Chains & Sprockets - ZX6R Forum
 36Likes
post #1 of 270 Old 03-14-2012, 03:23 PM Thread Starter
djnerek's Avatar
I Ride: 08 kawi green zx6r
Chains & Sprockets
gonna say first of all that i searched all over the place, and got a few different answers, so im gonna ask you guys to get the RIGHT answer.
from my research, ive concluded that the stock sprockets on my 08 zixsix are as follows: 16 front, 43 rear. correct? or am i wrong?
also, the chain appears to be a 520 x chain?
i am looking at replacing sprockets and chain in the next week or so, and wanted to make sure these were the correct specifications. call me a sally, but im probably going to keep the stock sprocket sizes, as i like how my bike performs currently. i also figure that would be the easiest on chain/sprocket wear. could be wrong about that tho....
any suggestions brand-wise would be much appreciated.
KawiGreen06 likes this.
mods: two bros m5 slip-on, mjs performance headers, two bros juicebox, k&n air filter, 12k ddm tuning HID kit (low and high), frame sliders, puig tire hugger, relocated back brake reservoir, jt sprockets (stock sizing), rk gold chain, de-badged, speedo drd, green leds inside fairings, sportbikelites integrated brake light, ebay levers (shorties) .....whats next
djnerek is offline
post #2 of 270 Old 03-14-2012, 03:40 PM
Street Hawk's Avatar
I Ride: 2007 ZX6R
Those specs are correct. Whatever you get, dont get the super lightweight ones. They wear out faster. D.I.D. is okay for a chain brand. Not sure what sprockets I have. I cant remember. Sprocket and chain wear depends on your maintenance. I kept stock size when I got my sprockets.
If you get a chain tool get the "motion pro" tool# 13193. Its good.
Torque wrench that can do at least 94ft pnds.
Make sure you have a 27mm long socket for the front sprocket removal. Its 90ft pnds.
Each rear sprocket nut is 43ft pnds. The rear axle nut is 94ft pnds.
How many miles do you have on that girl?
Street Hawk is offline
post #3 of 270 Old 03-14-2012, 04:10 PM Thread Starter
djnerek's Avatar
thanks for the confirmation.
i believe i have somewhere around 9k on it atm. if im not mistaken, it still has the stock sprockets/chain on it GASP. which is why i think its a good idea to replace them. when you say lightweight, are you referring to the aluminum ones? should i stick with steel?
honestly, ive never even taken the back wheel off, so im a little nervous to mess with the chain and sprockets. i am in the market for new tires as well, so ill pry get it all banged out at a shop somewhere...
djnerek is offline
post #4 of 270 Old 03-14-2012, 05:53 PM
zx racer's Avatar
I Ride: 04 ZX-636
stick to steel sprockets they last ALOT longer than aluminum ones.
DaddysNinja, MDeezy and AlexZX6R like this.
zx racer is offline
post #5 of 270 Old 03-14-2012, 05:57 PM
trackdayhero's Avatar
Actually I'm pretty sure they torqued mine to 290 foot lbs at the factory.
rtrofimovich and astcyr17 like this.
trackdayhero is offline
post #6 of 270 Old 03-14-2012, 06:08 PM
I Ride: 2007 ZX6R
Seems like it, uh. LOL
And yeah djnerek go steel. No aluminum. If its your first time then reserve the entire weekend for it. Have fun. Make sure you have some sort of breaker bar for that front sprocket. shes tough. And download the service manual from this site. You might need it.
post #7 of 270 Old 03-14-2012, 08:11 PM Thread Starter
djnerek's Avatar
thanks guys for confirmation on the steel vs aluminum. thats nutty that they want more for the aluminum ones too. less weight=goes faster gimmick i suppose.
sounds like someone doesnt want me to get it done professionally, lol. i do understand the logic of "doing it yourself," but this seems to be something that only needs doing every 5 seasons or so, depending on mileage. plus i dont have all of the tools-just seems like i would almost break even minus knowing how to actually do it myself.
djnerek is offline
post #8 of 270 Old 03-15-2012, 04:22 PM Thread Starter
djnerek's Avatar
went to the shop today to get an estimate, guy said he would throw two pirelli diablos, front and rear sprockets, did chain on for little over $550. seems legit.
djnerek is offline
post #9 of 270 Old 03-15-2012, 04:34 PM
Buy yourself a 27mm socket with a suitable breaker bar (or torque wrench if you must) and a metric 1/4 or 3/8 drive socket set, thats all you will need to do the job, you will likely have a lot of use for these further down the line...
Therapyrider likes this.
AndyP123 is offline
post #10 of 270 Old 03-16-2012, 07:49 AM
I Ride: '06 ZX6r
That's a reasonable price I think for a professional shop, if you don't already have the sprockets and chain. I recently finished doing the chain/sprockets removal/install for the first time. Took me longer than I expected and yes that front sprocket is difficult.
If you don't have all the tools already it may cost you close to that price to get what you need but in the long run it will all pay for itself. Up to you really, do the maintenance and then transport it to the shop to get looked over after each job until confidence is built.
klownface is offline
post #11 of 270 Old 03-19-2012, 08:19 PM Thread Starter
djnerek's Avatar
k, picked up some power 2cts (the tire part of my quest) and i am having the HARDEST time finding chain and sprocket kit. im having some friends do the work (i will be observing so i can do it next time) and i want to make sure i get the right stuff. i ran into a kit by reginal, but it came with a Z chain. dennis kirk said it fit my bike, but i was under the impression that i needed a x chain? am i mistaken?
djnerek is offline
post #12 of 270 Old 08-19-2012, 11:26 PM
zand3r's Avatar
I Ride: `92 GPZ500 (sold) `08 ZX6R
Help Choosing sprockets
Want to order a 15T/45T sprocket set from Amazon (easy to pay for here)
But having issues deciding on a model.
Amazon.com: 15T front sprocket vortex zx6 2007
The search query lists 4 different model sprockets, how do you choose which one you want?
Same question applies to the rear sprocket.
Official property of CelticStar
zand3r is offline
post #13 of 270 Old 08-24-2012, 01:57 PM
ninjazx6r636's Avatar
I Ride: 2013 green-black zx6r 636
Hooray! I used the search function!!! Anyways, does anyone know anything about sunstar sprockets??
DaddysNinja likes this.
2013 Green/black 636 - stock
ninjazx6r636 is offline
post #14 of 270 Old 08-24-2012, 02:38 PM
MOTOcityride's Avatar
I Ride: 09 zx6r 06 cbr1k
my front sprocket is sunstar. no complaints so far. bought it because it was cheap.
Originally Posted by givuhcky22 View Post
ER is for pregnant chicks.
i've got a broken vertebrae. guess who's still lifting, riding, hip thrusting, party rocking, and more lifting.
MOTOcityride is offline
post #15 of 270 Old 08-24-2012, 02:56 PM
Vitamin C's Avatar
I Ride: 04 636
Sprocketcenter.com
Vitamin C is offline
03 zx6r chain and sprocket
08 zx6r chain and sprocket specs
2008 zx6r stock sprocket
2010 zx6r sprockets
chain for ninja zx6r
chain sprokets for kawasaki zx-6r ratio change
kawasaki ninja zx6r sprockets -1 front and 2 rear
kawasaki zx6r stock sprockets
why -1 2 sprockets? zx6r
z chain on zx6r
zx6r 03 front sprocket
zx6r sprocket
Cheap sprockets and chains hellonearth Mechanical and Technical 6 09-02-2013 12:41 AM
Bewildered by new chain and sprockets (with video) GIGM08GT Mechanical and Technical 37 06-03-2013 06:43 PM
Has anyone bought chains from a track day? How bad do chains get used at races? cupofjoe The ZX6R 10 09-30-2011 03:43 PM
04 zx6r oem sprockets ??? sportryder Mechanical and Technical 3 12-24-2010 06:40 PM
RK chains schuler89 The ZX6R 6 04-07-2009 08:14 AM
