Valve Adjustment FORM - Page 2 - ZX6R Forum
 4Likes
post #16 of 20 Old 01-28-2016, 10:04 AM
SaugaCityZx6's Avatar
I Ride: 2015 Kawasaki Zx6r
after how many km on a brand new bike should i do valve adjustments ?
SaugaCityZx6 is offline
post #17 of 20 Old 01-28-2016, 10:37 AM
I Ride: 2009 ZX-6R - track / 2012 ZX-6R - project TBA
Look in your owners manual at the maintenance schedule.
PowerGroove is offline
post #18 of 20 Old 10-05-2016, 01:15 AM
Modified the original form to do the calculations for you. Its also laid out more in-line with the current ZX6R engine layout if looking from behind the bike. It will open to the instruction page first. The worksheet is on the second tab. I've added some more fields in hopes that it will make it easier. It can be used as a manual sheet, but if you take the data and enter it into the spreadsheet, it will check your numbers. If anyone finds and problems or has any suggestions, let me know and I'll see what I can do.
File Type: zip 2016-10-03-Active Valve Adjustment Form.zip (12.5 KB, 20 views)
CKwik240 is offline
post #19 of 20 Old 11-27-2016, 01:50 AM
CheekyMonkey's Avatar
I Ride: 2007 Kawasaki ZX6R
I have an issue with getting cylinder #4 at TDC I have #1 at TDC right now but it won't turn counter-clockwise or clockwise anymore. Anyone know what's up?
CheekyMonkey is offline
post #20 of 20 Old 11-28-2016, 03:29 AM
BTW I have checked the engine is in neutral clearances on the valves are running 0.038?
03 636 valve clearance
03 zx6r valve adjustment
03 zx6r valve clearances
2006 kawasaki 636 valve clearance
2009 zx6r valve
2009 zx6r valve adjustment
2009 zx6r valve clearances
2012 zx6r valve adjustment cost
valve adjustment form
valve clearence form
zx6r 2009 valve tools
zx6r form
valve adjustment cyclewerkes The ZX6R 10 05-09-2013 06:52 PM
2006 zx6r 636 15k mile valve adjustment Emanuel2b Mechanical and Technical 11 07-26-2012 08:53 AM
Price for a valve adjustment treyzx Mechanical and Technical 11 06-09-2012 03:43 PM
valve adjustment how come....? TexMex Mechanical and Technical 15 02-17-2012 08:50 PM
how important is valve adjustment? TexMex Mechanical and Technical 1 11-13-2011 10:03 PM
