Chains & Sprockets - Page 3 - ZX6R Forum
 34Likes
post #31 of 264 Old 09-22-2012, 06:40 PM
I Ride: 03 ninja 636
it also messes up ur milage, and fuel economy, smaller sprocets, better gas, big sprockets, poor gas, my light came on at 100 miles
ROLL OUT
trixter2003 is offline
post #32 of 264 Old 09-24-2012, 11:28 AM
I Ride: zx6r
Sprocket and chain question
This is my first reply/ post as I just joined. I have an 08 zx6r. I just changed over to a 15/45 Supersprox front and rear sprocket set with a RK 520, 112 link, x-ring chain from the OEM chain and OEM 16/43 sprocket set. The set was purchased from Supersprox as a set. I also installed a SpeedoHealer v4 to correct the speedometer error.
The install went as planned. Everything is torqued per spec, the axle is plumb on both sides so the chain is aligned and the chain tension was checked in-spec. With the sprocket change the engine RPM is higher as is normal due to the gear change. The bike rides fine however there is now pronounced chain noise when the rear wheel is turning. This occurs under power or by just turning the rear wheel by hand when it is up on the rear stand. It is coming from the front sprocket as the chain wraps around it. There is no binding or noticeable misalignment between the chain and the front sprocket. I loosened everything up this w/e and pulled the chain off the rear wheel and veriifed that the front sprocket is not the cause of the noise: it spins freely and noiselessly by hand. There was no noticeable or abnormal wear on the teeth that would indicate misalignment. I put everything back together and tried adjusting the slack on the chain both tighter and looser and even skewed the axle alignment to see if that would quiet it down. In conclusion the bike is back to when I did the changeout and the chain whirring/noise is still present.
I don't know if this is normal with a sproket change due to the front sprocket turning faster or what. All other indicators are normal, no driveline issues other than the noticeable, chain whirring noise that wasn't there with the OEM set-up. Is this a big deal or just something new to get used to? Thanks for the help...
spinhead is offline
post #33 of 264 Old 09-24-2012, 02:11 PM
01blueninja's Avatar
I Ride: 2006 zx6r
Originally Posted by PowerGroove View Post
by decreasing the number of teeth of the front sprocket and/or increasing the rear you are adding torque. You will run at higher RPM's making you closer to the power band most of the time. You lose top speed but gain quickness.
To give you an idea... stunt bikes need to have a lot of torque to get be able to quickly snap the front wheel off of the ground.... so on most all stunt bikes you'll see a HUGE rear sprocket.
Ok, so then how do you know how many links to get? Is there some kind of calculator?
01blueninja is offline
post #34 of 264 Old 09-24-2012, 02:13 PM
Guest
I Ride: 06 R1, 01 YZ250
Gearing Commander: Motorcycle Speed, RPM, Chain & Sprockets Calculator
lv2h8me likes this.
Corvus is offline
post #35 of 264 Old 09-24-2012, 02:20 PM
I Ride: 2006 zx6r
Thanks corvus... Im not sure what I would ever do without you?
post #36 of 264 Old 09-24-2012, 02:23 PM
Guest
Buy the wrong shit? Hahaha
WhyMista and Dale W2 like this.
Corvus is offline
post #37 of 264 Old 09-24-2012, 02:24 PM
I Ride: 2006 zx6r
Holy crap, how the hell do you work that thing?
post #38 of 264 Old 09-24-2012, 02:27 PM
Guest
Bike model goes in top dropdowns. Make sure you select N I N J A for model. Then get your year and hit load gearing. That will load up all of your OEM infoitch, teeth, and links, etc. You can then play with current or custom settings to see what effect changing sprockets and stuff would have on everything. Pretty comprehensive tool.
lv2h8me likes this.
Corvus is offline
post #39 of 264 Old 09-24-2012, 02:34 PM
I Ride: 2006 zx6r
Ahhh, thats why, i put zx and nothing happened.
post #40 of 264 Old 09-24-2012, 02:38 PM
I Ride: 2006 zx6r
Ok, so heres another question. If i change to a 520 instead of a 525 will that change the number of links?
post #41 of 264 Old 09-24-2012, 02:43 PM
Guest
Don't. 520, 525, and 530 indicates pitch. You don't need to change that or move up from a 520 for street 600cc applications.
But, to answer your question, no I don't think it would change the number of links. You do have to match the pitch between the chain and front and rear sprocket also.
Corvus is offline
post #42 of 264 Old 09-24-2012, 02:58 PM
I Ride: 2006 zx6r
In the site you gave me it says the pitch is .625. Shouldnt it say .525?
post #43 of 264 Old 09-24-2012, 06:09 PM
ninjazx6r636's Avatar
I Ride: 2013 green-black zx6r 636
I might be dumb asking but isn't 520,525,530 the thickness of the chain?
2013 Green/black 636 - stock
ninjazx6r636 is offline
post #44 of 264 Old 09-24-2012, 06:18 PM
Guest
Yeah, the tensile strength they can handle also. 520 thinner and less strength, 530 thicker more tensile strength
Corvus is offline
post #45 of 264 Old 09-24-2012, 06:19 PM
ok thanks bud!
03 zx6r chain and sprocket
08 zx6r chain and sprocket specs
2008 zx6r stock sprocket
2010 zx6r sprockets
chain for ninja zx6r
chain sprokets for kawasaki zx-6r ratio change
kawasaki ninja zx6r sprockets -1 front and 2 rear
why -1 2 sprockets? zx6r
z chain on zx6r
zx6r 03 front sprocket
zx6r race chain sprokets
zx6r sprocket
Cheap sprockets and chains hellonearth Mechanical and Technical 6 09-02-2013 01:41 AM
Bewildered by new chain and sprockets (with video) GIGM08GT Mechanical and Technical 37 06-03-2013 07:43 PM
Has anyone bought chains from a track day? How bad do chains get used at races? cupofjoe The ZX6R 10 09-30-2011 04:43 PM
04 zx6r oem sprockets ??? sportryder Mechanical and Technical 3 12-24-2010 07:40 PM
RK chains schuler89 The ZX6R 6 04-07-2009 09:14 AM
