ZX6R.com
troubles pulling codes for FI light
This is a discussion on troubles pulling codes for FI light within the Mechanical and Technical forums, part of the ZX6R Forum category; FI light on my 03rr track bike comes on after its been moving but not just idling. goes away when you turn it off and ...
Old 03-22-2012, 08:30 PM   #1
sag
FI light on my 03rr track bike comes on after its been moving but not just idling. goes away when you turn it off and start it back up. im having trouble pulling the codes as nothing is happening when i ground the diag wire. neither dealer modes work. i am touching the connector straight to the ground (should work right?) anyways, any other tips? the bike does have a power commander, i dunno if those mess things up? i searched and only got posts with responses where people told them to search.
sag is offline
Remove Ads
Old 03-22-2012, 11:01 PM   #2
Super Moderator
MistressOfMayhem's Avatar
I Ride: 04 ZX6-R, 04 ZX6-R Track bike, 07 R6, 09 DRZ400S
According to my manual:
•Remove the seats (see Frame chapter) and pull the self
-diagnosis terminal [G].
•Turn on the ignition switch.
•Connect an auxiliary a lead [E] for grounding to the self
-diagnosis terminal.
To enter the self-diagnosis dealer mode 1 ground [A] the
self-diagnosis indicator terminal to the ground for more
than 2 seconds [C], and then keep it grounded continuously
[D].
○Count the blinks of the LED light to read the service code.
Keep the auxiliary lead ground until you finish reading the service code.
•[B]To enter the self-diagnosis dealer mode 2 repeat opening
and grounding [A] the lead more than five times [F]
within 2 seconds [C] after the lead is first grounded, and
then keep it grounded continuously [D] for more than 2
seconds.
service code.
NOTE
○If the self-diagnosis mode is in dealer mode 1 then you
need to enter the dealer mode 2, turn off the ignition
switch once.
MistressOfMayhem is offline
Old 03-23-2012, 04:20 AM   #3
ZX6RRECTION's Avatar
I Ride: Green'06 ZX6-RR(:-(sold) 05 ZX6RR
Yah like mom said check procedure
Ru grounding it to the battery neg terminal? Or known ground contact point
Also what are you using to extend(or connect) the diagnos lead to ground?
ZX6RRECTION is offline
Old 03-23-2012, 07:56 PM   #4
sag
i just touched the diag wire straight to the terminal, pulling back the rubber cover. i got it though, just turned the bike on. it wouldnt do it just key on like i thought it was supposed to
sag is offline
Old 03-24-2012, 04:35 AM   #5
Street Hawk's Avatar
I Ride: 2007 ZX6R
It could just be the speed sensor on the front sprocket cover. Is that connected? That will make your F light come on only when in motion not idling.
Street Hawk is offline
Old 03-24-2012, 07:40 AM   #6
ok cool, so you pulled the codes
thats wassup,
Old 03-24-2012, 05:22 PM   #7
sag
ding ding ding. it was ziptied out of the way because there is no front sprocket cover lol
sag is offline
Everything you need to know about HID / Xenon Steve Motorcycle Talk 31 02-06-2013 07:00 PM
How To Pull FI Codes EvilTwin Guides 30 06-11-2012 10:08 AM
Tail Light electrical problems 2201436 Mechanical and Technical 11 12-17-2011 06:53 PM
Tail light doesnt work Erik Mechanical and Technical 10 10-30-2011 01:44 PM
