply resin, fiber, layer with more resin, another layer of fiber and smooth things out with a final layer of resin. Wait for it to hardend then sand the thing down(What progression in grit?). Do I need body filler or will sandable primer be enough?
I'll try and keep it shorter in the future. But, am I on the right track here?
