Will a 09 zx6r rear shock fit a 06 zx6r ?? - ZX6R Forum
post #1 of 4 Old 08-11-2012, 12:55 PM Thread Starter
bod
bod's Avatar
I Ride: kawasaki zx636r c6f
Hi guys just wondered iff a 09 zx6r rear shock will fit a 06 zx6r and iff so is there any advantages over standard 06 rear shock...
KAWI ZX6R 06 636
CARBON FIBRE AIRBOX TANK COVER,CARBON FIBRE SWINGARM COVERS,CARBON FIBRE HUGGER,CARBON FIBRE MUDGUARD,CARBON FIBRE CHAIN GUARD,CARBON FIBRE ENGINE COVERS,CARBON FIBRE DASH PANELS,CARBON FIBRE FRAME PROTECTORS,CARBON FIBRE DECALS,BREMBO MASTER,ZZR1400 FRONT CALIPERS,ZX6R 2014 310MM DISCS,HEL BRAKE LINES,EBC SINTERED PADS,PAZZO SHORTY LEVERS,GALFER WAVY REAR DISC,POWERCOMMANDER3 WITH CUSTOM MAP,K&N AIR FILTER,IRIDIUM PLUGS,DE-CAT,ARATA RACE CAN,RAM AIR MOD,08 REAR SHOCK,2012 MIRRORS,SMOKED INDICATORS,HOT BODIES SMOKED SCREEN,GILLES REARSETS,POWERBRONZE GREEN CRASH BUNGS, BIKE REPAINTED KAWI GREEN WITH CARBON FIBRE DECALS AIRBRUSHED..
bod is offline
post #2 of 4 Old 08-20-2012, 12:33 PM Thread Starter
bod
bod's Avatar
Found out the 09 rear shock is the same as a 07/08 so got a low mileage rear shock for her and slapped her on, no modification at all,straight swap,set up everything to hard ish... felt great but problems with turning in, seemed sluggish, not wanting to turn easy into to turns..so put back the 6mm spacer that i removed when i first got her...( as im a short arse) softened shock up a bit, ran out of time so will see how she responds to settings on friday....
KAWI ZX6R 06 636
bod is offline
post #3 of 4 Old 08-20-2012, 12:44 PM
RockerPhotog's Avatar
That's good info to know. I should've swapped mine with a newer one when I swapped springs....
RockerPhotog is offline
post #4 of 4 Old 08-20-2012, 01:05 PM Thread Starter
bod
bod's Avatar
Id red that you had to modify the bottom of the shock for an 08 to fit an 06 zx6r, but it just went straight on no probs..well happy..
KAWI ZX6R 06 636
bod is offline
Would A Gen 1 zx10r shock if my zx6r!! zx6r boy Mechanical and Technical 0 05-15-2012 01:34 PM
Do 2003 zx6r wheels fit a 2002 zx6r Jap Mechanical and Technical 3 04-22-2012 11:29 PM
rear suspension/ shock query zx6r A1P 636 thegreensnot Mechanical and Technical 15 01-05-2012 01:10 PM
07 Tyre huger fit on 06 ZX6R? Onetap Mechanical and Technical 13 07-06-2011 06:50 PM
