Chains & Sprockets - Page 18 - ZX6R Forum
 36Likes
post #256 of 270 Old 03-04-2016, 02:16 AM
lmiles's Avatar
I Ride: 2011 ZX6R
My stock set up is 16 43, I just bought a 45 rear. Would I have to add any links and if so how many?
lmiles is offline
post #257 of 270 Old 03-20-2016, 07:49 PM
ilovemyzx6r's Avatar
I Ride: s1000rr and zx6r
Sorry if this was already mentioned, but could someone explain to me everything there is to know about gearing, and also what a chain adjuster does?
i<3myzxsixer
ilovemyzx6r is offline
post #258 of 270 Old 03-22-2016, 11:11 AM
honestSquid's Avatar
I Ride: ZX6R (abs)
That is a tall order. You should search 1st then ask.
How about you start by telling us what you know and if you can not do that, then search.
honestSquid is offline
post #259 of 270 Old 03-22-2016, 12:28 PM
BrandonZX6r's Avatar
I Ride: 06 ZX6r 636
https://www.google.com/?gws_rd=ssl#q...n+a+motorcycle
BrandonZX6r is offline
post #260 of 270 Old 03-23-2016, 03:07 AM
Hello, everybody!
Its my first time to change my chain and sprockets for my ninja ZX-6R '06. Can you please give me your reviews about JT Sprockets and DID X-ring chain?
vixs is offline
post #261 of 270 Old 03-23-2016, 06:12 AM
Originally Posted by vixs View Post
Hello, everybody!
I installed JT sprockets and a DID chain on my '09 a couple of months ago. so far, so good. No problems for me at this point (roughly 1,000 miles later).
vixs likes this.
post #262 of 270 Old 04-24-2016, 06:25 AM
I Ride: 2002 zx6r
Just did an rk kit on my 02 zx6r. Less one tooth in the front. I did it myself with no issues. Is the speedo healer a complicated electrical installation?
Imminent34 is offline
post #263 of 270 Old 04-27-2016, 05:42 PM
Looking for a suggestion for speedo healer. Thanks
ColoZX6R is offline
post #264 of 270 Old 07-10-2016, 09:29 AM
Darren Frost's Avatar
I Ride: Kawasaki ZX636
Hey guys, had a good look around and quite find the info I need. I'm currently running 14 front and 43 rear set up on my 2006 ZX6r, however I now need to buy a new final drive kit as my chain is knackered.
After looking around quite a few forums it seems quite a few people favour going for a 14 front and 45 rear setup (-1, +2). I've had a good play around on the gearing commander website but my question is if I go for this set up will a 110 link chain still be the correct length?
When faced with complete disaster total defiance is the only recourse.
Darren Frost is offline
post #265 of 270 Old 02-27-2017, 06:13 PM
So riding home tonight (2005 ZX636) after refueling only to have my chain fall off. Two hours later my buddy's cousin was able to come by with a trailer to bring my bike home.
I'm looking to buy a new chain, and potentially change sprockets while I'm at it. Any recommendations? Not really sure where to start looking for a new chain. I'll have to check later as to what sprockets are already on it, as I know the PO changed a lot of parts.
yoitschavez is offline
post #266 of 270 Old 02-27-2017, 07:24 PM
This is what I use and recommend:
Sprockets (you can also find them with the OEM number of teeth if you prefer): Vortex Racing Sprocket Kit (-1/+2) for (2005)
Chain: EK Chain 520MVXZ 120 Link Chain
Edit: I also installed a SpeedoHealer to correct the speedometer reading after the gearing change: Speedo Healer 4.0 Kawasaki, ZX-6R (98-04 & 07-09)
post #267 of 270 Old 02-28-2017, 07:37 AM
So I'm semi-familiar with gear ratios and whatnot, I don't fully understand though. When you changed your sprockets, what made you decide to do a (-1/+2)? Is that a popular decision? Is it worth it for city riding?
Thank you!
post #268 of 270 Old 03-01-2017, 08:51 PM
Thank you!
Yes, -1/+2 is actually one of the most popular setups. It gives you better/quicker acceleration and slightly less top speed (e.g. 150ish vs. 165ish for my 2009). I ride in the city, on the freeway, in the twisties, and on the track with this gearing. I also installed a SpeedoHealer to correct the speedometer reading after the gearing change: Speedo Healer 4.0 Kawasaki, ZX-6R (98-04 & 07-09)
If you want to see how the different sprocket sizes will affect the performance of your bike, you can experiment with the numbers here: Gearing Commander: Motorcycle Speed, RPM, Chain & Sprockets Calculator
post #269 of 270 Old 03-02-2017, 02:08 AM
Thank you!
I think one of the reasons for this change being the most common, is that you can use the same length chain. Just takes replacing the sprockets.
Whatever you do, steel sprockets out last anything else.....
post #270 of 270 Old 03-05-2017, 03:50 PM
Cool thanks for the info!
03 zx6r chain and sprocket
08 zx6r chain and sprocket specs
2008 zx6r stock sprocket
2010 zx6r sprockets
chain for ninja zx6r
chain sprokets for kawasaki zx-6r ratio change
kawasaki ninja zx6r sprockets -1 front and 2 rear
kawasaki zx6r stock sprockets
why -1 2 sprockets? zx6r
z chain on zx6r
zx6r 03 front sprocket
zx6r sprocket
Cheap sprockets and chains hellonearth Mechanical and Technical 6 09-02-2013 12:41 AM
Bewildered by new chain and sprockets (with video) GIGM08GT Mechanical and Technical 37 06-03-2013 06:43 PM
Has anyone bought chains from a track day? How bad do chains get used at races? cupofjoe The ZX6R 10 09-30-2011 03:43 PM
04 zx6r oem sprockets ??? sportryder Mechanical and Technical 3 12-24-2010 06:40 PM
RK chains schuler89 The ZX6R 6 04-07-2009 08:14 AM
