Brake fluid leaking after lowside
This is a discussion on Brake fluid leaking after lowside within the Mechanical and Technical forums, part of the ZX6R Forum category; As some of you know i lowsided my bike this afternoon. Now when i press the front brake, the lever goes soft and leaks out ...
Old 02-20-2012, 08:44 PM   #1
Lobster's Avatar
I Ride: 2007 ZX-6R
As some of you know i lowsided my bike this afternoon. Now when i press the front brake, the lever goes soft and leaks out of the 10 or 12mm bolt thats directly underthe lever.
Any ideas?
Lobster is offline
Old 02-20-2012, 08:45 PM   #2
jake89's Avatar
I Ride: 05 zx6r
damn dude you are having a really bad day arent you?
jake89 is offline
Old 02-20-2012, 08:46 PM   #3
Youssef636's Avatar
I Ride: mostly white girls.
Any ideas?
you might have broke the bolt itself on the MC or cracked the MC itself ....
Youssef636 is offline
Old 02-20-2012, 08:53 PM   #4
Lobster's Avatar
I Ride: 2007 ZX-6R
Extremely bad day. My cars oil filter backed out because someone switched them out at walmart from box to box
Kill me now.
Dumb question. How would i know if its the MC?
Lobster is offline
Old 02-20-2012, 09:03 PM   #5
Youssef636's Avatar
^Thats why i always get my items from the very back, and check em.
Also you would have to inspect the bolts and area where the bolt screws in. Make sure the bolt is threaded right in the 1st place and not stripped, iv seen a few where that has been the case and your little lowside might have just been the iceing on the cake for it to start leaking. Looks like your lever took a nice bang so Kinda hard to tell you what to do but you just gotta look over everthing and tell us where the oil is leaking from EXACTLY
rear brake fluid how to... Rjones1041 Mechanical and Technical 3 10-14-2011 10:50 AM
Brake fluid tricks DaniZixxer Mechanical and Technical 14 04-29-2011 07:27 AM
Brake fluid ZX636 The ZX6R 8 02-21-2009 02:25 AM
