FAQ: Basic Maintenance - ZX6R Forum
 24Likes
post #1 of 53 Old 03-31-2012, 05:35 PM Thread Starter
oKayH's Avatar
Exclamation FAQ: Basic Maintenance
This Frequently Asked Questions (FAQ) thread is dedicated to showing general guidelines to performing basic maintenance task required to keep your bike in running order. For full procedures and information for your specific bike, please consult the service manual section (Service Manuals - ZX6R Forum) for the service manual.
** If you would like to contribute a relavent or better instructional or correct information, please PM me. **
Oil Change
Coolant Change
Cleaning & Lubricating your chain
Chain adjustment
Brake bleeding
Clutch & throttle cable lubrication
Lifting & Supporting your bike
* These are simply aids to help you complete a task. You are completely responsible for your bike and anything you decide to do to it
CCS EX
More gas, less brake
oKayH is offline
post #2 of 53 Old 03-31-2012, 05:36 PM Thread Starter
oKayH's Avatar
Oil Change
Basic Motorcycle Maintenence Oil and Oil Filter Change Part 5/5 - YouTube
Notes:
  • A cup filter wrench will make the job a lot easier on certain models. You can obtain the tool for several bucks from an auto store and it is a 14 flute, 65mm cup.
  • If you elect to do the DIY "screwdriver method" of removing the oil filter, be careful as you could damage some expensive parts if you drive the screwdriver in the wrong spot.
Coolant Change
**COMING SOON**
CCS EX
oKayH is offline
post #3 of 53 Old 03-31-2012, 05:36 PM Thread Starter
oKayH's Avatar
Chain Cleaning & Lubricating
How To Clean & Lube Your Motorcycle Chain - YouTube
Note: DO NOT do this with the bike on and in gear. Why? Ask him: How NOT to clean your chain. **GRAPHIC PICS*** : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Chain Adjustment
How To Adjust Your Motorcycle Chain - YouTube
steffydog and HIGHDEFMOTO like this.
CCS EX
oKayH is offline
post #4 of 53 Old 03-31-2012, 05:36 PM Thread Starter
oKayH's Avatar
Brake bleeding
Motorcycle Brake Bleeding Procedure from Sportbiketrackgear.com - YouTube
HIGHDEFMOTO likes this.
CCS EX
oKayH is offline
post #5 of 53 Old 03-31-2012, 05:36 PM Thread Starter
oKayH's Avatar
Clutch & Throttle cable lubrication
How to - Lube your motorcycle clutch cable. - YouTube
Lubing motorcycle throttle cable ('08 Kawasaki ZX6R by example) - YouTube
CCS EX
oKayH is offline
post #6 of 53 Old 03-31-2012, 05:36 PM Thread Starter
oKayH's Avatar
Clutch & Throttle Cable Adjustment
Throttle Cable Adjustment - YouTube
http://www.youtube.com/watch?v=hW6NVS6_9yo
CCS EX
oKayH is offline
post #7 of 53 Old 03-31-2012, 05:36 PM Thread Starter
oKayH's Avatar
Lifting & Supporting Your Bike
To perform many maintenance items on your bike such as lubricating and adjusting your chain or changing tires you will need to get the bike off the ground. That side kickstand just will not cut it. Also, most modern sportbikes do not come equipped with a center stand such as bikes from yestertime. There are several ways to get the bike supported.
Rear stand
Every motorcycle owner should own this type of stand. This will make many frequent task such as cleaning and lubricating your chain a snap. When selecting a motorcycle stand, you must decide if you want to use a spooled type or non-spooled type of stand. Pictured above is a spooled type of stand. The stand lifts the bike from swingarm attachments that bolt right into manufacture provided holes. The spools in question are below:
Another option is to use a non-spooled stand. This type of stand will lift from the swingarm itself instead of spools attached to the swingarm. This type of stand is pictured below:
Front stand
CCS EX
oKayH is offline
post #8 of 53 Old 03-31-2012, 05:37 PM Thread Starter
oKayH's Avatar
Reservedreservedreserved
reservedreservedreserved
reserved
CCS EX
oKayH is offline
post #9 of 53 Old 03-31-2012, 06:04 PM
bikerben's Avatar
Location: mildura, Australia (small town with no twisties)
I Ride: 95 zx6r
Great work okay
bikerben is offline
post #10 of 53 Old 03-31-2012, 10:46 PM
HotIce's Avatar
I Ride: BMW S1000R
Nice Job! I'll have to go get the wrench cup and hope that opens the filter up. I didn't have a crush washer with the 17mm bolt that lets the oil out. Is it necessary?
HotIce is offline
post #11 of 53 Old 04-01-2012, 06:32 AM Thread Starter
oKayH's Avatar
Yes, go grab a washer for the oil pan bolt before you put it back on. Bike shops stock them and possibly auto stores.
CCS EX
oKayH is offline
post #12 of 53 Old 04-01-2012, 06:33 AM
JustModawgIt's Avatar
I Ride: 07 ZX6R
I reuse mine, probably not the best advice, but its never failed me yet.
Tracker3 likes this.
JustModawgIt is offline
post #13 of 53 Old 04-01-2012, 07:13 AM
blazenorange's Avatar
I Ride: '14 Daytona 675r
Okay.. U should add, how to adjust clutch and throttle cable.
blazenorange is offline
post #14 of 53 Old 04-01-2012, 07:47 AM Thread Starter
oKayH's Avatar
Find a video or make a how to and we can expedite adding that . Just PM it to me and i'll put it in
I'll find one tonight if not tho, no worries.
CCS EX
oKayH is offline
post #15 of 53 Old 04-01-2012, 07:49 AM
I figured it would of been a good addition to your thread...
06zx6r 636 change coolant
2007 zx6r maintenence and adjustment
basic maintenance 2004 zx6r
how to maintenance zx6r
maintenance on a 2012 zx6r
zx-6r faq
zx6r basic maintenance
zx6r chain maintainance forum
2k mile maintenance kninja Mechanical and Technical 14 08-27-2012 10:25 PM
FAQ threads oKayH Motorcycle Talk 9 03-31-2012 05:37 PM
Maintenance for J? anjos Mechanical and Technical 7 02-09-2012 08:55 AM
Maintenance 1st time owner demarco75 The ZX6R 9 02-27-2009 06:27 PM
