Chains & Sprockets - Page 2 - ZX6R Forum
 34Likes
post #16 of 264 Old 08-24-2012, 04:09 PM
Street Hawk's Avatar
I Ride: 2007 ZX6R
I have Sunstar sprockets and they are good. No complaints either.
Street Hawk is offline
post #17 of 264 Old 08-24-2012, 05:10 PM
I Ride: 2009 ZX-6R - track / 2012 ZX-6R - project TBA
Actually I'm pretty sure they torqued mine to 290 foot lbs at the factory.
Yup... I just about killed the battery on a very high powered impact gun trying to get the phucker off!
Originally Posted by djnerek View Post
thanks guys for confirmation on the steel vs aluminum. thats nutty that they want more for the aluminum ones too. less weight=goes faster gimmick i suppose.
sounds like someone doesnt want me to get it done professionally, lol. i do understand the logic of "doing it yourself," but this seems to be something that only needs doing every 5 seasons or so, depending on mileage. plus i dont have all of the tools-just seems like i would almost break even minus knowing how to actually do it myself.
The weight difference isn't enough to make it "faster". What a lighter weight sprtocket gives you is less rotational spinning mass... making "flicking" the bike from left to right and vice versa quicker. Same reason that carbon fiber wheels are used in racing a lot of the time.
As for steel vs. aluminum... You CAN get really good wear out of almuninum if you get the hardened teeth. I changed my stock steel sprocket out at 17,000 miles or so... I currently have about 8000 miles on the Vortex aluminum with hardened teeth with little to no visible wear. (excessive I should say). And I regularly track my bike and ride it pretty hard.
PowerGroove is offline
post #18 of 264 Old 08-25-2012, 08:46 AM
TC636's Avatar
I Ride: 06 kaw 636 and women
Originally Posted by ninjazx6r636 View Post
Hooray! I used the search function!!! Anyways, does anyone know anything about sunstar sprockets??
I've been using sunstar sprockets for a while now. I think they're a really good after market sprocket. And not that expensive either.
i just replaced my chain and sprockets.. and again i went with sunstar.
BALLZEE, GO HARD OR GO HOME
TC636 is offline
post #19 of 264 Old 08-28-2012, 06:33 PM
ely
ely's Avatar
I Ride: 09 ZX6R
i thought i was going to read about sprockets and stuff but i cant stop looking at TC,s avatar its awsome
ely is offline
post #20 of 264 Old 08-28-2012, 06:42 PM
GILBY's Avatar
I Ride: 03 ZX6R
I went with supersprox when I changed mine a few months ago. Im not a good enough rider to tell the difference in weight, but supposedly they are the best of both worlds - Its a 2 pc sprocket, center is aluminum and the teeth are steel. If you take good care of it, they give you a lifetime warranty too. Ive put about 2.5k on mine so far, and they literally look brand new. Oh, Did I mention that they look bad as fuck?
Lvl8Mtrsprts likes this.
'03 ZX6R
-'05 Swinger and Shock -'08 Speedo/Tach -LeoVince Factory Full Exhaust -BMC Race Filter -Factory Pro Velocity Stacks -Driven Block Off Plates -Ram Air Mod -Factory Pro +2 Ignition Advance -PCIII w/Custom Tune(@111hp) -Rifleman Short Throw Throttle Mod -GPR V4 Steering Damper -SuperSprox -1+2 -RK-GB520GXW Chain -EBC HH Pads -StompGrips - Woodcraft Frame Sliders - Puig DB Tinted Screen -CRG Shorties -Smoked Tailight w/Integrated Turns
GILBY is offline
post #21 of 264 Old 08-28-2012, 06:43 PM
I Ride: 03 ninja 636
i want to go back to stock gearing and get a red chain, the previous owner has a stock/+1 i think, vortex rear sprocket, 520 chain, how do i tell how many links i have?
ROLL OUT
trixter2003 is offline
post #22 of 264 Old 08-28-2012, 06:45 PM
Guest
I Ride: 06 R1, 01 YZ250
Wow good lookin out. I'm checkin those asap.
Corvus is offline
post #23 of 264 Old 09-07-2012, 08:36 PM
Kitty Kat's Avatar
I Ride: '05 Silver Kawasaki Ninja 636 zxr
Hey guys, I'm replacing my chain and sprockets this week as well. I want to buy my own and have the shop switch them out. I have steel vortex sprockets right now and I see that 16 front and 43 rear are the ones to buy. What about a chain? What is the best brand to buy, or some of the best brands? I have a 525 racing chain on it now but I hear a 520 is bigger and better. I ride hard and about 2-3 times a week, so I need something that can keep up. Just looking for some info, so any help would be awesome!!!
Kitty Kat is offline
post #24 of 264 Old 09-07-2012, 08:48 PM
Guest
I believe 15/43 was actually OEM for the 2005, but I may be off. Make sure you get the front and rear at the same time when you get a chain.
Some of the best brands of chains are EK, DID, and RK. One of the best performance chains you can get for hard use now would be a EK ZZZ 520.
520 is just the pitch of the chain. It would actually be smaller than 525 and 530 would be larger. 520 is fine for 600cc bikes though.
I'd go with steel front/rear sprockets and an EK ZZZ in 520.
MajinIdo and Kitty Kat like this.
Corvus is offline
post #25 of 264 Old 09-14-2012, 05:21 PM
NEPAzx6r's Avatar
I Ride: 2005 ZX6R
i'm thinking about changing up my sprockets and chain this winter and i was looking for something i can pick up into a wheelie real easily without sacrificing the ability to crank on it in second. basically want to get a good wheelie bike while it can still be a good bike to cruise around on. any ideas on a sprocket and chain set up or where i can get one?
NEPAzx6r is offline
post #26 of 264 Old 09-15-2012, 09:34 AM
Uvedoneitnow's Avatar
I Ride: 2012 ZX-6R
I have a 2012 and I am looking into replacing my sprickets and chain. Never regeared a buke before and I think I'm gonna do a 15tooth/43 tooth. My question is when ordering the chain how do know the amount of links i need?
2012 ZX-6R with M4 GP Slip-On/ 8K DDM 35W HID'S/ Two Brothers Fender Eliminator/ Shogun Frame Sliders, Bar Ends, and Swingarm Spools/ Jumper Mod/ Seat Cowl
Uvedoneitnow is offline
post #27 of 264 Old 09-22-2012, 08:19 AM
01blueninja's Avatar
I Ride: 2006 zx6r
Any one know the OEM size sprockets for an 01
01blueninja is offline
post #28 of 264 Old 09-22-2012, 12:52 PM
I Ride: 2006 zx6r
Oh and can someone explain how the different sizing works?
post #29 of 264 Old 09-22-2012, 01:02 PM
by decreasing the number of teeth of the front sprocket and/or increasing the rear you are adding torque. You will run at higher RPM's making you closer to the power band most of the time. You lose top speed but gain quickness.
To give you an idea... stunt bikes need to have a lot of torque to get be able to quickly snap the front wheel off of the ground.... so on most all stunt bikes you'll see a HUGE rear sprocket.
post #30 of 264 Old 09-22-2012, 06:25 PM
nomorechickenscratch's Avatar
I Ride: ZX6R MONSTER EDITION 09
down 1 in front, up 2 in rear...u wont regret it,, extra low end torque...no involuntary wheelies, but easier to clutch wheelie if that is your thing..2nd gear wheelies....WHO CARES IS YOU LOSE 10MPH ON TOP END SPEED...WHAT REALLY IS THE DIFFERENCE WHEN U R GOING 175 TO 165...SAME THING
nomorechickenscratch is offline
03 zx6r chain and sprocket
08 zx6r chain and sprocket specs
2008 zx6r stock sprocket
2010 zx6r sprockets
chain for ninja zx6r
chain sprokets for kawasaki zx-6r ratio change
kawasaki ninja zx6r sprockets -1 front and 2 rear
why -1 2 sprockets? zx6r
z chain on zx6r
zx6r 03 front sprocket
zx6r race chain sprokets
zx6r sprocket
Cheap sprockets and chains hellonearth Mechanical and Technical 6 09-02-2013 01:41 AM
Bewildered by new chain and sprockets (with video) GIGM08GT Mechanical and Technical 37 06-03-2013 07:43 PM
Has anyone bought chains from a track day? How bad do chains get used at races? cupofjoe The ZX6R 10 09-30-2011 04:43 PM
04 zx6r oem sprockets ??? sportryder Mechanical and Technical 3 12-24-2010 07:40 PM
RK chains schuler89 The ZX6R 6 04-07-2009 09:14 AM
