Interesting delima. It might be easier to see if you can find that upper cowel for sale and save yourself the headache, also you can still have your race fairing incase you want to slap it on again.
If not, then it seem like it can be very tricky and you'd need to be delicate and caution. Fill the hole in the center and then cutting from the inside of the fairing outward and use a dremel at high speed. The fast speed will help you cut thru clean. Use very minimal force so you don't cause any cracks, let the dremel and cut wheel do all the work.
that my suggestion, never don't anything like that before, but i've had to cut thru delicate materials before and so far so good....
