PCV set up using engine temp or throttle position?This is a discussion on PCV set up using engine temp or throttle position? within the Mechanical and Technical forums, part of the ZX6R Forum category; I have no idea. The gray wire in the PCV harness won't even reach the speed sensor wire. Does someone know what to do? 2010 ...
