Clutch cable replace? - ZX6R Forum
post #1 of 17 Old 04-30-2012, 06:08 AM Thread Starter
I Ride: ZX6 09
The clutch cable has started to fray a little, where it connects to the lever. Do you think it needs replacing now?
Does not look like a hard job, any advice? I notice if I do not have the correct tension, the bike will not start in gear or have trouble starting. Do I need to adjust the nuts down by the clutch for ideal tension?
ZX6 09 BLACK. MGP GROWLER, PINE BOX LINK PIPE, JUICE BOX PRO, SHORTY LEVERS, RACE BRAIDED LINES, FULL HID KIT, R&G FRAME SLIDERS, R&G TAIL TIDY, LEDICATORS.
bcroninuk is offline
post #2 of 17 Old 04-30-2012, 06:13 AM
Manolo's Avatar
yes, must replace... my clutch cable looked like that and the day i replaced it, it finally snapped... also very easy to replace... remove the mid fairing and you'll see what you have to do... after replacing buy the cable lube and the tool as well
| Akrapovic Ti Evo | BMC Race Air Filter | Brembo RCS19 Master Cylinder | ECUnleahsed | Galfer Wave Rotors | Goodridge Superbike Pro Racing Brake Line Kit | Healtech Speedohealer | Jumper Mod | Kleen Air Mod | Motion Pro Revolver Throttle Kit | Ohlins 30mm Cartridge Kit & TTX Shock | Power Commander 5 | Ram Air Mod | Renthal Clip Ons & Kevlar Grips | Scotts Damper | Vortex -1/+3 Sprockets & Rearsets | Woodcraft Frame Slider |
Tuned 120.12 HP 46.58 FT LB Torque
Manolo is offline
post #3 of 17 Old 04-30-2012, 06:19 AM Thread Starter
I Ride: ZX6 09
cheers buddy.. read the manual, says 4-6 mm thread showing on the adjuster by the lever then tighten both bolts down below. Looks very easy so will get it done! thanks
post #4 of 17 Old 04-30-2012, 02:17 PM
empirezx6r's Avatar
you can do it without moving any fairings... just loosen the right side mid fairing, and snake the new cable the same way the current cable is... super easy fix.
2007 zx6r
2009 14
45 stay alive
empirezx6r is offline
post #5 of 17 Old 04-30-2012, 05:29 PM Thread Starter
I Ride: ZX6 09
do i need to lube the cable.. never done it before... does it come lubbed when i buy a new one?
post #6 of 17 Old 04-30-2012, 05:30 PM
MotoHavoc's Avatar
I Ride: 2006 ZX6R
Should be pre lubed I believe but I always do it anyway to my cables for good measure
06 ZX6R 636
Website - http://track-habit.com/
Track bike Build:http://zx6r.com/racing/25830-convert...ck-weapon.html
Two Bros. Dual Carbon Exhaust, 6k HID's, sliders, red progrips, -1 +3 sprockets with gold DID chain, 2010 zx6r M/C and calipers w/ braided lines, shorty levers, rearsets, red wheels, custom paint and a few other mods and a ton of fun
MotoHavoc is offline
post #7 of 17 Old 04-30-2012, 05:36 PM
AUaviator's Avatar
I Ride: 2003 zx6r 636 (sold), 2009 CBR600rr green edition
No you have to lube it yourself. Buy the 10 or so dollar tool and spray it in till you see lube come out the other end.
How to - Lube your motorcycle clutch cable. - YouTube
“Courage is doing what you're afraid to do. There can be no courage unless you're scared."
Edward Vernon Rickenbacker, WW1 pilot and ACE
AUaviator is offline
post #8 of 17 Old 04-30-2012, 05:55 PM
863JOE's Avatar
Happened to me a couple months ago. Didn't wait to find out how much longer it would last, replaced it that day.
863JOE is offline
post #9 of 17 Old 05-01-2012, 06:18 AM Thread Starter
I Ride: ZX6 09
Can I use chain lube or a any lubricating oil? Or do I have to buy something special. Will the cable last longer if its lubed? Can understand lubing a chain, but never heard of lubing a clutch cable...
post #10 of 17 Old 05-01-2012, 06:23 AM
bikerben's Avatar
Location: mildura, Australia (small town with no twisties)
I Ride: 95 zx6r
If you don't replace you will regret when it snaps and your not at home
Happened once and in a bind I used a standard by cycle cable as it was a long way from home was a part in the arse but I managed to limp it home
bikerben is offline
post #11 of 17 Old 05-01-2012, 06:33 AM
AUaviator's Avatar
Get a lube that is safe for cables (Wal-Mart or an Auto-Zone like store will have it). All it does is reduce the friction between the cable and tube that it is in. Will last MUCH longer. If you dont, it'll take about 2 months till your buying a new one.
post #12 of 17 Old 05-01-2012, 06:39 AM Thread Starter
I Ride: ZX6 09
Ah ok, I got 8000 miles out of this one from a new bike. Will have a look around and find something. thanks for the help.
post #13 of 17 Old 05-01-2012, 06:42 AM
Manolo's Avatar
you'll find what u need in any motorcycle shop
Manolo is offline
post #14 of 17 Old 05-01-2012, 06:59 AM
Steel's Avatar
I Ride: 2004 ZX6RR
Mine did this not even a month ago, it never snapped (thankfully), because I rode around on it for about 2 weeks while waiting on a cable to ship to me from amazon. I just took it to a shop since I didn't have any tools and was having my chain/sprocket replaced as well, it was a 1/2 hour billed labor.
Steel is offline
post #15 of 17 Old 05-04-2012, 06:36 AM Thread Starter
I Ride: ZX6 09
All done, easy job. Just waiting for my lube tool to come. Been told to use any lubricating oil, even wd40.
2008 kawasaki zx6r clutch cable fraying
2008 kawasaki zx6r clutch cable install
2009 zx6r clutch cable
95 zx6r clutch cable
97 ninja change clutch cable
clutch adjustment kawasaki 2006 zx6r636
clutch cable for 2006 zx6 how much
how much is clutch cable for zx6
how much to replace a clutch cable on a 03 ninja zx6r
how to change clutch cable kawasaki
what clutch cable can you use on a 2002 kawasaki zx6r
zx6r clutch cable
Clutch Cable ZXR 6 2004 Gashleyman Mechanical and Technical 1 02-27-2012 02:16 PM
How to install a clutch cable? NinjaBlazin Mechanical and Technical 2 05-15-2011 11:32 PM
Clutch cable issue help blazenorange Mechanical and Technical 19 03-31-2011 04:37 PM
The Frayed Clutch Cable....Two Questions Armadillo The ZX6R 4 12-13-2009 09:22 AM
new member, used 96 zx6r, NEED clutch cable help djjsin The ZX6R 3 05-16-2009 08:44 AM
